Question about Montel Williams Living Well 6 Quart Pressure Cooker w/ Accessories
Where do i find a weighted pressure valve for living well pressure cooker
Missing weighted pressure valve for lid
First time user, steam valve on my xl power pressure cooker sits loosely in the sealed position. Wonder if it is broken. It doesn't turn easily to open. haven't started cooking yet. Can you help me?
the valve is a safety valve to release pressure that gets too high
the action is by the weight of the valve itself sitting over a small opening
as pressure is generated by resistance to flow, that small opening area has to have enough pressure ( psi /surface area) to overcome the resistance to flow ( the weight of the valve body)
when that happens there is a brief loss of pressure and then the valve reseats and the cycle begins again
simple ,effective and safe
to relieve the pressure before opening the lid , remove the valve
Apr 24, 2017 | Crock Pots & Slow Cookers
Need to know where yo get a new pressure valve to replace mine
Electric Pressure Cooker - PPC1057E - Fixya
www.fixya.com/support/t21168813-electric_pressure_cooker_ppc1057e
Nov 3, 2013 - Electric Pressure Cooker - PPC1057E - Premium Electric Pressure Cooker - question. ... my pressure valve has popped can i fix this. Sep 15 ...
Electric Pressure Cooker Float Valve Explained - YouTube
? 11:23
www.youtube.com/watch?v=dy31HV50Az8
Jan 21, 2012 - Uploaded by wtbm123
I made this video to explain a little about the pressure cooker lid works. It tells about the weight and the float ...
Oct 15, 2015 | Premium Electric Pressure Cooker -...
Cooks essential #99770 2 art Pressure cooker lid when manual closed is not exactly even
The valves on the lid are "floating" valves, that means they will not sit firmly on the lid. However, food and gunk can get stuck in these valves. Remove it, soak it in hot soapy water, clean the inside with a toothpick and also clean the pipe on the lid that holds the weight. Your pressure cooker should be as good as new!
Sep 20, 2015 | Home
I have a Deni pressure cooker. 1 out of 10 times it works correctly. The last 2 times the top exploded off and spread liquid through the entire kitchen. Thank god nobody was injured. I have went through...
All pressure cookers should have a release valve. Be sure that is clean and allows a free flow of steam when the weight is not on it. Test it with just water in the pot. Heat the water until its just about to boil (with the lid off) then close and lock down the lid. Steam should start to come out of the release valve. If not .. clean it again.
Dec 11, 2014 | Deni Crock Pots & Slow Cookers
I am confused is the russell hobbs slow cooker a slow cooker or is it a pressure cooker i am looking for a pressure cooker not a slow cooker
Russel Hobbs makes both a slow cooker and a pressure cooker - confusingly in Europe they call Slow Cookers pressure cookers. The only way to really tel is if there is a special lid with valves and locks (pressure cooker) not a glass or plain lid (slow cooker).
Sep 05, 2011 | Russell Hobbs RHNPC800P 8-Quart Slow...
Displays e4 wont work
Removed the 3 screws on the bottom. There is a relay near the circuit board. Kind of looks like an old morse code relay. Just tapped out "E 4" in morse code. Plugged it in and it works fine.
May 13, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Presure weight plastic is off
You can remove the plastic cover from the vent valve and it will work fine. If you remove the plastic cap, you will need to manually tilt the valve with a utensil to "quick-vent" the cooker. Watch out for steam burns! Should work fine after that. You need to unplug the cooker and re-plug it to reset the "E4" error message.
Feb 13, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Wolfgang Puck DYB250 pressure cooker
Mine was missing when I received my order also the power cord. I am sending it back to Amazon.com
Nov 09, 2007 | Wolfgang Puck BDRC0010 10-Cup Rice Cooker
Montel Williams Living Well 6 Quart Pressure Cooker w/ Accessories Logo
71 people viewed this question
Top Montel Williams Home Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Montel Williams Home Expert? Answer questions, earn points and help others
