Question about Janome Memorycraft 6500P Computerized Sewing Machine
What does TD initial error mean?
I have a message "TD init error". What does that mean?
Good afternoon, My Brother sewing mach. has a error of f7 what does this mean. The model is Cs80
According to http://www.sewingmachinesplus.com/brother-sewing-machine-error-code-f7.php
the meaning and answers are as follows...
Q: What does F7 error message mean?
A: Speed VR disconnected
Q: How to fix F7 error message?
A: Unplug the sewing machine and reconnect any loose wires on the SSVR PCB assembly and the main PCB assembly. If the wiring connections are okay, replace the SSVR PCB assembly. If the problem persists, replace the main PCB assembly.
Jan 10, 2017 | Brother Sewing Machines
What does E2 mean?
Error Codes mean different things on different machine brands. It is an error message indicating your machine is malfunctioning. Usually your owner's manual will have a list of error codes in the Troubleshooting Section that describes the problem and suggested resolution. If not, then search the internet for your machine's:
Manufacturer + Model + error code E2
Nov 20, 2015 | Sewing Machines
What does the error message E005 & 004 mean
Hi there
regarding E005 , E004 at JUKI lock stitch machine means :
E004:
synchronizer lower position sensor failure ( please check if socket is connect secure or lose connect - please check belt tension if lose please made more tight for belt tension.
E005:
synchronizer upper position sensor failure ( please check if socket is connect secure or lose connect - please check belt tension if lose please made more tight for belt tension.
if still not solve please change synchronizer with new one.
BEST REGARDS
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Jan 04, 2014 | Juki DDL-8700
Janome MemoryCraft 6500. What does error message "BM init error" mean? What does it take to fix it?
That's an initiation error. I would call Janome direct and ask them.
Dec 02, 2012 | Sewing Machines
Hi Mr. Janome expert, My Janome Memory Craft 4900QC is showing error message E1.Unfortunately I lost the manual to identify the solution to this problem. Could you mind telling what this error means...
E1 means it out of order--something in the electronics is mess up--it needs to be serviced
by a service tech with the tools to check the electronics of the machine
Sep 13, 2011 | Janome Memory Craft 4900QC Mechanical...
Futura CE-200 Software fails to initialize on XP sp2
Maybe you should try to contact singer south africa and ask them whats wrong, my laptop did the excact same thing switch over to home pc and no problem ever again.
Mar 02, 2009 | Singer CE-200 Quantum Futura Computerized...
Janome Memorycraft 6500P Computerized Sewing Machine Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
