Question about JVC GY-HD100E Mini DV Digital Camcorder
Serious problem during recording process. "Black holes"
I own a GY-HD100E, and i'm having serious problems in the recording process.
Most of the tapes have what i call "black holes" in the midle of recorded footage. For example:
scene 1, ok
scene 2, ok
scene 3: the screen turns blue, and appears: "changing format"
scene 4, ok
I didn't change formats, has the camera seems to claim, once the same format was used in the all tape.
Also the problems seems to hapen when the camera turned off, and then connected again to record. It doesn't cut pieces of a scene. It disapears the all scene...
Sometimes in the "black holes", the first frame of the scene appears, and stands still in the screen, with the timecode running. This tells me that probably something is recorded, but the camera can+t read it.
This happened in HDV 25p, and HDV SD50p
This happen in several places, several situations, with several brand tapes.
I already contacted some GY-HD100E users, but none seems to recognize this problem.
During recording the image is OK in the monitor and in LCD. No message is show, and you only notice when you playback the scene in VTR mode
thank you.
2 Suggested Answers
SOURCE: unable to
Okay, so if you want to do real-time capture, you need to setup a playlist of clips on the camera. when you go to play the playlist, do NOT press the center button in, push it to the right. Then it will start doing what you want.
Posted on Aug 20, 2009
What does this mean?
Water vapour formed during the combustion process from water in the air. More noticeable on a cold engine on a cold morning. If you have fears of something more serious have a cooling system check done to test for head/gasket problems.
Apr 27, 2013 | Cars & Trucks
What does it mean when check engine light blinks
A flashing check engine light indicates a serious condition with the engine, and the car should not be driven far until that condition is repaired. You need to have the fault codes read to determine what the problem is. You can have this done at Auto Zone for free. If you continue to drive like this, you will destroy the catalytic converter.
Jun 16, 2012 | 2004 GMC Envoy
Hi there seems to be a problem with the iris to my HVC GY-HM100. I'm hoping it's just a setting that needs to be changed. Basically on complete manual mode the picture just keeps flickering in black and...
See if you can reset camera to factory defaults. If not then you have a serious issue with the camera electronics.
Think that puppy is ready for retirement since repair, if available, will cost a small fortune and not be worth it.
Sep 19, 2017 | JVC GY-HM100U High Definition Camcorder
Black screen laptop
during the boot up process for a short time you will see press a certain key to enter set up
press that key to enter BIOS scroll to PnP/PCI configurations the default is disabled
select enabled to reset configuration if you have installed a new add on and it has caused a serious conflict that the operating system can not boot
or you might try
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
Feb 26, 2011 | Computers & Internet
Some time my laptop is having problem during booting process-getting error disk error.....some time it is ok..please help me ASAP.
sir your hdd has serious problem it batter to replace and dont save any important data on it...Thanks
Oct 15, 2010 | HP Compaq Business Notebook 2230s
Cyberlink youcam unable to record audio properly
I've just run an experiment using two separate mic's and can for certain YouCam has a serious problem with audio. If you hold any note (voice, piano, you pick), for more than 2 seconds, YouCam cuts off the note after the second #2, and all you hear is some phase shifted garble over the remainder of that note. Real nice.
Jan 16, 2010 | Acer Computers & Internet
JVC GY-HD100E Mini DV Digital Camcorder Logo
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
