Question about Brinkmann 80023010 QBeam Max Million III Spotlight
Brinkmann spotlight won't charge
Flashlight won't charge when plugged in. The LED light indicator doesn't come on either.
How can I fix my rechargeable portable spotlight/flashlight after no charge for 1(one) year?
I replaced the battery in mine(coleman powermate) for 10 bucks but you have to be careful in how you disassemble it and put it back together. Batteries sulfate after awhile like a car battery.
Dec 12, 2014 | Vector Camping, Backpacking & Hiking
The spotlight/flashlight battery may have failed as a result of being unused and not charged periodically.
How do you replace light in Peak rechargeable spotlight
Sorry I don't know how to change the lights, but I need to know the charger volts and mA. Could you look at your charger and let me know please? ian 83877 at gmail
Jan 18, 2014 | Peak Performance Rechargeable Led Lamp...
My q beam work for one night then quit working checked fuse in power cord and bulb. I have another rechargeable q beam bulb is good battery is good but dosen't work any ideas
trigger messed up..i had to take mine apart and actualy push the little black button so i could see, it sounded like it was clicking but it was the only thing left to check and it was sure enough the problem....very cheap made lights
Aug 02, 2011 | Brinkmann 800-5000-0 Q-Beam LED...
Cyclops spotlight wont charge
It is indicating that your battery needs to be replaced, it will not hold a charge.
Oct 23, 2009 | Camping, Backpacking & Hiking
I am looking for the AC adapter?
Try a radio shack or electronics store. Take the light with you to insure you get the correct charger
Jul 16, 2009 | Vector Power On Board High Intensity...
CHARGED THE BATTERY AS INSTRUCTED, UNIT DOES NOT WORK
check the factory date.. the batt might be bad due to time, check the polarity conexion to the batt might inverse. i suggest u try another batt..
Mar 15, 2009 | Black & Decker Black And Decker 2 Million...
My Vector Vec157 Flashlight won't Charge...
It is the battery, I have a similiar Vector light for a few years and tried re-charging the battery but only the little LED light would come on. I have another Vector light, same model and switched batteries from the worjking one to the non-working one and now it works fine.
I then proceeded to purchase a new battery for the non'working one and when I arrived home I installed it and turned on the main light, still won't turn on, I tried the LED's, they work. I figured maybe the new battery needs a good charge so I plugged the charger in and charged the light for 12 hours, still no main light.
I guess the new battery is defective, so now I will return it and exchange it for another one.
Aug 22, 2008 | Vector 20 Million Power Series Spotlight
Brinkmann 80023010 QBeam Max Million III Spotlight Logo
299 people viewed this question
Top Brinkmann Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Brinkmann Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
