Question about Galaxy Radios DX-48T Base CB Radio
Am/fm receiver shuts down when i key the mic - Galaxy Radios DX-48T Base CB Radio
    Genius:
  • Galaxy Radios Master
  • 1,795 Answers
Final
Posted on Aug 11, 2014
Why is humming coming from speaker when mic is keyed?
this is strange as most times if a proper transmit key is depressed , then the radio switches from receive to transmit , the mfg know this would cause some great squeal from receiver /transmitting so close to a receiver so the part that is the receiver is muted to keep this from happening , id say there is some fault in the part that does this muting of receiver
Apr 13, 2016 | Radio Communications
Galaxy dx 44hp, no am audio or mod ,fm & pa ok
Have you tried another mic. First guess microphone wire broke or broke solder for audio wire in mic jack at mic cord.
Mar 26, 2014 | Galaxy Radios DX-44HP Mobile Amateur Radio
No transmit or recieve
sounds like a repair for a tech to me.
Jan 16, 2014 | Galaxy Radios SSB Echo Base Station CB...
Hi i want to restore factory settings my rxv 995
(input mode key)+ ((AM/FM key) lastly Press (power key)
When diag menu appears select 8
when sub menu appears select RESERVED
use tuning up/down at MAIN MENU and
program up/down to move for SUBMENU
Sep 13, 2013 | Yamaha RX-V995 Receiver
What FM frequency does the radio need to be on to use a wireless Disney Mickey mouse microphone?
Each microphone has a different FM Freq. If you can not find a Freq there is a very small hole in the mic near the Mic switch. You will need a jewlers screwdriver to make a freq. adjustment. Hold down the applause button while very close to your FM radio. Use manual tuning on your FM radio until you hear applause. If there is a local station playing on the Freq you can insert the jewelers screwdriver into the small hole and change the FM Freq for the Mic. You only need to make "fractional adjustments" to change the Freq. setting. Once you make a mic freq. adjustment change the radio freq SLIGHTLY up and down until you hear the applause.
This should get anyone going that is having difficulty with this microphone.
Thanks for choosing FixYa.
Kelly
Aug 02, 2010 | Toys
Cb transmit noise
Its just RF feed back, that's normal, try to re-route the coax, or just turn the FM down, o try turning your modulation down....hope this was helpful....
May 29, 2010 | Cobra 75 WX ST 40-Channels Handheld CB...
Slide to unlock has stopped working and I cannot access anything or even receive calls
try a soft reset ...Hold the power and home keys at the same time ...phone will shut down hold buttons til the a[pple logo shows on the screen
May 21, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
I HAVE A 2517 GALAXY RADIO IT IS MUFFELD ON TRANSMIT
What is the power output on a watt meter telling you? if it is up above an 8 watt dead key with the rf power turned all the way down, someone has turned up the radio inside and you will ned to turn it back inside to get about a 2 or 3 watt dead key with the rf power turned all the way down on the outside knob on the face of the radio. to do this, you will need to locate the VR18 pot for low power on am/fm and the VR14 pot for high power on am/fm and adjust accordingly, you are most likely overdriving the radio in some way and if you are not familiar doing this sort of thing, then my suggestion would be for you to take it to your nearest electronics repair tech and have them do it for you. It is not a costly procedure and you will be better off to have an experienced tech in there. Also if you are running a power mic on it, try turning it down some or going back to the stock mic to see if the problem persists. If it does while running the stock mic, then most likely it's internal issues like the one explained above.
Dec 10, 2008 | Galaxy Radios DX-2517 CB Radio
Getting a "Protect" message in the display which then shuts down
The speaker wires were al little frayed, so I cut and stripped new 3/8" leads and when re-inserted the receiver worked fine. The problem was a short from the frayed wires touching either the back of the receiver or some other metal near the terminal.
Dec 06, 2008 | Sony STR-DE185 Receiver
Hannah montana mmicrophone
I found this on Yahoo:
I Have The Directions Here
1. for best proformance please note the following
a. place the FM radio in an area of minimal nosie and interference
b. do not set vol to max
c. has to be within 15 ft
d. hear your own voice, will not be brodcasted over the radio
e. in some areas, all frequencies in 92 to 106 FM range could be occupied by a local radio station. in this rare case, your mic will not be functional
3. move mic close to radio while tuning, tuning into frequnecy may take practice. may need to move your radio dial slowly and sing or talk in to the mic
Buttons on the mic:
A.... Applause
S.... DJ Scracth Efeect
M.... Mic
Source(s): Hanna Montana FM wirless mic instruction manual
Feb 10, 2008 | Audio Players & Recorders
Galaxy Radios DX-48T Base CB Radio Logo
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
