My laptop will notcharge the battery and I had the battery checked still has 78%. battery charger light is dim and blinks
SOURCE: Dell Laptop Charger, wont charge bat. but keeps computer running.
The center of the connetor for the AC adapter to the system has a very fine wire that is the sensing wire for the battery charger. It ID's the type adapter connected to the system. If the wire is bent or broken, the system cannot ID the adapter and the battery charger will not function.
If the wire is bent or broken, then replace the AC adapter. ALso try a different adapter and see if the issue occurs with it. If the issue happens with more than one adapter or if this adapter functions normmaly on another system, then the motherboard will need to be replaced.
SOURCE: my computer battery light is blinking red during charging
it means that the battery is bad
replace battery
SOURCE: Laptop battery wont charge?
It could be the battery needs replacing ... it shows that the battery is charging but it doesn't keep the charge .....
SOURCE: battery light blinking red during charging
Dell or Panasonic? Your post has both listed.
If the blinking light on a Dell is yellow or amber or orange (somewhere in that color range) and continues to blink the entire time it is plugged into AC power (wall outlet) and when you unplug it from the wall the laptop immediately dies .... then you battery is dead and needs replaced.
If the blinking light stops after a while (perhaps a minute?) and then turns green while plugged into AC power, then it is successfully charging - or so it thinks.
When you unplug it from the wall, does it stay up and running?
If it runs, it's OK - just ignore the light and plan on getting a new battery one day, start browsing now. :)
If it dies immediately upon unplugging, then your battery is dead and needs replaced.
SOURCE: my eee pc charger wont charge my laptop...
we had a similar problem the ac jack socket burnt out so we got a replacement part from ebay and my husband put it in and hey presto it works it cost 6 pounds for the part whereas a company to fix it wanted 100
