Question about LaCie Computers & Internet
Error code 0652 when trying to install easy media creator for the d2 DVD+RW drive
When I tried doing the lightscribe install I get an error 'A newer or the same version is already installed.'
Blue Hammer
  • 167 Answers
SOURCE: Sandisk cruzer titanium 4.0 GB
May be the USB drive is damged. Try connecting it to another machine. If it works then plug it in to the same port as you have installed it.
Posted on Oct 27, 2007
  • 102 Answers
SOURCE: Installation of Lightscribe
Loreen:
Check out this link, make sure that the software/tool or utilities are compatible to PC vista, please also check any firmware as well:
http://www.lacie.com/support/drivers/index.htm?id=10008
In Vista after the download is complete you might have to do this:
right click over the file and select run as administrator, (its strange but it depends upon the user trying to install software on your system).
Hope it helped!
Regards
Posted on Dec 16, 2007
whitetiger93
  • 141 Answers
SOURCE: CANNOT INITIALIZE API - REINSTALL THE SOFTWARE
When you installed the 5.0 in, did you put the update in also?
ecdc_v53.5.10 basic_enu
You will need this or 5.0 will not run.
Posted on Mar 30, 2008
charcois
  • 763 Answers
SOURCE: Sandisk Cruiser not recognized
if you dont mind to erase all the files on your sandisk and if no other solutions then format it to be use again.
CHARCOIS
Posted on Aug 29, 2008
bunnydawg
  • 5158 Answers
SOURCE: my SONY DVD+RW DW-56A won't burn a DVD
I am suspecting that you are running into a copyright issue that wasn't removed when they made the copy.... or the copy was corrupted... will it play back on your machine ?
Robert
Posted on Dec 20, 2008
Sony Optiarc AD-7581A 8x DVD?±RW DL Notebook IDE Drive w/LightScribe Burner is not being recognized and installed.... It shows the error 10 "device will not start" can anyone help?
Try a cold boot. Shut down the computer. Remove the battery. Unplug the power cord. Wait at least five minutes. Start up the computer. If still does not work, go to device manager --> CD/DVD drives. Uninstall the Optiarc drive. Go to Actions --> Scan for Hardware Changes, or simply reboot to reinstall the drive.
Apr 05, 2010 | Sony Optiarc AD-7581A 8x DVD?±RW DL...
Is there a software update for lightscribe for lacie d2 blue ray burner, so that I can burn dvd titles on a disc?
When you say "burn dvd titles on a disc", do you mean to write (laser-etch) the name of the movie on the plastic disk? I am assuming that is what you mean. If not, please describe what you mean. . No, LaCie does not make a Blu-Ray LightScribe drive. This is a technology/hardware problem, not a software problem. . There are a small number of internal (I know you want external) Blu-Ray burners with Lightscribe hardware built in. Here is one: LG LightScribe GGW-H20L Blu-Ray DVD Sata Drive. . The Lightscribe website says no such media exists, even though the drives have been available since June of last year: http://lightscribe.com/products/index.aspx?id=106 Watch that site for info about the media. Once the media is available, you will be able to buy the external drive you want. . Here is a burner for only $4,400 (that is not a typo):http://www.meritline.com/sharkblu-lightscribe-8x-blu-ray-dvd-duplicator-1-11---p-35937.aspx . OK, it is a duplicator (burns up to 11 copies at once), hence the high price, but useless without the media. . BTW - It is a simple matter to buy an external USB2 or FW case and put an internal burner in that case to make an external drive. . --Dave
Feb 07, 2010 | LaCie d2 DVD-RW Burner
How do I activate the option to burn an 8.5GB DVD+R DL using LightScribe HP dvd1070? I am using Roxio Easy Media Creator 10.
That option would be set in Roxio, not the drive itself.
Make sure that your machine meets the requirement for speed and memory required to write DVD's at this density.
Dec 22, 2009 | Lite On LightScribe (HP640VI) (HP640VI)...
IS THIS SOFTWARE SUITABLE FOR USE WITH SONY DVD RW
Yes it certainly should be compatible with the CD/DVD drive.
Roxio has it's own burning software included with the program, you will just have to explore the software until you work out how to burn a CD using Roxio itself.
If you want to try another burning program try Nero 9 trial. All you have to do is enter your email address and then download the software. Nero is an excellent bit of software, i personally have never had any problems with it.
Get Nero 9 here >>>>>>>>>>
http://www.nero.com/eng/downloads-nero9-trial.php
Regards.
Sep 29, 2009 | Roxio Easy Media Creator 7
Roxio dvd disk type doesn't match project type
Check the following parameters
- Type of disk--> it must be a DVD RW disk (Read and write), if the media is only DVD R, you can't burn it
- Your DVD driver--> Check if it accepts DVD RW(-) or DVD RW(+) or both. With this information, check if the media matches the driver capability
- Roxio settings--> In the Main Menu select--> Disc--> Disk information--> confirm that the right driver is selected (drive D or E or the letter your computer uses for the DVD driver)
Nov 07, 2008 | Roxio Easy Media Creator 7
EZCD 5.0 and EZCD 6.0
I don't think that 6 and 5 are compatible 6 is an upgrade from 5. I have just 5 on one of my old XP computers and it works fine, but that's all I have. I went to the website and they are not giving any support for Roxio 6 anymore.
I will tell you that Roxio Easy Media Creator is fantastic. The things you can do with that are unbelieveable. I got it at Sam's Club for about $70. But I know that does not solve your problem.
Roxio 5
To burn data files, Open project selector, make a data cd, click data cd project. WhenEasy CD Creator 5 opens and you choose your files to burn, try this: Select Disc at Once Radio button, click okay and click burn.
ID Number: 000008GN Products: General Information
OS: Issue When burning a CD or DVD, you receive an error, burning does not complete, or your media is rejected. Resolution Burning errors can happen for a variety of reasons. Roxio has found that doing the following steps resolves about 80% of all burning issues. Please give all these steps a try and see if it fixes your writing problems.
  1. Update your drive's firmware/drivers. Most companies regularly update their firmware and drivers. If you are unsure what model your burner is and its firmware, click here to find out.
  2. Enable DMA. Direct Memory Access enables better efficiency of data. For more info, check how to enable DMA.
  3. The media. Check the following:
    • The disc is clean and unused.
    • The media is recommended by your burner's manufacturer or try a different brand, preferably a name brand, if you continue to have problems.
    • Make sure that media (-R/+R, -/+RW, dual-layer compatibility) is supported by the burner by checking burner's manual or manufacturer's website. This is especially true for some Blu-Ray burners which do not support CD-R/RW media.
  4. If your burner is external, make sure it is connected directly to the computer via USB/Firewire and not a hub or other other device like a sound card.
  5. Update to the latest PX Engine. The PX Engine improves compatibility with newer burners on the market.
  6. A reinstall of the burner's drivers may also help.
    • Windows XP: Go to My Computer and choose Properties.
    • Windows Vista: Go to Start --> Control Panel --> System and Maintenance --> Device Manager.
    • Click on the Hardware tab.
    • Select Device Manager
    • Expand DVD/CD-ROM Drives, then select your burner and uninstall it by right -licking on it.
    • Reboot.
Roxio 6
OrangefoodJSLib.events().registerNativeEvent("mousemove",document.getElementById("rating_img"),highlightRating); OrangefoodJSLib.events().registerNativeEvent("mouseout",document.getElementById("rating_img"),ratingExit); OrangefoodJSLib.events().registerNativeEvent("click",document.getElementById("rating_img"),ratingVote); Article Details ID Number: EE6000132 Products: Easy CD Creator 6.x Platinum Suite
OS: Windows 98 Second Edition
Windows ME
Windows 2000 Professional
Windows XP Home Edition
Windows XP Professional Edition
Issue Roxio does not recognize the blank CD/DVD media in the recorder drive.
Resolution Follow the listed procedure to ensure that the CD/DVD media you are using is supported by your CD/DVD Recorder.
On Easy CD and DVD Creator:
  1. Open Creator Classic.
    1. Launch Roxio Easy CD & DVD Creator 6.
    2. Click on the Creator Classic icon.
  2. Check the supported media types.
    1. Click on Tools on the top left hand corner of the window, then select Drive Properties.
    2. Under the Devices section, click on your CD/DVD Recorder drive.
    3. Under Supported Media, click on down arrow to see a list of supported media your CD/DVD Recorder supports.
    4. Ensure that media type that you are using is listed here. If it is not listed then your CD/DVD Recorder does not support that type of media.
On Easy Media Creator:
  1. Launch Disc Information.
    1. Launch Roxio Creator Home menu.
    2. Click on the Tools tab, then select Disc Information.
    1. Under Supported Media, ensure the media type is listed.
    • Reboot.
I do know if you have Roxio5 you cannot installed Nero 6 InCD, not compatible. Other than all of the above, I have no more suggestions. I am really sorry, wish I could work on your computer to figure out the problem. This is my specialty. Reloading computer and figuring out problems. It is so much easier hands on.
Good Luck
Mar 30, 2008 | Roxio Easy CD & DVD Creator 6...
Lite-On SHM-165H6S & Lightscribe 1.2 media
have you tried updating the software to the latest version, there are probably patches on the manufacturer's website.
Oct 27, 2007 | Lite On Lite-On SHM-165H6S DVD+R/RW -R/RW...
DVD RW - Installation Problem
Ok. What I am going to suggest may seem like a daunting task but if you are careful and do only what I suggest you should be ok. The first thing you are going to have to do is manually make a change to the Windows registry to fix the permissions. 1. Fix registry permissions a. Click on "Start" choose "Run", then type "regedit" and click "OK". b. In the Registry Editor, click on the "+" next to "HKEY_Local_Machine". c. Now click on the "+" next to "Software". d. Right-click on the key (folder) called "Roxio" and choose "Permissions". e. Make sure that "Administrators" and "System" have checkmarks for "Full Control" - "Allow". f. If you had to add those checkmarks, click on "Apply". g. Click on "Advanced". h. Put a checkmark in "Replace permission entries on all child objects with the entries shown here that apply to child objects". i. Click "OK". j. Click "OK" again. k. Now close the Registry Editor Next, you will have to uninstall the Roxio software. 1. Remove Roxio Easy Media Creator 7 a. Go to Start--->Settings--->Control Panel--->Add/Remove Programs b. Select Roxio Easy Media Creator 7 and select "Remove" c. Once the uninstall is complete, reboot the computer. 2. Reinstall Roxio Easy Media Creator 7 a. Insert the CD and install as you did before and then reboot. If you have any issues uninstalling the Roxio, go to the following link to download the Microsoft Cleanup Utility... http://support.microsoft.com/kb/290301 Run the utility after the unistallation attempt and then reboot and reinstall Roxio. Hope this helps. Good luck.
Jun 19, 2007 | LaCie 8x DVD+/-RW USB 2.0 External Dual...
Easy Media Creator 7.2
You may need service pack 2, but if you have; then the software may not be compatable with SP2 and may need you to visit the Roxio website for any patches or fixes. There are other programmes you can download for free from the internet to try instead, although, i would recommend Nero 6 or 7. Also ensure you have enough system memory as these programmes take up usage memory, then require more to manipulate and burn videos etc.
Jan 06, 2007 | Roxio Easy Media Creator 7 for PC
Computers & Internet Logo
16 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
