Question about Samsung CLP-610ND + Demo Laser Printer
How to disable mp tray - Samsung CLP-610ND + Demo Laser Printer
How do I clear a scanner jam for a MFC 8480
Hi Judy,
Please follow the steps posted below:
1. Remove the paper from the MP tray
2. Remove any jammed paper from in and
around the MP tray
3. Close the MP tray. Then open the front
cover and close it to reset the machine.
4. Open the MP tray again
5. Fan the paper stack, and then put it back
in the MP tray
6. When loading paper in the MP tray,
make sure that the paper stays under
the maximum paper height guides on
both sides of the tray
Let me know if this resolves the issue,
Thanks,
Hunter Quinn
IBM Help Desk
Dec 04, 2014 | Brother MFC Office Equipment & Supplies
My Brother HL 4040cn showes a Jam MP Tray. There are no papers jambed but it will not reset.
Hi James,
Remove the paper from the MP tray.
Remove any jammed paper from in and around the MP tray.
Fan the paper stack, and then put it back in the MP tray.
When loading paper in the MP tray, make sure that the paper stays under the maximum paper height guides (1) on both sides of the tray.
Press Black (Mono) Start or Color (Colour) Start to resume printing.
Still having Problem Then follow Us For
Brother Printer Support
Feb 20, 2014 | Brother HL-4040CN Laser Printer
Manual feed isnt working. once tray 1 is open i thought it would automatically know i want to use manual feed.
Not necesarily so, it depends on how you have the printer configured. To test the MP tray, use the arrow keys to get to troubleshooting menu, press check, use arrow keys to get to paper path test, press check, set tray option to tray 1, then print test page. Printer should feed from MP tray. If it does, then the problem is that you do not have the printer set to print from MP tray first or you have the tray options set to exclusive which means that if your print job asks for tray 2 then printer will not print from MP tray unless you specify MP tray in the print options.
Mar 18, 2011 | HP LaserJet P4015 Printer
My lexmark X832e is asking to chnage MP Feeder Folio. What should I do.
If you disable the MP feature in settings that'll fix it or change the print priority to tray 1.
Dec 03, 2010 | Lexmark T642 Laser Printer
Won't print: message change MP feeder plain folio
Sep 15, 2010 | Lexmark T520 Laser Printer
My OKI C5500 will only print from the MP tray, and will not take paper from the bottom paper tray, even though there is plenty of paper in the bottom tray. Its giving me a 490 Error message, but I do NOT...
490 error means -
LOAD mmm AND PRESS ONLINE SWITCH 490: MP TRAY EMPTY
Print job from MP Tray has been received and the MP Tray is empty.
Load the requested media (mmm) in the MP Tray and press ON-LINE.
Check your print driver settings and see if your defualt try is set for the MP Tray. Also see if the page setup for the print job is set for MP tray.
Feb 17, 2010 | OKI C5500n Printer
Can this printer automatically choose the paper tray i.e. if the MP tray is open will it choose that instead of the cassette?
MP tray needs to be set on FIRST*
When paper is in MP tray, thats where the printer will automatically take it from. When there is no paper in the MP tray, or it is closed, the printer will take from the cassette.
Apr 09, 2009 | HP LaserJet 4 plus Printer
Fs-1030d even when set tray1 as source will print from mp feeder if paper in it
If paper in mp tray it can print mp tray only,
There is no option to chane the settings.
Oct 14, 2008 | Kyocera Office Equipment & Supplies
Printer message "paper empty custom in MP"
Its asking for you to put some paper in the tray at the side of the printer. There is a small hatch on the right hand side which will turn in to a paper tray when pulled open. Put in the paper and it will print. You will then have to disable that tray to prevent it happening again.
Jul 02, 2008 | Samsung CLP-500 Laser Printer
Samsung CLP-610ND + Demo Laser Printer Logo
32 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
