Need ballast for LiteSource LSM-180 magnifying desk lamp
Need ballast that is located in the base by the clamp. E4819-A-P or E127641
4 Suggested Answers
  • 9 Answers
SOURCE: i need change the ballast board on a HD-61FN97
well make sure that first u work in an antistatic area... you can achieve this by hooking the workbench or even urself up to the earth connection in a power socket( THAT IS IF U KNOW WHICH ONE THE EARTH IS) label every connector and cable to the board, draw a diagram if need to... use a NONSTATIC screwdriver to unscrew the board, it should slide out quite easily so this shouldnt be a problem, then take out old board, put in new one connect cables and connectors according to diagram u made, and shove it back in... so yeah not to hard, but antistatic is the key word
Posted on Mar 17, 2009
ladywinn
  • 5138 Answers
SOURCE: where is ballast located
FOX has Lamp for $109.00 1-800-227-5369
Encompass Parts has Ballast $54.43 1-800-638-3328
Encompass wants $150.00 for lamp Your TV is a Samsung it will be on Right Hand Side of TV and I would Just Replace The Lamp First? What was your TV doing to begin with?
Posted on Jan 01, 2010
  • 6 Answers
SOURCE: HP DLP md5020n TV. I need a new Lamp BALLAST
http://shop.ebay.com/i.html?_nkw=hp+md5020n&_armrs=1&_from=&_ipg=
Posted on Feb 10, 2010
Lamp light flashes amber without the lamp ever turning on, then projector shuts down in a minute or two
Based on what you're describing, it sounds like a failure in the lamp ballast itself. The projector will probably need to be sent for service.
If you have a spare lamp, that would be the first thing to try. However, if it isn't that, it is likely the ballast.
Mar 15, 2016 | ViewSonic PJ402D DLP Projector
The bulb is flickering. I have replaced it but the new one also flickers
replace the ballast I can send you one cheaper than you could purchase it I have 100s of them in storage always a ballast if they flicker
Apr 10, 2013 | Verilux Modern Deluxe Natural Spectrum...
BALLAST PART No FOR A SAMSUNG SP50L6HX PLEASE HELP
Google that model number with ballast or lamp ballast to locate the part and its number. Usually the color wheel will not operate if ballast is not working---Lamp comes on and stays on the Ballast is good.
Nov 06, 2012 | Samsung SP50L6HX 50" DLP HDTV
Sharper Image Desk Lamp S1412. I need a manual. Lamp has quit working. Doesn't appear to be the bulb.
I have the same lamp with similar problem. I suspect the problem is with the ballast or starter, not bulb or switch. Ballast likely in the base. I'm searching for a replacement ballast.
Jul 03, 2010 | Kitchen Appliances - Others
Where is ballast located
Dec 31, 2009 | Televison & Video
Samsung SP50L6HX, I replaced the Lamp but still nothing.
Hi, Samsung haves a known issue with the ballast, once you make a replacement of the lamp, sometimes its harder to ignite a new lamp that has 100% of gas inside than igniting a old lamp that has maybe 60% or 50% of gas inside. Just in order to ignite the lamp, the ballast needs to send some High Pulses of Voltage, as high as 15 kV (that is the constant clicking sound that you are hearing). In order to resolve this you need to change the Ballast Board. I tried to look for your ballast with your TV Model # at samsungparts.com , but nothing showed up. You will need to find out which ballast part # you have in order to find it online. To locate the ballast part # please check the end of this video, you only need to take the lower back cover of TV off. http://www.youtube.com/watch?v=0jr_9A5Xd2Q
Here is a link of a ballast I found http://www.discount-merchant.com/SAMSUNG-9137-008-08905-Lamp-Ballast-Driver-p/1138231.htm?Click=49915
Dec 24, 2009 | Samsung SP50L6HX 50" DLP HDTV
Purchased Sharper Image Model S1481 desk lamp and it stopped
you can go for LED retrofit w/ this one on amazon:
http://www.amazon.com/--1134-Lumens-Conversion-FML27W-Fluorescent/dp/B00J7Q4004/ref=sr_1_42?s=hi&ie=UTF8&qid=1402581740&sr=1-42
bypass the ballast & just connect LINE & NEUTRAL wires (from the ON/OFF switch) to the LED light
seth
Aug 09, 2009 | Kitchen Appliances - Others
Ballast UART Error
Same thing happened to me. After one minute of running, lamp shuts off and 5 power led blinks and 3 ready led blinks, indicate UART ballast error. Well, I purchased a new lamp, and installed it, and the problem was gone. I looked closely at my old lamp, and it showed a little blister inside, and a tiny spot of white residue, perhaps it was the whole problem there, although I don
Nov 20, 2008 | Televison & Video
Projection lamp replacement
the only thing that would burn out another lamp so quickly is if the ballast assy was also bad.
C-Dog
Feb 10, 2008 | Televison & Video
Televison & Video Logo
169 people viewed this question
Top Televison & Video Experts
Electro Med Services...
