Question about Dyna-Glo (PPH16-LP) Utility Heater
I have a workhorse heater12000btu
Workhorse 12000btu heater starts and heats for a short time than quits
4 Suggested Answers
SOURCE: E 1 error on Dyna-Glo Workhorse Kerosene Turbo Heater
Take the top off of the heater and and clean the nozzel orifice, while you have it apart wipe off the photo cell and clean and regap spark plug. The nozzel unscews and you can clean it with a bread tie.
After this clean or change the fuel filter in the tank, and finally check the pump pressure and make sure it is inline with the owner manual. This is assuming that it is firing to begin with
Posted on Feb 09, 2009
  • 67 Answers
SOURCE: I HAVE A WORKHORSE 65,000
Ken's Repair Ph 7403694798 or e-mail Kcox7@columbus.rr.com
Posted on Jan 19, 2011
  • 35 Answers
SOURCE: dyna glo workhorse heater
The most common problem is a lack of air pressure. Air pressure is supplied by a pump attached the the motor shaft. Dirty air filter elements can inhibit the intake of air. The pump may be dirty internally also...especially if the fan does not spin freely when flicked. The black tubes transfer the air pressure to the nozzle and they crack and leak after awhile. the fuel filter in the tank can become clogged and the black fuel-to-nozzle line can leak also. The flame sensor can be faulty or dirty if your unit starts okay but goes out after a few seconds. Observe the spray pattern, it should be a very fine vee spray pattern. A dirty nozzle can inhibit ignition. The ignitor should spark when the unit is first turned on and be positioned at the edge of the spray pattern. Most of these units have a circuit control board which lights with a green LED if power is on to the board. Failure to turn on the spark or the motor when power to the board is OK...means a bad board. Power can be checked at the black and white leads from line voltage to the spade on the board.
Posted on Dec 14, 2012
Why does engine not turn when turning key of Kia K2700 Workhorse?
possible flat battery.
check the voltage of battery
and tap the starter motor. if it fires up then the starter motor is
not working properly
Aug 09, 2016 | 2007 Kia K2700 Workhorse
Kia Workhorse does not start
Possible flat battery.
let me know how you get on
How do i bypass the themstat on a workhorse heater
As you should know thermostat is for safety and it is not good idea to by pass it ,not recommended
Feb 04, 2015 | All-Pro Kerosene Garage Shop Heaters - All...
HOW TO DO TIMMING FOR KIA K2700 WORKHORSE
ALIGN THE TIMING MARKS AS PER THE ATTACHED FOTO. on the gears there are timing marks.
Jun 21, 2014 | 2007 Kia K2700 Workhorse
Kia 2700 workhorse engine not running evenly at high revs or uphill travel
Fuel starvation. replace fuel filter first and at that time check fuel pump pressure. While under the hood clean injectors
Jun 18, 2014 | 2007 Kia K2700 Workhorse
Workhorse with GM 5.0L gas engine
Is the ignition switch position working?
Locate and check the fuel pump relay.
Most relay fail after 160,000 miles. It is rare but it could happen.
Jan 16, 2014 | 1990 Ford F350
Where is the clutch fluid reservoir on a kia workhorse
It is on the right side of the dash board and is visible with the door open inside the cab.
Oct 14, 2013 | 2007 Kia K2700 Workhorse
Ford courier 1.8 diesel van, blower works, but no heat comes into the van when heater turned on
ford courier workhorse ,great van ---right when engine is hot feel the hoses that run into the heater ,also it could be the heater core was leaking and someone has joined the hoses together .if the hoses are connected and they are hot then ,try removing them and then flushing the heater with a hose pipe
Nov 29, 2009 | 2000 Ford Escort
2002 Workhorse chassis RV hazard flasher doesn't work
I am looking for a locking gas cap for my 2005 Bounder 36Z. This motorhome has a Workhorse chassis. Can you help me locate the part number and a dealer near Newberg, Oregon?
Thank you.
Sharon Bladow
503 554-1281
Aug 14, 2008 | GMC R3500 Cars & Trucks
Dyna-Glo (PPH16-LP) Utility Heater Logo
19 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
drifterray
Level 1 Expert
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
