Question about Canon ImageCLASS MF4350d Laser All-in-One Printer
Printout is tilted - Canon ImageCLASS MF4350d Laser All-in-One Printer
Printout
The scanning unit may need servicing nor replacement, if sure the catridges are Ok
Jul 13, 2013 | HP Color LaserJet 2600n Printer
I have 3 to 4 months old canon Imagerunner 2420L Printer *** photostat without duplex or any network /scanning facility.The Printout coming very faded, if I print on the backside of the printout . Eve
hi my immage scanner ir2420 display says front left side is open /close but i close evry thing steel the same falts so may be power suply problem how can i get diyagram of power supply plz
Nov 05, 2012 | Office Equipment & Supplies
PRINTING ON PAGE IS VERY FADED AND SOME PARTS NOT PRINTING AT ALL
First, checkthat the USB cable is secure in both the printer and the computer and that theprinter is sitting on a flat surface. The printer may not work if it is tilted.
Next, run a printer check to make sure the printer is operational. To run aprinter check, turn off the printer and the computer and unplug the USB cable.Turn on the printer and press the Maintenance button. Use the down arrow buttonon the printer to highlight More Options on the display screen and press OK.Highlight Nozzle Check and press OK twice. If a page prints out, reinstall theR300 software on your computer.
Lines inPrintout
R300 mayproduce printouts with light horizontal lines that are not a part of theprintout. This is called banding and can have several causes. First, trycleaning the printer head to clear any clogged nozzles. To clean the printerhead on the R300, press the down arrow button to highlight More Options andpress OK. Use the arrow buttons to highlight Head Cleaning and press OK twice.The printer will take about 30 seconds to clean the print head, after which youshould run a printer check as described above. If the printout has gaps, pressthe STOP button to run the print head cleaning feature again. Once there are nogaps in the printout, press OK.
If the printout still has banding, open the Print window on your computer andclick on Properties. In the Properties window you can choose the print quality,speed and printer type. Select a higher print quality and a lower speed andmake sure the paper type matches the type you are using for the printout.
Finally, check that the ink cartridges are not empty or close to empty andreplace them as needed.
Faint Printout
If your printout looksfaint or faded when using the R300, try cleaning the print head. Next, replaceany ink cartridges that are old, low on ink or out of ink. Check that the papersetting on the computer matches the type of paper you are using for theprintout.
Another potential cause of faded printouts is incorrectly loaded paper. Sometypes of paper have a printable side that is whiter or shinier on one sidecompared to the other. The printable side of the paper needs to be loaded intothe printer face up.
Nov 20, 2010 | Epson Stylus Photo R300 InkJet Printer
Magenta horizontal banding on all color printout
I suggest that if your machine is under warranty you call out HP, as I have heard that they don't support these machines with parts therefore you will get a new machine.
Good Luck
Dec 09, 2008 | HP Photosmart 3310 Printer
HP5550 printer; printing VERY slowly
check in which mode u had selected the printout.
1)best mode (the printout will be very slow)
2)normal mode(the printout will be fast)
3)draft mode(the ptintout will be very fast)
so check in your printer properties on which mode u r printing.
thanks.
Oct 13, 2008 | HP Office Equipment & Supplies
Printout problem
Hi Jpex,
If all the other printouts are fine then the problem is more than likely with the programme that the file is downloaded to.
Save the document and the click on edit and change the contrast settings to make the print darker
Regards
Gavin.
Oct 06, 2008 | Brother IntelliFax-2820 Laser Fax
Replaced Toner faxes are black
try a internal printout function6-4-start-
let me know how that looks. if that looks fine you have a static build up on the scanning glass.
if thats the case. lift the front pannel you will see 2 green plastic arms, pinch those towards each other and lift it wont come completly out, " if you see the toner cartridge you've gone to far" ... tilt the white plastic and wipe down the glass under neith this should fix your problem
May 07, 2008 | Panasonic PanaFax UF-490 All-In-One Laser...
"Tilted" printouts
one way to verify if it is the cart. is to install the old and see if it happens, if not get an original cart, if yes it could be the scanner (laser assembly)
hope this helps
Jan 09, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Canon ImageCLASS MF4350d Laser All-in-One  Printer Logo
16 people viewed this question
old marine
old marine
