Question about Sony WEGA KD-34XBR970 34" TV
Sony wega tv standby light flashing 5 times. tv is on but light flashes. ocassionaly tv will not turn on but light will flash three times
  • 2318 Answers
SOURCE: Sony WEGA Fails to Turn On Stand-by Timer Flashes 7 Times
Follow the instructions from the image provide and see if that works, if it does not work; you have a hardware failure in your TV. The hardware failure could be the HOT or flyback transformer.
Let me know if you need further assistance.
Posted on Aug 23, 2008
SOURCE: standby light flashes nine times and tv will not turn on
I had the same problem with Sony KV-32fs120 with 9 blinks. Replaced D645 and D647 on main board with 1.5A1KV diodes from Radio Shack which did the trick.
Posted on Oct 29, 2008
stonephoenix
  • 563 Answers
SOURCE: Sony trinitron WEGA won't turn on and standby
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
Visit the link below so you can talk to Sony either on the phone or via online chat for your full range of options.
http://esupport.sony.com/US/perl/support-contacts.pl?
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Aug 04, 2009
  • 8457 Answers
SOURCE: KV-HX32 SONY WEGA TV
The hight voltage transformer it dead.The FBT(The flyback transformer is dead)The block of plastic with the red wire with a cap hook to the CRT(the tv tube).
Posted on Aug 25, 2009
Testimonial: "Thank you so much"
  • 17 Answers
SOURCE: My Sony Wega 55
if the light flashes 6 times over and over it is the power board. butcheck the lamp
Posted on Dec 08, 2009
Problem with Sony Grand Wega TV
This could be due to bad capacitors in the sweep supply, a bad High Voltage block, a bad regulator.
Jul 06, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
TV popped and shut off red light flashes 5 times then pauses
this specific type of TVs flash their standby light if the onboard testing system sniffed out a problem
so, as if your TV is trying to tell you "i have a problem and i need to be serviced"
i hope it goes well for you
:D
Aug 30, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony Vega TV , On off switch
prolly u need the "D" board replaced--common to give error code of 5 to 6 flashes--unplug and wait to reset and try again
Jul 18, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Flashing light
The LED used in most tv are dual color led,some have two lead, some have three. try to find the same size and replace it.
Jun 20, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Mar 19, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Trinitron KV-32FS12
i think your tv had a lose contact or crack on board
Oct 18, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony WEGA  KD-34XBR970 34" TV Logo
26 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
