Question about Canon PIXMA iP3000 InkJet Photo Printer
Certain colors not printing - Canon PIXMA iP3000 InkJet Photo Printer
I am trying to print something in color using my canon pixma mp640. i have made sure all of my ink levels are good and that my setting on both the computer and printer are set to color. but it is only...
If you are certain that your printer online properties indicates color printing and you can get 'test print' in color (via Printer properties or Printer built-in menu), I would first check that your application is not overriding the default settings (e.g. such as proof/draft mode printing in mono or B&W) or try another application.
If no applications won't print in colors, I would try to re-install the Printer Drivers specific to your windows version.
Sep 21, 2011 | Canon Office Equipment & Supplies
I would like to use the black ink only for certain jobs and not have the color printing
It is not a mono laser. Color laser no matter if you print only black it will still pull some small percentage of other color to mix. if some of your color toner is already 0% it will not allow you to print unless you replace the tomer.
Apr 09, 2010 | Samsung CLP 300 Laser Printer
Printer printing out wrong color. i have cleaned the cartridges several times, checked to make certain tape is off. How do I configure the printer to allow me to have access to the printer service to...
Print a test page. if that is ok, then it could be the color profile you have selected. Also, you can make your own test pattern of Yellow, magenta, and cyan. (use mspaint and make 3 colored bars, a black bar, and a white background). Print that, and see if all 3 colors and black are printing. If one color is not printing (ie, yellow for example) then there is an issue with that printer head on that cartridge. If you are recycling the carts, then that cart needs replaced.
Aug 28, 2009 | HP Photosmart C3180 All-In-One InkJet...
My color ink was low so I changed the ink but when I print it shows low ink on color and from certain programs(word) it prints fine in color and from other programs(windows photo viewer) it comes out very...
have you changed the print quality? some programs have different print quality settings if you change it to a universal setting like automatic it should be the same. also some programs print lighter to save on ink!
Jul 09, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Certain color parts previewed on computer don't print out
Depending on the software you are using to do the preview...( a word processor, photo software ..etc) the preview is just that...it simply lets you look at the document or picture to see that you have formated it correctly in the main program. You should not try to print from the preview...what you can do is exit the preview function and return to the main software. the go to the file menu and exicute the print command and or do the page setup for the picture or document.
May 31, 2009 | Office Equipment & Supplies
Printer doesn't print exact copy of picture should be in color.
Is the setting on the print driver set to color? If so, often times you can't print certain imaged from the web as you see them, It is copyright protection. So it may not be possible to reproduce is as seen.
Jan 31, 2009 | Office Equipment & Supplies
Printing without color
Each cartridge must have a certain amount of ink for the machine to run, even though you only want to print in black and white. Hope this helps.
Nov 13, 2007 | HP PSC 750 All-In-One InkJet Printer
Black will not print
This may seem obvious but have you tried cleaning and refreshing the print heads? I've had a similar problem with only certain colors and the cleaning seemed to help.
Nov 06, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA iP3000 InkJet Photo Printer Logo
13 people viewed this question
old marine
old marine
