Question about Maytag Microwave Ovens
How to reset the microwave - Maytag Microwave Ovens
Reset lg microwave LMHM2017ST
As far as I am aware, you can reset the microwave entries with the STOP/CLEAR button. This is the only way to clear all entries on the oven.
Nov 14, 2014 | LG LMHM2017ST 1000 Watts Microwave Oven
My microwave want cook
Hello
and/or circuit breakers, particularly in the case of recent power failure, and reset if necessary.
Unplug the microwave, wait 30 seconds and plug back in to the power supply to reset the microcomputer.
Open and close the microwave door firmly and press "Stop/Reset." Select a new cook time and press "Start."
Ensure a proper cooking temperature and/or time is chosen, as low cooking temperatures or short cooking times may prevent the microwave from heating food appropriately. Press "Power Level" to ensure the microwave is cooking at 100 percent power.
Contact an authorized service technician if the problem is still unresolved.
Oct 04, 2011 | Sanyo Microwave Microwave Oven
When you put something in microwave and push for time it will run for about 5 seconds and fan will change tone and it won't heat anything
HELLO.
TO MAKE YOUR MICROWAVE WORK AS REQUIRED BY YOU.TAKE THE RESET STEP
4 Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
5 Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Thanks.
Sep 07, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave resets itself whenever the door closes. I do not even program the time on it because it always resets. The microwave works, just very annoying.
either a defective circuit board or a keypanel problem. reset clock and disconnect circuit board keyboard ribbon connector to isolate problem.
Aug 06, 2011 | GE JVM1340AW/BW/WW Microwave Oven
No power to viking microwave unit.tripped fuse in house and than reset fuse but doesnt work.
Check to see if you have a "reset" button on your microwave, or even just by pressing the "clear" button first. Check to see if you have a "master" or "red" reset or "test" button nearest to your microwave on a light switch and reset that if applicable. You could also check to see if your unit has a fuse and replace that. It's possible when you tripped the fuse in the house you might have blown the fuse in the microwave.
Oct 09, 2010 | Viking DMOR205SS Microwave Oven
Microwave resets after start
See this FixYa solution. even if your model number is different.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
May 23, 2010 | GE JVM1650 1000 Watts Microwave Oven
Emerson MWG9111SL microwave reset switch
my microwave stoped woring and i dont know where the reset button is can someone help
May 19, 2010 | Microwave Ovens
My Panasonic nn-s262 microwave/fan keeps reseting every time I try to use the microwave. The fan works fine and the light worked fine until today, it now resets the microwave. What can it be?
internal short that can damage your control panel but do not try to fix it yourself its got 4000v !!! sorry :( your life worth more then this microwave.
Dec 30, 2009 | Panasonic NN-S262SF Microwave Oven
Microwave Ovens Logo
13 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
