Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Brushes won't turn and vacuum will not pick up sprayed cleaner
Motor runs strongly but brushes don't revolve and no cleaning solution is picked up.
  • 29 Answers
There's a Capt. Obvious fix to check before you go any farther. Like many vacuum cleaners, the brushes on the Bissell carpet cleaners, by design, only spin when the handle is not locked in the upright position, so be sure to plug it in, turn it on, and depress the foot pedal to lower the handle while watching the brushes one more time to be sure that the fix isn't that easy.
If the brushes still won't spin with the handle in the unlocked position, lift the handle back up into the locked position, power off and unplug the Bissell, and look down and see if either of the two belts that make the brushes spin are broken, as a broken belt, or a belt that's come off the track, is the next most likely problem. Both belts must be unbroken and in the right place for the roller brushes to spin.
These belts can be seen in the clear plastic pieces on either end of the roller brushes. If you're having trouble locating them, **with the Bissell unplugged so the brushes won't suddenly start spinning and hurt your hand**, try spinning the brushes with your fingers while watching for the belts. They're black, about the thickness of two quarters, and the bigger one of the two (on the left end of the roller brushes, as you face the front of the Bissell), is just big enough to fit around both roller brushes. The smaller belt, goes around the back roller brush on the right and to a smaller cog wheel behind it. If you see a broken belt, or a belt off the track, that's your problem.
Here's a video you can watch for free on Bissell's website that tells how to replace a belt. I'm sure the belts can be ordered online somewhere or found at some Bissell dealers or repair shops. Note, again, the two belts are different. If only one is broken, be sure to order the correct one.
http://cache.vendaria.com/vpop/VpopV6.html?ct=13&ctname=CT630X556D630X390&fw=630&fh=556&logo=49&fv=10&ap=vnd_bissell_change_belt_proheat_2x&purl=MAIN_bissell_change_belt_proheat_2x&iid=sbpgzLIuvIlJlJquLvumgwqKqvIqvv&bg=ffffff&nm=BZOpener&curl=&err=0&title=Bissell&tp
If the belts are intact and in the right place, does the metal cog wheel behind the roller brush right turn when the Bissell is on and the handle is dropped? If not, then the motor that turns that cog wheel must be burned out.
Posted on Jun 12, 2009
SOURCE:
Hoover cyclean brush stopped revolving
The belt may be broken or worn If your cleaner is not picking up fluff and hair from the carpet or has become heavy to push it is possible that the belt has snapped. This belt makes the sweeping brushes spin round underneath the cleaner and brush dirt into the path of the air suction. The brushes also give that 'groomed' look to your carpet by gently brushing the carpet fibre. If you pick up something sharp or debris gets jammed in the brushes then the belt may snap. Also over time your belt will stretch, so it's a good idea to change your belt once per year to ensure the cleaner picks up dirt effectively.
Dec 14, 2016 | Hoover Vacuums
My miele flamenco II vacuum cleaner motor makes a loud grinding noise what's wrong with the motor?
Hello Louis Casado,
Most of these motors make noise because the bearings have gone bad and need replacing...
(loss of lubricant or other-than-round ball bearings).
Alternatively... the rotor brushes have picked up something that is clashing with the housing... and needs to be resolved.
Clean it all... really good & run it without a load...
If all else fails to remedy your situation... pull the beater brush and cut everything but the fixed bristle rotor brush... clean it... cut it free... check out all clearances... and return it to service
Hope this helps!
Happy hunting!
Oct 18, 2016 | Miele Vacuums
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
My pet vac only pick up via the tools and the brushes are not spinning
1( test the belt , can be worn, and replace
2( test the power brush and clean, and replace if necessary
3( clearing the hose.
4( see the diagram.
5( test the motor if need Repair.
Sep 06, 2012 | Bissell Upright Vacuum - The Pet Hair...
Power light on but motor won't run. where do i
the motor carbon brushes need replacing which is a most difficult job to get the cleaner disassembled. Brushes are easy to fit if You have replaced carbon brushes in other appliances etc..
Getting to the brushes in the Kirby is very difficult...
Lee in Australia
Jul 28, 2011 | Kirby Generation 3 Bagged Upright Vacuum
Hoover Bagless WindTunnel vacuum cleaner.
very easy. you have clog. take the brush off look where the hole is thats where the clog is. it might be in there you might have to take the housing off of the motor
May 08, 2009 | Hoover U5753-900 WindTunnel Bagless...
Do i need to do anything special when replacing the brushes in a lamb ametek 117500 motor? It looks like I can just remove the old brushes and insert the new ones. Is it this simple? Will the motor work...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=758676
Generic problem for all Vacuums
Do I need to do
Posted by edkraynak on Jul 08, 2008
Do I need to do anything special when replacing the brushes in a lamb ametek 117500 motor? It looks like I can just remove the old brushes and insert the new ones. Is it this simple? Will the motor work again? Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Make sure they are the right carbon brushes for your particular lamb motor and once you have installed the new ones then there is a seating chalk that you place against the armature to help seat the carbon brushes, you can pick up the seating chalk @ your local vacuum cleaner store or contact Lamb / Ametek listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.ametek.com/contact/index.cfm
Customer Service – 610-647-2121
AMETEK Corporate Office
37 N. Valley Road, Building 4
P.O. Box 1764
Paoli, PA 19301 U.S.A.
Tel: 610-647-2121 Fax: 215-323-9337
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 08, 2008 | Vacuums
How do I work this dam thing?????
How do I work this?
Bissell 1699 ProHeat Clear View Upright Steamer
The Bissell has a holding tank to the solution and the recovery tank for the water and soap you pick up -- -both are removable for cleaning purposes – there is a trigger assm on the handle to release the Bissell Soap or detergent that you are using – (low sudsing) and there should be a switch on the bottom of the unit to activate the revolving brushes. So the best way to shampoo the rug is to do it on the back pull – when you pull back you are dispensing the water solution and shampoo by squeezing the trigger assm, the brushes are agitating the carpet and the vacuum part is picking up the water. This is about as simple as I can get it – please refer to the owners manual for the trouble shooting part of the manual or check with your local vacuum cleaner dealer in your area and in the yellow pages under vacuums, or call the Bissell factory phone # or use the website.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Don – The Vac man
Apr 22, 2008 | Bissell 1699 ProHeat Clear View Upright...
Hoover sttem cleaner
The brushes spin by virtue of an air driven turbine. This turbine uses a little of the motor suction to turn a large fan which turns the brushes. If you look behind the clear glass window on the front right hand side of the machine, you will see a screen which acts as a filter to keep debris out of the turbine. If this screen becomes clogged, it will affect the flow of air to the turbine and the brushes will slow down or stop all togeather.
Also, if the lid of the recovery tank is not on correctly, the suction will be compromised and the brushes will not turn and the machine will not pick up water off the carpet.
Feb 04, 2008 | Hoover V1 SteamVac SpinScrub Vacuum
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
706 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
