Question about AKG K267 Tiesto Headphone 3285H00010
I have a akg k267 headphone but i broke the left ear side from the headband can i replace a headband
How can i replace the headband
5 Suggested Answers
SOURCE: AKG K240S headphones not working well.
A buzz in one ear and no sound in the other 'sounds' like an open connection inside the headphones. The K240-series uses three wires from the pin to the headphones. Try this link to get wiring schematics and disassembly details: http://www.akg.com/site/powerslave,id,7,nodeid,7,_language,EN,cat,11.html
DHE 2008
Posted on Apr 25, 2008
Grubhead
  • 5056 Answers
SOURCE: Right speaker is not operating on a set of AKG headphones.
Go in by the part that fits to your ear. You will need to remove the ear pad. Also the foam, you might have to force the foam off, you can glue it back when done. With them gone you should see access screws.
Posted on Feb 17, 2010
SOURCE: Hallo! I have been using AKG IP 1 ( i have own
If you have an account on ebay.com,you can purchase it online. so goto www.ebay.com thanks
Posted on Oct 26, 2010
SOURCE: i need to replace the cable for my AKG 450
Just buy a new one, I got mine from here:
http://www.proaleo.com/replacement-upgrade-headphone-cable-for-akg-k450-k480-q460.html#
http://www.proaleo.com/replacement-upgrade-headphone-cable-with-mirco-for-akg-k450-k480-q460.html#
the cheapest I could find with international shipping,hope it helps.
Cheers.
Posted on Dec 30, 2011
Headset earpiece assembly has become detached from headband assembly. The post does not want to go back into the hole on the earpiece assembly bracket. What do I do?
The headband post can only be inserted into the earpiece when the earpiece has been sufficiently rotated. (Note that the hole and post are a 'D' shape, not round.) The installed ear cushion is preventing you from rotating the earpiece sufficiently.
Remove the ear cushion from the earpiece by carefully pulling it off so you do not damage the clips that hold it on or the gasket material between the cushion and the earpiece. There are six clips, three on each side.
Now you can rotate the earpiece into the position where the headband post can be inserted into the earpiece.
Carefully reinstall the ear cushion by pressing it onto the plastic clips. Note that it can only be installed one way with the internal plastic support towards the headband.
Oct 01, 2013 | Bose QuietComfort 3 Acoustic Noise...
Broken headband
You can try to strip a little bit of the jacket off the wires and twist them together securely. Then use a little bit of electrical tape to wrap the bare wire. After, you can tape the head piece back together...... or you could buy some new headphones.
May 24, 2012 | AKG GHS1 Headset
How can i open my AKG k141 studio headphone to repair it ?
I had a problem with my AKG K141 Studio headset. The right side stopped working. Hard to believe but one of the leads to the ear speaker was disconneted from the solder lug. To disassemble, pry the gold AKG emblem using a jeweler's screw driver. You can pry it without damage by locating a small notch on the black plastic rim at the 6 o'clock position. Then unscrew ththe tiny phillips screw and remove black disc. You will see two leads (red and white) feeding through a hole. Disassemble removing a larger screw. This will give you accesss to the solder lugs.
Nov 30, 2010 | AKG K 240 Studio Professional Headphones
The left and right ear bud work some times. and if i turn the base were you plug it into the device it coukd work how can i fix it so they can both work at the same time.
Probably can't. What typically happens is that the base of the wire gets stressed from wrapping the cord around you media player and it eventually breaks the copper wire inside of the insulation. You likely can not even see the damage, let alone repair it. Be more carefull with the next set, and might I recommend a set of AKG ear buds. I use AKG studio headphones and bought my little sister some AKG ear buds, very impressive quality very close to my studio headphones. AKG K 313
Oct 29, 2010 | Skull Candy LINK Earbuds Consumer...
I got a skullcandy TI 1 year ago, and since two days the sound comes out normally, or without the left side, depending on the position of the wire connecting the MP3 to the skullcandy. It's very sensitive,...
What typically happens is that the base of the wire gets stressed from wrapping the cord around your media player and it eventually breaks the copper wire inside of the insulation. You likely can not even see the damage, let alone repair it. Be more careful with the next set, and might I recommend a set of AKG ear buds. I use AKG studio headphones and bought my little sister some AKG ear buds, very impressive quality very close to my studio headphones. AKG K 313
Oct 29, 2010 | Audio Players & Recorders
Feb 16, 2010 | AKG K 240 Studio Professional Headphones
How do you disassembly right side headset to fix faulty connection
The headphone unit is sealed and cannot be accessed via the padded ear pads. You have to prise open the outer headphone cover which breaks off 4 internal attachment points (which can be re glued for re assembly). Be careful on the Left hearphone as it contains a complex electronic circuit board.
Aug 01, 2009 | Jabra C820s Headphones
Need instructions for replacement of headband and ear cushions.
It should be easy - I just eased mine out by pulling on the top and bottom parts of the headphone cushion/pad.
Hope that helps
Mar 27, 2008 | Sennheiser HD 600 Consumer Headphones
DHE 2008
Jan 07, 2008 | AKG K 240 Studio Professional Headphones
AKG K267 Tiesto Headphone 3285H00010 Logo
93 people viewed this question
Top AKG Audio Players & Recorders Experts
Vito Vacirca Jr.
Ben Armstrong
Edward Carrington...
Level 1 Expert
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
