Question about Yahoo Messenger
I cant log in to my yahoo messenger. i entered the username and password but it still doesnt work . i have a good internet connection. pls help :(
It says we cant sign you into Yahoo messenger. There might be a problem with your internet connection. Make sure you comp. is connected to the internet. Click troubleshoot to begin a series of tests to try to diagnose the connection problem. ( I reinstalled my YM and then a message popped it said there's a missing plug-in but when I click it, the message was gone and I cant retrieve it anymore)
4 Suggested Answers
mcsecoolguy
  • 93 Answers
SOURCE: We can't sign you in to yahoo! Messenger.
Kindly check your network connection and also if you connected to the internet. kindly sign out and sign in to yahoo
Posted on Jan 09, 2010
  • 3001 Answers
1) Yahoo are concentrating their efforts to resolving sign-in issues with Messenger 10. You may have to upgrade to this version if you cannot resolve your problems and make use of the troubleshooting software - even if you want to retro install an older version later.
2) users who opt for a default browser other than IE may be neglecting to keep IE up to date unaware that IE plays a crucial part in the running of Yahoo Messenger. I use Firefox as my default but note the amount of cleaning in IE when I run ccleaner.
3) Start your trouble shooting with a clean browser
Download 'ccleaner' and run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.
http://www.filehippo.com/download_ccleaner/
4) It will be worth making IE your default browser while you troubleshoot
5) Download the latest IE from Microsoft
http://www.filehippo.com/download_internet_explorer/
6) Ensure 'work offline' is unchecked :- > Tools - uncheck Work Offline.
7) Update your support software for IE using the links on this page
http://help.yahoo.com/l/us/yahoo/messenger/messenger10/notices/mstabuguqscripterror.html
After updating check you do not have old versions of Flashplayer, Shockwaveplayer and Java running alongside the latest - this can cause conflicts
Start / control panel / programs
delete any old versions
8) If your log-in fails, interrogate the troubleshooting log for 'failed items'
Two Yahoo servers are used for initial log-ins
The log-in server checks your username and password are correct
If this has 'failed' check your IE can access a secure website by signing in here
https://login.yahoo.com/
No luck? check IE settings >Tools > Internet options > Connection tab > LAN > 'Use a proxy server for your LAN' > Advanced - Under 'Proxy address to use' check the info in 'Secure' and 'Port' are correct > OK for each window.
The connection server helps find the right location to synchronise with other servers- if this shows 'failed' change your YM settings to connect via a proxy.This can be done from the menu on the sign in page > Messenger > Preferences > Connection -adjust settings > Apply > OK
If all else fails - try dis-abling your firewall and do a test sign in.
Posted on Jan 10, 2010
mace1mace
  • 1138 Answers
you can sign in again, just follow the steps from this link
icantsignintoyahoomessenger.blogspot.com/
Posted on May 23, 2011
Unable to connect yahoo messenger in nimbuzz for PC : in communities option it gives error
the problem is connecting yahoo thru nimbuzz not with YM.. logging in YM is working very fine. but not thru nimbuzz. does anyone have a solution for this ?
Apr 21, 2012 | Nimbuzz Computers & Internet
Im using yahoo messenger version 11 .i cant sign in anymore .. other website like facebook n search are okay except in yahoo ..what are solution of this problem..pls help
i got the same problem with my ym 11 too.. but honestly looks like its ym problem that it may just work whenever it want to.. :( but try this.. open Yahoo Messenger click on "Messenger" (on top), choose "Connection Preferences" select "Connect via Proxy Server" try to log in ..
if it doesn't work put it back to the original settings, same instruction go to YM, click Messenger then Connection Preferences select "Connect directly to the Internet".. this time try to disconnect your internet connection first.. and then with your YM open enter your username & password but dont click "connect" yet.. connect to internet & log in to ym (you should click "connect on ym right after a second you are connected to the internet)
Sep 10, 2011 | Yahoo Messenger
I can't log in to my yahoo messenger
Hey there,
first be sure you entered your username and password correctly. In offline mode select from the top left corner of the messenger window: messenger >
connection preferences. See if your connection is set to connect via a proxy server. If true, Select connect directly to the internet by selecting the radio button. Insert your login details again and try. That should solve it.
Hope this helps
pls don't forget to vote.
Jul 04, 2011 | Yahoo Messenger
My internet connection is working but it will not let me log into yahoo messenger? Normally the only reason i cant log on is if the internet connection is down but it is not so i am puzzled. I am waiting...
Hi .I understand your frustration.You really want to connect with your friends and you cant..Now if you have internet connection there's no possibility that you cant log on to your yahoo messenger account.It requires same download -upload speed when you use your yahoo messenger application.There might be problem with your password or user name..Or offline mode has been checked.To access Offline setting.Click FILE menu ,see option WORK OFFLINE unchecked it..hope this helps.
Jun 20, 2011 | Yahoo Messenger
I cannot sign in to my yahoo messenger now. why?
make sure you have an internet connection. try opening a website.
if you cannot log in to yahoo messenger what error are you getting?
if password error check your password and user name
in yahoo messenger you don't have to type in the @yahoo.com in the username and the password try to type it in the notepad to check if you typed the correct password.
copy that password then paste it in the password box.
check for your antivirus and firewall setting maybe it is stopping your yahoo messenger from connecting the internet.
also try uninstalling and reinstalling your yahoo messenger. try downloading the latest version
if still don't get any luck logging in.
try to log in to the web base yahoo messenger
http://webmessenger.yahoo.com/
Apr 17, 2011 | Computers & Internet
I cant connect my yahoo messenger
1. Check your internet connection or call your internet service provider for assistance.
2. Check your username and password if it's correct.
3. Download for latest version of yahoo messenger. Click this link and click the download this version
on the top right side of the page to start downloading the latest version.
4. Restart your computer and log on to yahoo messenger.
Have a nice day!
Mar 22, 2011 | Yahoo Messenger
Cannot open my yahoo messenger
I am not able to log into yahoo messenger
Feb 13, 2011 | Yahoo Messenger
Cant log in to yahoo messenger
Try creating a new account, or try the forgot password link.
Jan 21, 2010 | Yahoo Messenger
Cant log into my yahoo account
hi thanks for using fixya!
Just make sure that you enter the correct username and password. And make sure that the internet connectivity is working properly.
If you still, cannot open, try to sign up for a new one.
Regards!
Apr 26, 2009 | Yahoo Mail
Unable 2 use messenger for vista
Hi There!
As i Understand you successfully downloaded yahoo messenger foe vista, however you cannot login using your username and password.
It seems like some of your files are corrupt. Please uninstall yahoo messenger and reinstall again from the link given below,
http://messenger.yahoo.com/download/vista/
Also once you have installed the new yahoo messenger, see that you have internet connection to get connected using your username and password.
Regards,
Olafsson
Oct 11, 2008 | Yahoo Messenger
Yahoo Messenger Logo
62 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
