Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Whirlpool HE4t front load washer problem
My washer is blinking and beeping dL F at me.  I pout in a moderate sized load and did not over fill with detergent.  Have tried running plain water hrough the detergent recepticle. Still beeping and blinking and not washing.  Machine is smarter than I am -- how do I get it operational?
  • 290 Answers
Re: Whirlpool HE4t front load washer problem
The dl means doorlock. These machines are notorious for bad solder joints in the main control board in the door lock circuit. You could have a bad door latch but I doubt it.
You can keep trying to start it and sometimes it will work and sometimes not.
Remove the top of the washer. It is held on by three screws at the rear of the top. Slide back and lift up.
You will see the control at the top rear of machine. There are two connectors that plug to the board with pink wires. The board will be marked dl1 and dl2 where they plug in. Wiggle these connectors and try the machine again.
If your machine is less then 2 years old the board may still be covered by warranty. Check your owners manual for details.
Post back and let me know what happens.
Posted on Oct 27, 2007
Thanks for the tip, washing machine is up ans running.
Posted on Nov 21, 2007
0 characters
3 Points
Whash machine
The symptoms are pretty specific for the F11 code on the Whirlpool Duet front loaders and clones (Kenmore Elite and KitchenAid):
If the washer starts to fill but the drum NEVER moves, your MCU is bad
If the washer runs through most of a cycle and then gives the F11 before (or during) a rinse or spin cycle, then you have the CCU relay problem.
If you are interested in having me repair your CCU for you, I offer that service on eBay (website coming soon). My username there is "jhagner"
Feb 04, 2014 | Kenmore HE4t 3.8 Cu. Ft. King Size...
How do you reverse the front door on a Kenmore HE4t washer?
The Kenmore HE4T washer does not have a reversible door. The matching dryer would have a reversible door.
Some newer washers do have a reversible door but it is still a very small number of washer that allow you to reverse the door.
You can not reverse the door on an HE4T washer.
Aug 21, 2011 | Kenmore HE4t 3.8 Cu. Ft. King Size...
The washer beeps and flases f dl
it probably flashes also correct that problem , you must replace CCU board (upper board) and latch assembly...
F11: CCU board
FDL: latch problem
Jul 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error message of f dl on kenmore washer model he 4t
does your washer stop on spin cycle some time. your is 4/5 years old?. f dl means door lock system is bad but i don't think so. do you have other error code beside f dl if yes then i think your washer need new main control board.
May 24, 2009 | Kenmore HE4t 3.8 Cu. Ft. King Size...
DL-F code on HE4t washing machine
Google your washer by model and google the code list. It could be something as simple as the drain is clogged. We had the same problem. It was a simple fix.
Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE4t stopping in mid cycle with F abd DL errors
See Phoebe 112 latest solution! This is a common problem with these washers. For a quick fix you can usually get it going again by unplugging it for 30 mins. so the computer will reset. You will hear a slight buzzing noise when it resets. If it keeps doing it, go to the comment for Feb. 14, 2009 and try that if you are handy. Unplug the machine before doing any of this as with any machine that is electric or you will probably get the shock of your life.
Feb 14, 2009 | Kenmore Elite 45986 Front Load Washer
Sears kenmore elite he4t
Shaking is caused by poor distribution of clothes causing an imbalance. Try the machine empty. If it works well, be aware that you'll have to redistribute your load to stop the shakes.
Dec 31, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
268 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
