Question about Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2)
My router keeps disconnecting the internet
I have a WRT54GX2 SRX200 wireless router. The lights, especially the power and internet lights, keep blinking on and off every minute or so. I keep getting connected and then disconnected to the internet. How do I solve this problem? I called linksys a few times but they weren't able to help me..
And I know it's not the modem because I can directly connect the labtop or desktop to the internet and there's no problem.
  • sammiey Oct 27, 2007
    When I ping the router, it works when all the lights are on, but doesn't work when all the lights are off..so basically I can ping it for a few seconds and then I can't and then I can..and so on.
    Any suggestions would be helpful.
  • 49 Answers
A blinking power light suggest that the device is already broken. Go to the command prompt and ping the roouter. If you can still ping it then i suggest to upgrade the firmware of your router.
Posted on Oct 27, 2007
SOURCE:
I am unable to get wireless internet access. By directly pluging the modem into my laptop the internet works but the srx200 wirless doesn't connect. I was stold by our internet provider that I may...
Hello nanpw,
To reset your router to factory, take a paper clip and press the reset button. Hold it for about 30 seconds or until the lights on the router flash. open a web browser and type 192.168.1.1 username is (blank) password is admin then run the wireless setup utility, after your laptop is connected its always a good idea to include security.
Aug 15, 2011 | Linksys WRT54GX2 Wireless-G Broadband...
Problem with the Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2) wireless light does not come on
If the wireless light on the router is not coming ON that is a sign of something is wrong with the router settings or with the router itself.
First thing that you can do here to correct the problem is to do a reset on the router, To reset the router using a paper clip or pen press and hold the reset button of the router for 10 seconds while power is ON and then once done let go the reset button and unplug replug the power of the riuter then check now is the wireless light is back ON , if the light for wireless is back on you can now continue an reconfigure the router.
But after the reset and still nto able to bring the wireless light back ON your next step here is to do a firmware upgrade on the router. You can follow these step by step procedure from this link , just click HERE and then follow the steps to upgrade the firmware of the router.
May 23, 2011 | Linksys WRT54GX2 Wireless-G Broadband...
My wrt54gx2 will not power up,is this a common problem and how do i fix it?
Did you try plugging it in to a different power outlet? If there is no power light on your router still after trying a different power outlet, this means that the router has gone bad .
May 22, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
My devices keep losing connection with the router due to loss of power in the router.
Connect the router to a UPS to prevent temporary loss of power issues. Any electronics store will carry a UPS that won't cost you a lot.
Apr 20, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
My SRX200 consistently disconnects from the internet.
the wall plug type power supply (made in China) may be likely bad.
This actually is a switch mode power supply very unlike the old and usual linear power supplies.
It is common the capacitors used in this supply are under rated and do not last very long. Then funny and intermittent stuff can happen.
The problem usually seen with dim LED lights on the unit, limited range and intermittent operation.
Try to find a replacement power supply with perhaps higher current rating.
Good luck
Jan 06, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Any update for l2pt protocol
Hi Milian,
Currently WRT54GX2 does not have support for L2TP connection. You may try to use WRT54GS. It has an option for L2TP connection.
Hope this helps
Oct 04, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Connecting linksys srx200
It means that the router is not yet configured properly for internet connection. Who is your internet service provider and what is the model or brand of your modem?
Aug 20, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
How do I get rid of the router using an automatic private address which keeps disconnecting?
the router will give you a private address , that is the functionality of the router, the problem is not with your connection, try to upgrade the latest firmware inthe router and reconfig the router in a pppoe mode that will fix your problem..
Dec 20, 2007 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2) Logo
1,486 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
