Question about Dyna-Glo (PPH16-LP) Utility Heater
Workhorse kerosene heater how do u set the gap on spark plug
2 Suggested Answers
SOURCE: E 1 error on Dyna-Glo Workhorse Kerosene Turbo Heater
Take the top off of the heater and and clean the nozzel orifice, while you have it apart wipe off the photo cell and clean and regap spark plug. The nozzel unscews and you can clean it with a bread tie.
After this clean or change the fuel filter in the tank, and finally check the pump pressure and make sure it is inline with the owner manual. This is assuming that it is firing to begin with
Posted on Feb 09, 2009
How do i bypass the themstat on a workhorse heater
As you should know thermostat is for safety and it is not good idea to by pass it ,not recommended
Feb 04, 2015 | All-Pro Kerosene Garage Shop Heaters - All...
Tip
Forced Air Kerosene Space Heater Spark plug
I have an older COOP 50,000 BTU forced air kerosene heater. I tried burning #2 in it. Result was rapid fouling of the spark plug. I removed the ground electrode from the plug allowing the spark to jump to the shell. It has never fouled the plug again, runs perfect.
on Nov 27, 2008 | All-Pro Forced Air Kerosene Space Heater...
My rem50 does not have spark
Check the ignitor circuit. Check also your ignitor spark gap making sure it is not too far or shorted.
Jan 20, 2014 | Reddy Heater 60,000 BTU Kerosene...
All Pro Kerosene SPC-K50 runs intermittenly
This type of heater can be temperamental because they are often stored for long periods in unsuitable conditions, aren't serviced very often and the remnants of fuel are left inside the tank during storage.
Kerosene has a fairly high natural water content, the tank is vented and normal air pressure changes will allow further moisture and dirt to enter the heater.
Good heater operation depends on very clean and uncontaminated fuel. Tiny dirt particles and contaminants can corrode, wear or jam the spinning spray head.
I suggest you service the heater - a thorough internal clean of the fuel system, clean the filter(s) and spray head, check and if necessary adjust the air pump regulator pressure and ensure the spark plug is clean, in good condition, is correctly gapped and the spark is constant and steady.
Your heater should then be ready for the coming winter season at the end of which, perhaps different summer storage arrangements would be advisable.
Oct 25, 2017 | Heating & Cooling
Heater blows smoke out front, wont ignite...please help!
Two things cause it ,No fire at Spark plug or low air pressure
Jan 22, 2011 | Reddy Kerosene Heater with Thermostat:...
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
R155 and unburnt Kerosene
Check plug gap and depth of the tip. The spark may be to far into the fuel spray flooding it out. DESA says use a standard spark plug washer or two for shims if needed.
Jan 30, 2008 | Reddy R155D Utility Heater
Dyna-Glo (PPH16-LP) Utility Heater Logo
32 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
