Question about Refrigerators
Igloo model MIS1530
Cooler does not work. temp. light is on but can not change temperature from 46. can not turn on inside light or change temperature. I have turned it off then back on.
  • 958 Answers
SOURCE: Westinghouse fridge
cooler means coooler cabinet temperature...
Posted on Feb 12, 2008
joboo1
  • 257 Answers
SOURCE: Haier Thermoelectric Wine Cooler
Hi, Well not much to go on but this is not a complicated unit. Please bear with me as we go back and forth for this type of long distance troubleshooting. The control board on this type of unit uses ambient temperature and that is what should be displayed when first turned on. Knowing that; the unit will not run if the setpoint is lower than the ambient temp. The unit operates on 27F degree difference from ambient. So lets do this, unplug the unit, remove your stuff if any, open the door for a couple hours till the unit stabilizes to room temp. Close the door, plug the unit back in and note the display. Move the setpoint to just below whatever your room temp is, if there are dashes it indicates a temp problem or the sensor that needs to know the difference. Good for now, let me know. Thanks and Good Luck!
Posted on Feb 14, 2009
SOURCE: My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Posted on Feb 17, 2010
richroth
  • 9472 Answers
SOURCE: I have a Avanti wc492d wine cooler that is not
The issue could be the cold control, timer, wiring, or the compressor.
The temp control has to be closed for voltage to get to the timer. The timer then calls for the fans and compressor to run. The timer could have stalled after a defrost cycle or the cold control could not be sending voltage to the timer.
Posted on Jan 28, 2011
imufo2
  • 3773 Answers
SOURCE: Haier Model HNSB02, Serial #
I'm Leo
Yes higher numbers are colder
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Jul 27, 2011
I have a wine enthusiast wine cooler model 272 03 27. Not cooling,compressor kicks on. The fans are running.The temperature never gets below 64.Is it the temp sensor or Control board? Thanks Randy
It sounds like it is in the correct temperature range. You may ned to adjust the temperature to a lower setting.
°C °F Wine Style 19 66 Armagnac, Brandy, Cognac 18 64 Full Bodied Red Wines, Shiraz 17 62 Tawny Port 15 59 Medium Bodied Red Wines 14 57 Amontillado Sherry 13 55 Light Bodied Red Wines 12 54 Full Bodied White Wines 11 52 Medium Bodied White Wines 10 50 Ros?, Light Bodied White Wines 9 48 Vintage Sparkling 8 46 Fino Sherry 7 45 Non-Vintage Sparkling
Dec 01, 2016 | Furniture
I have a igloo 48 bottle wine cooler, and it will show error code "LC" and then you can not adjust the digital temperature or turn the light on. It fridge still feels code? Any ideas would be great!
Could be the temperature sensor. There should be a support number in the manual you can call. Hope you can get it fixed. if not check out my blog for help choosing your next cooler. The Best Wine Coolers The Complete Guide Vino Coolers
Jun 07, 2016 | Furniture
Why is my upright igloo freezer not staying close
The door sometimes warps and need to be lightly twisted back to where all four corners make contact and seal.
Your unit may need to be tilt back a bit so the door wants to close y itself, the front foot pegs are adjustable and can be turned to make the front higher or lower than the back side of the cooler, gravity closes the door when the unit is leaning back.
Aug 28, 2014 | Igloo Cooler Igloo 4.6 cu. ft....
What does the on off switch for inside the frig "?"
Defrost heater.
It should stop the compressor and turn on a heating element to speed up defrosting.
Jul 15, 2014 | Igloo Cooler Igloo - 10.0 Cu. Ft....
Where can I find a replacement hatch for my dockside 25 igloo cooler. The product line is not listed on the igloo website
Go to www.coolerhinges.co
Under bestsellers click on 4. cooler shield cooler hinge type I igloo pair. 14.99 plus 5.00 shipping. Lifetime warranty.
If you need 3 hinges click on 2. cooler shield cooler hinge type I igloo three pack. 21.99 plus 5.00 shipping. Lifetime warranty.
Phone 1-888-810-7283
Jun 08, 2014 | Igloo DOCKSIDE 25 Pier Fishing Cooler
Why does my Igloo FRW700 wine cooler always cool to 0 Celsius or 32F if you prefer regardless of the temperature setting?
It sounds like your temperature control is not functioning correctly. Most temp controls still have a small mercury switch somewhere in the cooling circuitry. I would hazard a guess that if you can turn the dial to different temp settings and it always goes to freezing at 0C or 32F that your temp switch is either bad or the mercury switch (which tips forward or back depending on the setting to make contact and start the compressor) is stuck somehow so that it always sets to the lowest possible setting for your Wine Cooler. Without actually looking inside and testing circuits, that's my best estimation of your issue. Hope that provides you with a starting point to talk to someone who can help you repair it.
May 20, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
Igloo chest freezer 7.2 cubic ft seems running all the time?
It may be on "superfreeze", if there is a yellow light, or it may be set for too low a temperature (try setting the thermostat down to 1 or 2). Check the condenser is clean, and fan working if it has a fan, Check lid is closing properly and the ambient temperature isn't too high.. Lastly, if all else working correctly, suspect short of refrigerant.
Apr 30, 2014 | Igloo Cooler Igloo - 5.2 Cu. Ft. Chest...
Igloo mini fridge not getting cold
The compressor may be frozen. Turn off the fridge for 6-8 hours, then turn it back on. Don't turn the temp to the coldest setting. If it will still not get cold, the compressor is probably bad.
Jan 22, 2014 | Igloo Cooler Igloo 4.6 cu. ft....
Igloo MIS1530 not cold
If it is out of warranty..... Take it to a football field, and see if you can make three points through the goal posts.... Sorry, wish I had a better solution. They just are too inexpensive to warranty $80/hour work plus parts on them.
Jan 09, 2014 | Igloo Cooler Igloo 3.2 cu. ft....
Refrigerators Logo
1,044 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
