Question about Omega Juicers
Ruined will not turn on
Juicer worker perfectly two day ago now it will not turn on
No longer turns on
check the motor some juice might have been inside of motor has 2 brushes need to work prpoerly on 110 vac rated at 10 amps or better. clean your machine look for signs inside not on the city streets..
Mar 25, 2014 | Waring JEX 328 Health Juicer
I need a manual for G5NG853S juicer
WHAT DO I DO TO REMOVE THE BLADE IT IS FROZEN?????THE JUICER WORKS PERFECT, I REALLY WANT TO CHANGE THE BLEADE
Dec 29, 2010 | Champion G5NG853S Household Juice...
Hello, and thank you for your time. The juicer was given to me 2 months ago and it's brand new. As of today, some how l can not get it to work. l turned the nob to on, but nothing happens. l opened the...
you have to twist the top round so that the switch is pressed in place so the power can be turned on, from new it takes a few times to get it to click in place this is the safety device so it cannot be turned on by mistake.
Aug 04, 2017 | Hamilton Beach Big Mouth Pro 67600 820.27...
Omega 8005 juicer will not start
flip it over and hit the reset button, if there is one. If not, then make sure that it is put together properly, mine will do the same thing if the pulp collector is on wrong. or if you overheat it, then let it set and try to reset it.... hope that helps.
Jun 30, 2009 | Omega 8005 Juicer
Jack LaLanne power juicer 250 no longer works.
The stainless bar should be on the correct slots on top of the juicer. It has a safety switch on those bars. Smell the motor from under the juicer, it should not smell like burnt. Press hard on the switch, it might be loose.
Jan 28, 2009 | Jack Lalanne Power Juicer 250 Watts
Power juicer not working
Hi my name is patricia you probably have to have the handle bars on or up so it can be tight and then the motor will run.
Aug 27, 2008 | Jack Lalanne Power Juicer (Stainless...
Jack LaLane Power Juicer CL003AP Tri Star Products
The Jack Lalane website claims it has a lifetime engine warranty. Visit to find out.
Aug 09, 2008 | Jack Lalanne Power Juicer 250 Watts
Everything leaked all over the countertop
You have one or two choices. You have every right to return to product to the store you purchase it within 30 days with a receipt. Now if you feel you want to keep it try to place the gasket on right. This should stop the leaking. If you did not get a gasket, then return this product for another one. Sign, Spurs21
Jun 12, 2007 | Jack Lalanne Power Juicer (Stainless...
Juicers Logo
41 people viewed this question
Top Omega Juicers Experts
Andrew Taylor
Andrew Taylor
eyecam
Tom Chichester
Are you an Omega Juicer Expert? Answer questions, earn points and help others
