Question about Midland Radio Communications
Midland 77-118 cb/ weather radio
The weather works but the CB side just makes a pulseing noise
    Habit-Forming:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 104 Answers
Sounds like the cb section is way off frequency. Check it out first.
Posted on Jan 12, 2016
wyoed1
  • 211 Answers
SOURCE: 75-822 midland radio
You have a bad detector in the radio. Needs serviced. Change the bad detector diode and it should work. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
wyoed1
  • 211 Answers
SOURCE: midland cb model 13-895
Hi Frank, It sounds to me like you may have a bad dectector diode. Other possibilities are cold solder joints in the stand up boards in the IF section. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 08, 2008
Communicomm
  • 90 Answers
SOURCE: wiring a midland 78/999 cb radio microphone
Pin 1 = white
Pin 2 = shield
Pin 3 = black
Pin 4 = red
Posted on Sep 29, 2008
One Wire
  • 126 Answers
SOURCE: converting a different brand of mic for a midland CB
This should be a typical Midland pinout. If you are using a generic 4 pin mic that is wired to cobra/Uniden, all you have to do is switch pin 1 & 2, then 3 & 4.
Not all mics are color coded the same with their wires.
Posted on Oct 06, 2008
kb8dns
  • 494 Answers
SOURCE: lookin for info on midland cb 13-830 and 77-824
Both radios are AM only, the 13-830 is 23 channel and the 77-824 is 40 channels. Of the two the older 23 channels is a better radio and is able of more frequencies.
Posted on Mar 07, 2010
Pulse noise
Not sure what you mean. Can you give more info?
Feb 11, 2014 | Midland 1001Z 40-Channels Base CB Radio
My uniden pc68ltw seems like it wont switch from weather band to cb. I can still hear the weather band after i switch to cb. I can not hear anyone one cb mode
You need to take off cover locate wires to that switch and cut them loose from CB/WB and buy a Toggle switch to mount outside radio and switch it on/off like to make CB/WB selection..Seems that switch inside is screwed. needs new one. I would rigg it myself. By drilling hole in cover and placing outside toggle with white marker saying Cb top Wb bottom.
Mar 23, 2011 | Midland 75-785 Handheld CB Radio
Midland cb radio. when i turn on my wipers i get a noise over the cb radio
This is usually caused from a poor ground. Try to reground the radio to a better location and it should fix it.
Jan 06, 2011 | Midland 1001Z 40-Channels Base CB Radio
No talking
This could be several things, first I'd look at your antenna system,make sure its matched to your truck. When I say this you need a good ground good coax at least 18 foot,the mount and it installed right and the right kind of antenna, they make many different one because not all work on what you're installing it on. Then I'd check your mic if it has a broke wire it can also cause the problem you're having, most midland mics are wired different so don't just find another one.
May 02, 2010 | Midland 1001Z 40-Channels Base CB Radio
I have a midland 77-115 weather max111 and there is a humm in it i think becouse of the freq conversion any sugestion before i stick my finger in it to convert the channels bach to 27mghz
what kind of hum are you getting. and is it power line noise or something comeing from the radio. like being converted on a extra band hearing noise?
Dec 09, 2009 | Midland 77-115 CB Radio
My roadtrip cobra cb won't talk with my midland gxt radios
What midland is it? if its a gmrs 2 way radio, like a walkie talkie, even tho it has 40 channels, it is not a CB. it transmits on a completely different band.
CB is in the 27mhz band, and gmrs is in the 462 MHZ band.
They will not talk to each other.
Oct 23, 2009 | Cobra Radio Communications
I'm getting engine noise in my midland 1000.
This is an old problem with a solution that helps but not completely.
You need to search for 'spark suppressors' on a site that appeals to ham radio folks.
You may also need a special filter for the alternator; they are a known source for this kind of garbage.
Mar 22, 2009 | Midland 1001Z 40-Channels Base CB Radio
Cb not working
Probably cold solder joints on the stand up if boards. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 30, 2007 | Midland 1001Z 40-Channels Base CB Radio
Ed
NC Electronic
Mills, Wyoming
Dec 15, 2007 | Midland 75-822 40-Channels Handheld CB...
Radio Communications Logo
108 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
