Question about Capitol Freightliner Mt-55 Emt Us Capitol K9 Police Truck 132
Trouble shooting diesel engine
Once engine is warmed up the truck sputters during excel oration and white smoke coming from exhaust.
Trouble shoot white smoke
Causes of White Exhaust Smoke
I've copied this link which provides info on some of the causes of white smoke. The first thing to check is the coolant level in the radiator. Take the cap off only when the engine is cold to avoid burns.
May 03, 2014 | 2002 Chrysler Voyager
White smoke from exhaust after changing fuilds
Is it condensation or actual smoke? White smoke is associated with diesel mixed in petrol and with quite strong smells. I suspect that it is condensation as water vapor is a by product of combustion and the motor/exhaust will have to warm up to clear it. Check for water droplets at the end of the exhaust to confirm condensation. Burning oil will cause a blueish smoke to emit from exhausts.
Apr 02, 2014 | 2007 Harley Davidson FLHX Street Glide
1998 gmc sierra 1500 5.0L
white smoke is a blown head gasket [white smoke burning anitfreeze]
Jun 24, 2013 | Cars & Trucks
EXHAUST TROUBLE SHOOTING
If smoke is black indicates too much fuel
If smoke is white Could be coolant in the exhaust system
If smoke is blue possible excessive oil entering in the combustion system
Also if you have an automatic transmission with a vacuum modulator, it could be leaking transmission into the combustion
If you have too much oil in the engine, it will also smoke
May 06, 2013 | 2007 Honda Accord Sedan
White smoke pouring out of my diesel Renault Clio
You have fuel delivery issue, what they are will take a diesel engine service technician time to figure out.
Mar 16, 2017 | Renault Clio Cars & Trucks
86 chevy silverado, white smoke coming out exhaust and sputtering out
this sounds like you may have a head gasket that is leaking. you will need to have the compression on the engine checked when it is cold to see what is going on.the smoke is from coolant that has leaked into the engine and is being turned into steam and this is what you are seeing and once it warms up the leak seals off and should stop smoking
Dec 04, 2010 | 1986 Chevrolet Chevy
Engine light came on wit lack of power spluttering and wgite smoke from exhaust
Dear Sir,
As you said engine light is on and misfire with white smoke, it clearly symptom of poor ignition spark may cause of any wire got disconnected or spark plug faulty.
white smoke comes only in case no spark at spark plug and un burn fuel throwing from silencer. check wire and spark plug if any issue let me know. thanks.
Yogesh
Nov 17, 2010 | Hyundai Tucson Cars & Trucks
I have a diesel engine that expells white smoke for 5 to 10 miniuts after start up? The exhaust also smells rich with fuel? I bought the truck used and am trying to fix the problems! Please help.
When an engine expels black smoke it means that the piston rings are going and is consuming oil. And when the color of smoke is white the engine is consuming more fuel. Both are harmful. Black to the engine and pocket while white to the pocket. It seems that the injector need careful attention.
Cold engine does expel white smoke initially. When the temperature rises to normal working temperature the smoke stops. This is normal in your case. 5 to 10 minutes to warm up is normal for any diesel engine. But any thing more than that needs attention.
Oct 04, 2010 | 1988 Ford F 250
White smoke coming out of the exhaust when starting the engine?
Its the problem of oil.The oil is getting burned out. The vehicle is either burning oil or it is moisture in the gas chamber if you notice white smoke from the exhaust. This is a common possibility.but in some cases this white smoke is not due to oil burning.In that case   White smoke from the exhaust is a symptom of coolant entering the combustion chamber. Normally this is a sign of a blown head gasket or cracked head. And  this is not a common problem must be repaired immediately. You must STOP driving this vehicle or you will cause serious engine damage. you will have to get both this possibilities checked.
Thanks. you can rate this solution and show your appreciation.
May 20, 2010 | 2001 Volkswagen Golf
1992 gmc sierra turbo diesel starts and idles fine until warm up
It's time for a Italian tune up!
The blue smoke can be one of two thing.
oil drop from the valve stem (from engine head to cyclinders)
or
diesel soot collect inside the exhaust system.
I will take a 5-10 minutes high rpm (not redline) ran on the highway.
Pay close attention to the rear view mirror and look for black diesel soot.
=== I will use Diesel Cleen or similar product to condition the fuel. (keep moisture down)
Use the recommended amount of SEAFOAM oil additive to condition the valve stem seal/rubber parts.
I can not rule out excessive blown by.
Can you get a diesel compression tester?
When was the last valve adjustment?
Please post the actual odometer on the engine and I will follow up on it.
Apr 21, 2009 | 1992 GMC Sierra K1500
Capitol Freightliner Mt-55 Emt Us Capitol K9 Police Truck 132 Logo
21 people viewed this question
Top Capitol Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Capitol Toy Expert? Answer questions, earn points and help others
