Question about Dyna-Glo (PPH16-LP) Utility Heater
I have a workhorse kerosene heater it starts and heats and than later stops won't stay running
3 Suggested Answers
SOURCE: E 1 error on Dyna-Glo Workhorse Kerosene Turbo Heater
Take the top off of the heater and and clean the nozzel orifice, while you have it apart wipe off the photo cell and clean and regap spark plug. The nozzel unscews and you can clean it with a bread tie.
After this clean or change the fuel filter in the tank, and finally check the pump pressure and make sure it is inline with the owner manual. This is assuming that it is firing to begin with
Posted on Feb 09, 2009
roniecon
  • 6826 Answers
SOURCE: i have a dyno glo work horse kerosene heater modle
If it is a gas,thermo type heater,then the thermocouple is bad.Check and make sure the pilot lite flame is touching the tip of the thermocouple,if it is not,adjust it,to where it will.If it is not adjustable,replace the thermocouple.
Posted on Jan 15, 2010
My kerosene heater wont stay lit.
Wick is corroded real bad. Unless you can do the cleaning cycle your only recourse is to replace the wick with a new one.
Feb 04, 2017 | Heating & Cooling
How do i bypass the themstat on a workhorse heater
As you should know thermostat is for safety and it is not good idea to by pass it ,not recommended
Feb 04, 2015 | All-Pro Kerosene Garage Shop Heaters - All...
Kerosene garage heater (Desco) fan starts, burst of kerosene, and the heating element is red. Within a few seconds, heater stops abruptly. Email address: p.s.stohr@sbcglobal.net Thanks for your help.
Remove the top from the heater and clean the flame sensor. It should be the photo eye type. Remove it from it hold and clean inside with soft cloth or cotton swab with alcohol. If this doesn't help, let me know what you find. nitensheaterservice@earthlink.net
Jan 11, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Heater used once 3 yrs ago. Now wont start.
When the heater hums is the fan turning. If it is I would add more Kerosene. There is no shut off but the Kerosene is sucked out a tube from the top of the tank. This tube does not reach quite all the way to the bottom of the tank. Your heater should hold about 9 gallons if it is empty. A couple of gallons would give it plenty to run though. Let me know.
Jan 02, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
MY KEROSENE HEATER STARTS, RUNS MAYBE 5 MINUTES THEN SHUTS OFF
Same problem I had and it was the CAD/flmae sensor. you can get one that will fit from Mr. Heater for 3 bucks or from reddypats.com for 18. the wires are a different color but all you do is clip them and splice them to your old wire harness. It does''nt matter how you hook them as there is no hot and ground just a complete circuit.
Jan 27, 2009 | Reddy Heater-30-55,000 BTU Variable
Heater runs hot for a few minutes then stops heating
I would say from what you have described your problem is a bad thermostat heat sensor (you may have to replace the whole thermostat on this model!) This is a very common problem for this unit!
Please rate my sesponse!
THANK YOU
Jan 14, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Blows cloud of smoke
thin your fuel mix with about a gallon of kerosene to 5 gallon of heating oil.could also be a semi clogged fuel line filter.
Nov 21, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Dyna-Glo (PPH16-LP) Utility Heater Logo
27 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
drifterray
Level 1 Expert
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
