What does an f01 mean on a whirlpool front load washer machine?
2 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
Error code f01
all I can say to that is if you arrange the bath rugs in a balanced way so they are equally distributed then the problem should go away eric
Dec 29, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Error f01 flashing on machine
F01 on a Washer Dryer means you have a motor fault.
I suggest check the motor and associated wiring. You may just have a broken wire.
Hope this helps.
Oct 08, 2011 | Hotpoint Aquarius WD640 Front Load...
We have a F01 coming up on our machine. Any ideas.
The "F01" error code is indicating a communication error between the Central Control Unit (CCU) and the EEPROM on board the CCU occurred.
Generally in order to correct this failure the CCU board will need to be replaced.
Jan 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What is f01
Hi, off hand I don't recall the F01 code but if you take the lower front valance off the machine (three screws at the bottom) there is a technicians chart of codes located in the machine in a packet glued to the right side. Good luck.
Dec 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door will not open,error code f01
Problem isnt solved, seems like several people are having the same problem with whirpool front load washer with the F01....sad nobody will help you, they want money.....as high priced as those machine are............dont buy whirlpool......
Oct 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer codes F01/F33, have cleaned the pump and
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jun 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't start. Error code f01 shows.
Hi F1 means your CCU is bad and needs to be replaced sorry :( If you have any other questions please feel free to comment again. Mike e63dqt.jpg
Nov 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WFW8400 WHIRLPOOL FRONT LOAD WASHER KEEPS FLASHING F01 ERROR CODE. HOW DO I CLEAR IT?
Un-plug the washer to reset the ccu. If still in error, open the top and check the connections of all the plugs going into the ccu. Post back on your findings.
Mar 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code
I could not find error f01 for maytag, but for for whirlpool, it means CCM(central control unit) unplug washer for 2 minutes then try it.
Jul 12, 2008 | Maytag EPICz Electric Dryer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
