Garrison heater Fan does not shut off and power light flashes
2 Suggested Answers
SOURCE: garrison tower heater flashed E3
hi there, i just ran into the same problem i think i have the solution:
the E3 code is a "fall down" sensor shut off, what i think the problem is the internal sensor for when the unit falls over and shuts itself off is really sensitive. i had mine on carpet and it was acting up quite a bit till i wiggled it and put it on a more level surface.
hope this helps
Posted on Jan 08, 2011
Manual for garrison oil heater model #043-5863-4
You should be able to download a manual here:
garrison oil filled heater model 043 5863 4
Also please be advised, your model may be under recall due to fire hazard:
http://www.healthycanadians.gc.ca/recall-alert-rappel-avis/hc-sc/2013/36781r-eng.php
Nov 16, 2016 | Heating & Cooling
HOW TO DOWNLOAD OWNERS MANUAL FOR GARRISON OIL FILLED HEATER MODEL # 043-5950-6?
Here ya go:
https://www.manualslib.com/manual/906339/Garrison-043-6127-2.html
Sep 19, 2014 | Heating & Cooling
Garrison heater
Return it as defective. Check operation of the replacement one before bringing it home.
Jan 04, 2014 | Hardware & Accessories
Require manual for garrison oil filled heater # 043-5950-6
Try Googling (garrison)(043-5950-6)(manual) without parens.
Nov 13, 2013 | Heating & Cooling
Garrison heater red light on but no heat
I just fixed mine with the same problem. I first called Garrison and they wanted to send a tech out to fix my $60 heater that was just of warranty..I said no of course. Any how I have a electronic background so troubleshot myself and found a thermo fuse that was bad. It was located inside the heater and not easy to get to but that was the problem. I am guessing that the fuse goes because of blockage at the top of the heater. Any how it's fixed.
Oct 24, 2012 | Heating & Cooling
Garrison tower heater flashed E3 code?
hope this helps
Dec 25, 2010 | Vacuums
It wont light. the light inside is flashing 2 times systten lockout i want to know what to check
Hi first clean the flame senser ,check the fan control is clean , then jump out the pressure switch see if it lights , you can blow it out with a air line as well ,
you can jump fan control see if it s shutting off/on
check for power at the gas valve and thermostat if fitted check for power at fan
Feb 18, 2010 | Mr. Heater MHU45LP
Error code of 6 flashing light on circuit board,
There appears to be a short in the unit. Not sure where. The power to the fan is not interrupted completly when the fan shuts down, still feeding voltage to the fan, keeping it running slow. Before checking the wiring, please turn off power first.
Nov 19, 2008 | Heating & Cooling
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
