Question about Rinnai Desa Vent-Free Infrared Gas Heater: Vent-Free Infrared Gas Heater(18,000 BTU)
Flame to high
When turning the the heater on ithe flame goes to high.
5 Suggested Answers
  • 2692 Answers
SOURCE: my 2520 water heater won't stay lit for just the shower all other
Replace thermocouple
Posted on Dec 31, 2008
Pnutgllry
  • 57 Answers
SOURCE: Toyo Laser 73 Flame goes out
You might have carbon build up in the heat pot, causing it to create a chain of carbon on the fuel rod. If the rod can not sense a flame the heater will turn off. A quick temporary solution is to give the fromt of the neat pot at the top where the flame rod is a tap to see if it loosens it. Start the heater up and see if it runs any longer. If it does, you need to have your heater cleaned, or clean it yourself. You might have a warped burner ring also.
Posted on Jan 05, 2009
  • 4 Answers
SOURCE: pilot lights but when ignition pops back up the flame goes out
will either be the unitrol control box or the thermocouple, when you push down you are holding two magnets together and waiting for a small charge to be created from the probe in the flame , if this is not working you have no charge and the magnets won;t stick to allow the valve to open, change the thermo and see if that works first, its way cheaper than a new controler
Posted on Feb 05, 2009
aquaman987
  • 927 Answers
SOURCE: Rinnai heater 403FT. The heater
I suggest you call for service. This "bang" could be a serious problem in the future - meaning the next time it tries to start.
Gary
Posted on Jul 04, 2011
How high should the flame be in a kerosine heater
Adjust wick till nice Blue Flame, if wick to High flame turns White/Yellow. Turn down wick till Nice Blue Colour
Jan 11, 2016 | Heating & Cooling
No Flame
It could be dirty nozzle or dirty line
Unscrew every thing in the nozzle and control valve section and clean gas line and reinstall and try it
Nov 18, 2013 | Fire Sense 60803 Patio Heater
I installed a Mr Heater 45,000btu heater in my garage, when I turn it on to fire, it fires for a moment, I get about a 3 inch flame for a moment and then it goes out. What do I need to do?
clean the flame sencor first check connections on flame sencor , check you have gas to heater check limits high and low jump then out one at a time see if it lights , or check pressure switch if fitted jump this out and check tubes to it
Jan 20, 2011 | Mr. Heater Natural Gas Garage Heater -...
Dyna glo tag along propane heater pilot stays on but when turning
sounds like either a bad thermocouple or more likely a pressure regulator problem. should have unit checked by someone familiar with propane systems.
Jan 13, 2010 | Dyna-Glo (PPH16-LP) Utility Heater
When it goes to the second and third stage on the dial to make it hotter the flame goes out. If you re-pilot it, it comes right bak on, but it will not stay on the higher settings.
there is a flame rod that looks like a thermocouple at one end of the burner. Pull it back away from the burner toward the front of the heater slightly.This will allow the heater to operate at higher temps without shutting off the gas to the burner. The high limit will still work but the sensor is in the flame to close and is getting to hot as the flames get higher
Jan 03, 2010 | Blue Flame Charmglow 30K BTU Propane Vent...
Rinnai heater flashes code 12
Bailey,
Next time you try your stove watch the flame. If the flame goes away and then the error code comes on, you have something wrong with the over temp circuit, gas or gas valve, If the code comes on and then the flame goes away you have a flame sensor problem.
Good luck,
Tom Hawkins
hawkins111@gci.net
Mar 13, 2009 | Rinnai Toyostove Direct Vent Heater:...
Pilot light lights
air gas mix racio to high on air.
Jan 03, 2009 | Endless Summer 153100 Open Flame Patio...
Heating & Cooling Logo
24 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
