Question about Saeco Odea Go
Beans grind but coffee does not come out then red light flashes
Saeco
SOURCE: Saeco Incanto Flashing Red Bean Light
I found a machine in my dentist's office with this exact same problem. I'm not familiar with the model, so I downloaded a manual for the closest model I could find online (the Sirius), and it offered no help -- but in 8 languages!
I ended up just pulling the drip tray, pulling the box where the grounds end up, and re-inserting the assembly (all while the machine was on.) When I buttoned it up again, it worked.
Hope this helps (although I can see how it might not...)
Posted on Nov 15, 2007
dutchman05
  • 487 Answers
SOURCE: saeco italia
ok turn the machine on and wait till warmed up. Open door while machine is on and remove the dreg drawer. This you always need to do when the machine is on otherwise it will not reset.
flashing means dreg drawer steady means coffee beans
Posted on Apr 16, 2008
  • 8 Answers
SOURCE: I have descaled my Saeco Odea and the coffee beans
Hi, Try holding down the steam button for 10 seconds. It should reset the descale warning lamp.
Hope it helps.
Andrew
Posted on Feb 13, 2010
SOURCE: No coffee brewing with beans, but with coffee brewing with ground coffee.
make sure you use very dry non-oily coffee beans
Posted on Jan 31, 2011
SOURCE: Saeco Incanto S-Class Sirius coffee machine not sensing beans.
I have the exact same problem with mine.
The machine will work fine with pre ground coffee, but is a no go with beans.
The machine grinds the beans, puts them in to be brewed, moves the brewing unit into the brew position, then I get a short hiss - then it resets chucking the slightly damp dregs out. Interestingly if i run the steam for a good while first, then order a coffee it does seem to try a bit harder - I get a very small trickle of coffee sometimes. It seems like it's not quite closing around the o ring, or as if it's too much pressure and it is blocked, but I know it isn't blocked because it works fine with pre ground!
Either when doing bean to cup I do not get the 'pre brewing - brewing' cycle picture up on the lcd, it's almost like it's missing this part of the operation or it's corrupt?
I have already taken the grinder apart and serviced it - descaled it etc. I use very dry beans, but no water comes out even if I use no beans - again only works on pre ground.
Any help would be appreciated!
Posted on Jul 22, 2013
Why aren't the beans being ground?
try pushing the beans into the grind mechanism while it is grinding or turning the grinder knob but only when grinding, or try different beans
Jun 10, 2014 | Saeco Incanto Classic Espresso Machine
Saeco odea does not brew. coffee beans will grind, then coffee maker will start flashing all lights, and ground coffee will spit out without brewing. when i change beans to more oily ones, it works without...
Hi...Keep on grinding until the Auto Dosing System readjust the amount of grind to be in the optimum. Normally it takes 3 to 4 grinds. Whenever we change the type of beans, this condition happens, it is not a problem.
Aug 29, 2011 | Saeco Odea Giro Plus Coffee Maker
My SAECO Talea Giro is not working. I have cleaned it properly and coffee beans and water is filled up. The red exclamation mark and the warm water lights are flashing. I can produce steam without a...
The thing that comes to mind is the brew unit is blocked and or the grind is too fine. Remove the brew unit and clean the screen under the red o-ring.
Aug 06, 2011 | Saeco Talea Giro Espresso Maker -...
My Saeco Vienna Black Automatica Espresso maker will grind coffee only about one-fourth of the time. Other times, it makes whirring sound and then shuts off and red "coffee bean" light comes on.
Your grind is to fine. Turn the big knob in the bean hopper up 4 clicks and try again. It could be oily beans which would require the same solution.
Nov 02, 2010 | Saeco Vienna Espresso Machine
Red warning light comes on in my saeco vienna deluxe I just aquired this unit and to date have not been able to make a cup of coffee. All the green lights light up and coffee starts grinding but after that...
Hi
More than likely your grind is to fine and you are using oily beans (shiney). There is a small knob in the bean hopper. turn it down to the minus side. Turn the big knob to the # 18. If that doesn't work you are going to have to take the grinder apart and clean it.
Jan 07, 2010 | Saeco Vienna De Luxe Espresso Machine
Saeco Giro Plus Bean Grinder Section Inoperative
i am facing the same problem. Please let me know if you can fix it. Thanks.
Mar 01, 2009 | Saeco Odea Giro Plus Coffee Maker
Hot water
Grinds are too fine and or the coffee chute is clogged.
Feb 19, 2009 | Saeco Vienna SuperAutomatica Coffee...
Stuck grinder
make sure you not get any damp into the grinder. If you have damp in the grinder then it do not grind the beans.
/Mirran
Aug 30, 2008 | Saeco Incanto Classic Espresso Machine
Nov 10, 2007 | Saeco Incanto Classic Espresso Machine
Open Questions:
See all Saeco Odea Go Questions
Saeco Odea Go Logo
21 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
