Question about Canon PIXMA MG3222 Wireless Inkjet Photo All-In-One Printer - Back to School Value Bundle
Print test page - Canon PIXMA MG3222 Wireless Inkjet Photo All-In-One Printer - Back to School Value Bundle
Hp Laserjet P2055d-Page Counts error
are you looking at the pages printed on the toner cart. print out the supplies page.
Jul 28, 2017 | HP Office Equipment & Supplies
How do I print a test page?
Print test page Windows Help To print a test page. Open Devices and Printers by clicking the Start button , and then, on the Start menu, clicking Devices and Printers. Right-click a printer, and then click Printer properties. On the General tab, click Print Test Page.
Dec 05, 2015 | Office Equipment & Supplies
How to print a test page on hp deskjet D1341. I just installed a new cartridge and can't get back to the page that tells me to print test page
Click on Start - printersand faxes - right click on your printer - click Properties and then click Print test page.
May 18, 2012 | HP Deskjet D1341 InkJet Printer
When printing, it keeps printing the test page first. How can it stop printing the test page??? thx
reset the printer by pressing the reset botton for atleast 5seconds. then it ask for printing the test page.............. and you have to print the test page completely... otherwise it will ask for printing the ttest page at every print......................
then switch off the printer and again on it..........
then you will see th\at the problems will be solved..................
thnx
Jun 22, 2011 | Epson Stylus Pro 4800 InkJet Printer
How do you print a test page from the control panel
1.
Open Printers and Faxes from the Start Menu
2.
Right-click the printer you want to test, and then click Properties.
3.
4.
Click OK if the test page printed correctly. If the test page did not print correctly, click Troubleshoot to open the Print Troubleshooter for help resolving the printing problem.
Feb 08, 2011 | HP Designjet 110plus nr InkJet Printer
I have an hp 3150 all in one printer. Every time I turn it on to print a document it prints a test page. I am out of color ink so it doesn't print the additional numbers and lines to align the printer. I...
I know your problem and i want to know that have you changed or refill your cartridge?.
if yes
place one plain paper in the tray.
it will print the test paper
print it and place it on the scanner with the printed side down.
press the scan button from the printer
printer will blink the light for some time and stop blinking
now it didn't print test print every time you print
thanks
Jun 26, 2010 | HP PSC 1315 All-In-One InkJet Printer
How to print configuration page hp officejet g55
Printing a self-test page Method one: Print a self-test page from the All-in-One control panel
  1. Press the Menu button.
  2. Press 3 or use the arrow keys to scroll to Print Report , and then press the Enter button.
  3. Press 5 or use the arrow keys to scroll to Print Report , and then press the Enter button. The self-test page prints.
Method two: Print a self-test page from the computer
  1. Click Start and click Printers and Faxes .
  2. Right-click the appropriate product, and then click Properties .
  3. Click Print Test Page . The self-test page prints.
Oct 22, 2009 | HP OfficeJet G55 All-In-One InkJet Printer
Printing multiple test pages
Check for a sticking button on the printer itself. The big Green button will produce a test print if pushed. Also try disconnecting it from the wall outlet overnight to reset it.
Jul 27, 2017 | HP LaserJet 1320 Printer
Test Page
thats not the test page that is allignment page which is printing.
keep the the printed side of that page which comes out on the scanner glass.press the ---scan ---button.the on /off light will blink, wait till it stops blinking.and after that everything will be normal.
for any thing else let me know.
thanks.
Sep 17, 2008 | HP LaserJet 1200n Printer
Canon BJC 4300 InkJet Printer
i assume the cleaning method that you perform is offline (taking the cartridge our and clean them). I suggest you clean the head during the printer on.. try to perform below steps per the manual Cleaning the printer Printing the test pages Cleaning the print head I assume you do not have the manual anymore (no DVD) i list down the step below Its a bit long manual I suggest you download them from the canon website.. if you still have problem I can send to you the BJC 4300 manual Cleanning printer Make sure the printer is turned off before cleaning it. It is a good idea to unplug the AC adapter also. Do not clean the exterior of the printer with volatile liquids such as thinners, benzine, or any spray-type or chemical cleaners; doing so will damage the surface of the printer. When cleaning the printer, avoid the area near the print head on the BJ cartridge. Do not touch the print head. Ink may leak out and cause stains. Clean the printer regularly to avoid printing problems. Remove any ink mist or paper debris from the interior of the printer using a soft cloth moistened with water. Clean especially well around the platen area. If the rollers become dirty, you can clean them using a small soft brush. Clean the exterior of the printer with a soft cloth moistened with water. Clean away smudges and dust. Do not use paper products (such as paper towels or tissues) to clean the inside of the printer. Printing the Test Pages You can print these test pages to check the operation of your printer and your print quality. Test A This test prints a repeating pattern of characters. Demonstration This test prints a sample page describing the printer's features. Printing the Test Page From Windows You use the Test option on the Control tab in your BJC-4300 Printer Driver for Windows to print a self test, demonstration page, or a nozzle test pattern. Before selecting a Test option, make sure paper is properly loaded in the sheet feeder (see Automatically Feeding Paper starting on page 3-7). Click on the Test option and then click on the Print button. Printing the Test Pages Using the Operators Panel To print a test page, make sure the printer is turned off and paper is loaded. Press and hold the POWER button until you hear the number of beeps that correspond to the test page you want to print. Test Page Number of Beeps Pages Printed Demonstration 1 Continuous Printing Status Information 2 1 Page Test A 3 Continuous Printing Nozzle Test 4 1 Page When you release the POWER button, the test page starts to print. *All self-test prints require Letter or A4 size paper. Using a smallersize paper for a self-test print will result in parts of the printoutbeing printed directly on the platen. All self-test prints are printed in accordance with the current printing settings (font, printing mode, etc.) *Red- Information for technician not included in the user manual Cleaning the Print Head Your printer is equipped with a print head cleaning function to ensure constant high quality printing. Cleaning the Print Head From Windows If you are using Windows, you can execute print head cleaning from the Control sheet in the printer driver. Simply click on Clean Ink Head. 4300 Chapter 4 Page 6 Cleaning the Print Head Using the Operators Panel If you want to clean the print head from the operator panel, follow these steps: 1 Make sure the printer is turned on. Make sure the green POWER light is on. 2 Press and hold the RESUME button for at least two seconds until the printer beeps twice. The POWER light will blink for several seconds while the print head is being cleaned. Perform the print head cleaning only when you encounter a print quality problem. Unnecessary and repetitious cleaning will waste ink. If you execute the print head cleaning while paper is manually loaded, the printer will eject the paper and then perform the cleaning. 4300 Chapter 4 Page 7
Aug 24, 2007 | Canon BJC 4300 InkJet Printer
Canon PIXMA MG3222 Wireless Inkjet Photo All-In-One Printer - Back to School Value Bundle Logo
62 people viewed this question
old marine
old marine
