Question about Rinnai Desa Vent-Free Infrared Gas Heater: Vent-Free Infrared Gas Heater(18,000 BTU)
How do you turn the flames down? - Rinnai Desa Vent-Free Infrared Gas Heater: Vent-Free Infrared Gas Heater(18,000 BTU)
How high should the flame be in a kerosine heater
Adjust wick till nice Blue Flame, if wick to High flame turns White/Yellow. Turn down wick till Nice Blue Colour
Jan 11, 2016 | Heating & Cooling
RPJ 2 Comfortmaker. Turns on, runs for 5 seconds with flames then turns off. Sensor light blinks 6 times. Diagnostic instructions say check service instructions. What's wrong?
on opposite side of ignitor is a flame sensor, turn power off pull wire of flame sensor (single wire) remove flame sensor, clean with steel wool, sand it down to remove oxide build up re install and it will work just fine,
Dec 19, 2015 | Heating & Cooling
Broiler flame on hotpoint stove needs adjustment
as in height of flame? if its too large a flame and you have switched from natural gas to propane gas you must turn the orfice spud down onto the orfice face to adjust it,just land it lightly,do not turn it down overly tight
May 05, 2012 | Hotpoint Ovens
Pilot turns on but when I switch to turn it on,
When you light the pilot, are you holding it down for 30-60 seconds. When you release the pilot button, does the pilot flame stay lit? Or does it only go out when you turn the knob to on position. Make sure the pilot flame is heating the end of the thermocouple and that it's a strong blue flame, not a lazy yellow pilot flame. Make sure the tip of the thermocouple is not burn't off, which usually happens with lazy yellow pilot flames. Replace thermocouple is nothing else works.
May 13, 2010 | Coleman 5040-751 BackHome Open Flame Patio...
I turned one front burner on it came on but
Light burner the same way you did before. When flame is present turn the knob down to "medium" level. Flame should stay on and clicking should stop. Adjust flame accordingly.
Jan 25, 2010 | Kitchen Ranges
GAS FLOW IS TO HIGH PILOT GOES OUT EXCESS GAS FLAME ON TAPPEN FU
Hi this could be a gas leak on the pilot i would get this checked out
Mar 17, 2009 | Tappan TGF320 Gas Kitchen Range
Honeywell Gas Furnace
A Make and Model number of the furnace not the thermostat will help but I can walk you thru the operation of a typical furnace. It sounds to me that the burners are igniting properly but the flame sensor is not sensing the flame and shutting down the system. You will need to find the sensor and clean it and check the wire from it to the control board. Typically, the flame sensor is found at one side or the other of the burner box. It is a small probe that the flame hits. Depending upon your model it may have a small wire attached to it leading back to the control. Or it may be part of your auto-pilot assembly. ? At any rate, you will need to get to it and very delicately brush it off. Then inspect the flame channel. This is a trough area where the flame travels to ignite all burners. Over time, they tend to fill with rust and debris. Take a small screwdriver and run the blade down the trough. Inspect the wire that goes from the flame sensor to the control board. Make sure it is not frayed or broken or shorting out and that the connection at the board is good.
Beyond that, it's time for a technician to come.
Let us know the Make and Model of the furnace (found inside the furnace cabinet) and maybe we can help you further.
Nov 19, 2007 | Heating & Cooling
Heating & Cooling Logo
27 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
