Question about Brother Wireless Color Laser MFC-9340CDW All-In-One MFC9340CDW
My Brother printer is squealing
Once my toner cartridges got low, my printer started squealing during the print process. I've replaced all but one of the cartridges and it's still doing it. Is this a low toner warning and if so, when does it start?
jaylex
  • 417 Answers
SOURCE: Toner life end
There is no reset code the likely thing is that you have a faulty toner cartridge. Put another new one in and check the machine then.
Before you try the above shake the toner cartridge and tap it some more as it may also be the toner inside have become solid and needs breaking up.
Hope one of the above works for you
Thanks J
Posted on Jan 08, 2008
  • 120 Answers
SOURCE: Brother 2820
The toner cartridge is in the drum unit. push the blue lever and the toner pops out, make sure you have a toner cartridge in the drum unit. Lawrence
Posted on Apr 23, 2008
  • 52 Answers
SOURCE: Brother HL2040 - Shading of toner all over my page when I print
The drum is a very sensitive part. Should not touch with bare hand, expose to light for long, etc. With what did you clean,it.
Posted on May 19, 2009
  • 133 Answers
SOURCE: Brother HL 2040 toner light flashing
Push the start buttom and hold for 30 sec.
Posted on May 23, 2009
greg_margo
  • 1959 Answers
SOURCE: "Toner Low" keeps showing
Hi Meridy!
There could be a few reasons for the Toner Low msg you're getting.
  1. The toner wasn't evenly distributed when the cartridge was changed (shake gently from side to side before installing)
  2. The cartridge wasn't properly installed (ensure that the lock lever "clicked" into place
  3. The corona wire wasn't cleaned when changing the cartridge or the the blue tab wasn't put back in place (this is less likely the issue but still a possibility)
  4. The new toner cartridge was old and is now defective
I hope this helps with your problem. All the best!
Greg
Posted on Jun 17, 2009
Hello - my Lexmark E120 will print a test page, but won't print anything that I send to it. I just get an error message. There is a green light next to the 'lightbulb' on the printer. The...
The light next to the lightbulb on the printer Toner low/replace PC kit. The printer is ready to receive and process data. In addition, the toner in the toner cartridge is getting low.
Solution:
? Press continue button to clear message and continue processing job.
? Remove the toner cartridge. Gently shake the toner cartridge from side to side and front to back several times to redistribute the toner, and reinsert it. Repeat this procedure multiple times. If the print remains faded, replace the toner cartridge.
For further assistance, please contact Lexmark Technical Support
Sep 12, 2011 | Lexmark E120n Laser Printer
Brother HL 3070CW says the toner is low and won't print. It has toner and I have to get something printed for a client
I done on my brother lh3070cw printer cartridge on Message "Low Toner"
First I take off toner cartridge
second - Covered the both Glass Buttons of Cartridge situated right and left side of cartridge (all cartrideg) for Black Electric Tape.
thent install the cartridge in the printer again.
after install the cartridge press SECURE PRINT AND CANCEL BUTTON SAME TIME AND CLEAR THE STR AND STD FOR PRESSING ok BUTTON FOR 2 TIME.
ERASE EACH STR AND STD
THEN PRESS CANCEL
YOU CAN USE YOUR PRINTER FOR END OF THE TONER
Mar 28, 2011 | Brother MFC-9440CN Laser Printer
Brother hl2142 printing copies out which look faded
The toner could be low.
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Mar 10, 2011 | Brother Office Equipment & Supplies
How to change toner cartridge TN330
Hello
Once you have the correct Brother Toner for your printer model, power your printer OFF and open the cartridge box.
Next, you need to open the top cover of the printer. You should do this carefully to prevent damage to the interior or exterior of the printer.
Once the printer top cover is removed, you want to extract the empty Brother Toner cartridge from the printer by pulling upward and away from the machine. You should be able to do this without a great amount of force.
After you've taken the Brother Toner cartridge from the printer, you want to prepare the new cartridge for insertion. To do this, you need to remove it from the plastic bag it is contained in. Next, you need to remove the rip strip from the cartridge. The rip strip is attached to a plastic film strip. Removing the rip strip is important because if you don't your printer will only produce blank sheets. Take care when ripping the strip off, as you may get Brother Toner on your clothes which can stain. If you end up spilling toner on yourself you can wash it off with cold water.
Next, you want to place the new cartridge in the printer the same way the old Brother Toner cartridge came out. There will most likely be arrows on the package to guide you in the placement that will help you make sure you're putting it in correctly. Much like removing the used Brother Toner cartridge, it should slide in with minimal force. If it doesn't slide in easily you should make sure that the Brother Toner cartridge is the correct cartridge for your model printer and then make sure that it is aligned correctly.
Once you have the cartridge in the printer properly, put the printer lid back on.
Now you are going to print a few test pages to make sure that everything is working the way it should. If the printouts look good: You are done. Package the old toner cartridge in the box the new toner came in and recycle it. If the printouts look bad: Sometimes cartridges can be defective. If there were problems with your test pages, you may need to try the process again with another toner cartridge.
Jan 17, 2011 | Brother Office Equipment & Supplies
I have a Brother MFC-7440N machine. On 7/22/10
The toner cartridges have a small port on the side that the printer uses to check the toner level. Our 7440N tells us it will soon need a new toner cartridge and will then print another 400 copies. Search YouTube for Brother Toner Cartridge and it will show you how to modify the cartridge by covering up the portholes with tape. Since there is obviously some kind of sensor, you might need to get a can of air and clean out any extra toner. Lastly, the Brother cartridges have "reset gears" which are replaced when the cartridges are refilled. You might have a cartridge which the gears were not replaced on.
Jul 26, 2010 | Brother MFC-7440N Laser Printer
Hl-2140 noises
For a possible fix to the Brother HL-2140 squeal/squeak/noise problem open the printer at the other side from the paper tray and toner cartridge door. You should see a little black roller rod along with some white wheels.
The noise may be coming from the contact between the wheels/rollers which pull paper toward the output tray on top after it has been printed.
Check and clean/wipe the wheels and black rod, especially in the center area. Hopefully the noise will now be reduced/eliminated.
Cheers, Stephen
Sep 14, 2009 | Brother HL 2140 Laser Printer
Received "Low Toner" message. Replaced toner with new Brother cartridge still have "low Toner" meaasge and [printer will not print.
Please check if you removed the Plastic Tapes which is placed in the side lock of the new Toner Cartridge.
Apr 24, 2009 | Office Equipment & Supplies
Printer catridge
If you just want to REPLACE the toner cartridge, open the front door and jiggle the combined toner & drum units out. push down on a blue tab on the side to release the TN-350 toner cartridge and lift it out of the DR-350 drum cartridge. If you have the toner cartridge out and want to refill it you7rself, DON'T. You can buy toner with about the right size grains, but Brother uses toner with grains that are much smoother and rounder than that aftermarket stuff. The toner is constantly stirred during the print process, and the rough-grained aftermarket toner puts up so much resistance that it often breaks a gear in the body of your MFC. Brother usually doesn't cover that one in their warranty.
Feb 05, 2009 | Brother MFC-7820N Laser Printer
Brother HL-1440
(blinking every 5 seconds) Toner Low Indicates that the toner cartridge is nearly empty. Purchase a new toner and have it ready for when Toner Empty is indicated. (solid) Toner Empty Replace the toner cartridge with a new one. User's Manual is available at the following location: http://www.brother-usa.com/Data/Documentation/Printer/User/UM_HL1440_1450_1470N.pdf Hope this helps.
Aug 22, 2007 | Brother HL 1440 Laser Printer
Brother Wireless Color Laser MFC-9340CDW All-In-One MFC9340CDW Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
