Question about GE WHSE5240D ENERGY STAR Super Plus 3.2 cu. ft. Capacity Washer
Washing machine squeals loudly at end of spin cycle
  • 1294 Answers
SOURCE: GE Washing machine won't spin in rinse cycle
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Posted on Sep 12, 2007
SOURCE: GE Front Loading Washing Machine seems to be holding water....
manual
Posted on Mar 21, 2008
SOURCE: Washing Machine Will not Spin
Every one needs to know that the expensive parts are under warranty for ten years the outer drum front and rear, the pulley, the inner drum.  GE sent me all four parts retail value 1200.00 on their web site, got them today.  Before I under take this project I am wondering if any one know if the drum seal the giant O ring ( the one between the two halves) should be replaced or can the old one be used?
Posted on Apr 17, 2008
CRTN
  • 716 Answers
SOURCE: Not spinning
Sounds Like Its The Belt Open Up The Unit Get The Broken Belt And Take It To The Auto Parts Store And Have Them Give You One Of The Equal Length.
Posted on Jan 15, 2009
  • 106 Answers
SOURCE: Loud banging noise durning washing machine spin cycles.
First plug off the wall. Open the machine from behind to examine if any shock-absorbers(known as dampers) or springs have come off or broken. Your dealer could help with spares. But you could do the job yourself.
For spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Posted on Mar 02, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Washing machine began squealing like a bad bearing
my first thought is belts, but maybe pump
need more info for proper dianosis
Apr 24, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washer squeals at end of spin cycle
The manufacturer recommends you tilt back the washer and spray some penetrating oil into and around the brake package to stop the squeal.
Jan 18, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Makes loud squeal noise when stoping to change cycles
when in spin out cycle when first comes on makin a noise like something is in the pump i check it and the pump is clear must be maybe lower bearing assembly sounds like something is lose or broke it also stops instancely at end of cycle what could this be
Jan 12, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My washer make a loud squeal when the spin cyle is done
new brake assembly. please post your model number for further help TY
Mar 29, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Feb 23, 2008 | Washing Machines
Squealing noise during spin cycle
The spin cycle activates the fast mode on the motor, squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
Jul 08, 2007 | Whirlpool LSB6200KQ Top Load Washer
GE WHSE5240D ENERGY STAR Super Plus 3.2 cu. ft. Capacity Washer Logo
20 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
