Question about Tablets & eReaders
Zeki tbdg1073b will not boot up
Tablet will not boot past the android OS screen. Do I have to reset and is pushing the button on the back the best way to go about that reset.
  • 99 Answers
SOURCE: HP tablet OS is android
As far as I knew hp was running windows on it's tablet line.
Posted on Oct 13, 2010
ib_yang
  • 1098 Answers
SOURCE: when i turn my android
Hi there
There is a reset hole. Please insert an unfolded paper clip and push the button for about 10 seconds.
Let me know what happens.
Thank you for using Fixya!
Posted on Jul 26, 2011
  • 3940 Answers
SOURCE: my binatone homesurf tablet is stuck on the home screen and wont do anything can you reset it
Sounds like it needs a reset.
The Binatone Helpline is available from 9.00 am to 5.00 pm, Mondays to Fridays, please call0845 345 9677 for UK+491805938802 for EuropeAustralia customer service number 1300 768 112 or email to service@shriro.com.au India customer service number +91 7503011385 or email to assist@binatonetelecom.in
http://www.binatonetelecom.com/binaries/content/assets/binatone/products/android-products/homesurf-7/pdf/homesurf_7user_guide.pdf
The manual has very limited troubleshooting, so it looks like you'll need to call them.
Posted on Oct 25, 2011
brimknows
  • 10 Answers
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
Posted on Oct 26, 2011
SOURCE: The tablet turns on but seems frozen and shows the android screen and nothing else. Tried to reset it but it does the same thing
so wat do i do
Posted on Dec 28, 2011
I turn on my zeki 7' dual core tablet and it turns on but stays on the zeki logo screen and wont load..
Go to this site for the instructions on how to do a hard reset on your tablet.
http://www.howtogeek.com/130611/how-to-factory-reset-your-android-phone-or-tablet-when-it-wont-boot/
Dec 31, 2014 | Zeki Berk Ulu TBDG773B 7" 8 GB Black...
How to reset a zeki tablet password
Hello there,
From the Zeki website it says do this.
If you have set the screen lock to a password or pin code, and have forgotten the code; you will need to reset you tablet to factory default setting.
  1. Make sure your tablet has a full charge
  2. Press and hold the Volume - button and tap the Reset button
    (The reset button is located between the HDMI and USB ports)
  3. Continue holding the Volume - button until the boot screen appears
  4. Release the Volume - button
  5. Use the volume controls to navigate to "Wipe data/Factory reset"
  6. Press the power button to select
  7. Navigate to "Delete all user date"
  8. Press the power button to select
Your table will take several minutes to reboot to a factory default setting.
Hop this helps you friend. :)
Sep 25, 2014 | Digital Products International Zeki 7
Reset zeki tablet
if all you see is a large green android robot then you will have to reflash the tablet as android is having a problem booting up
http://zekitablet.com/support.html
there are too many models to give you specific instructions need to know the model number
Sep 06, 2014 | Tablets & eReaders
How do i get it off the android screen so it will show the lock screen?
Sounds like its borked.
Have you pressed the reset button on the back - pinhole - press it with a pin its a long shot.
The real fix is to go into recovery mode using the power button volume up combo. Then select the restore tablet option.
If none of that works you will have to sideload or reinstall using an sdcard a replacement OS - Try cyanogenmod - your tablet will have to be rooted and have the cm bootloader installed however - tablets are not easy things to repair when the software goes belly up.
May 12, 2014 | Shopnbc Zeki 10.1" LCD Android 4.1 8GB...
I have a zeki tablet that won't load, wondering if anybody here can help me?
I'm assuming it is the Zeki 8" TBDG874B. What I would do to get it of the flashy Android logo is hold down the volume button on the minus (-) side and get a small pin or needle to tap the reset. While holding the volume it will reset, then tap the power button still holding volume it will bring up a list. Do a factory reset (you lose all data but that's what I would to do to be on the safe side).
Apr 09, 2014 | Tablets & eReaders
ANDROID SCREEN IS STOCK IN THE WORD ANDROID
Could be a Boot Loop. This happens when you have (or attempted to) modify the device's firmware. A factory reset would be the best solution to your problem.
The following web post might be of help;
http://www.gadgetreview.com/2013/05/how-to-factory-reset-your-android-device.html
Good luck
Feb 20, 2014 | Shopnbc Zeki 7" Multi-TouchTablet
Can you download apple apps on a zeki tablet?
no, absolutely not (only with an emulator, see 2nd link)
as Zeki-tablets use Android OS
- however many apps exist in iOS, Android or other versions
you need to check that with the built in Amazon App store
Ask Mama Reviews
iOS Emulator for Android APK Download Run iPhone Apps on Android Phone download-apple-apps-zeki-tablet-oawkhf2sylgpmq5puvpglfxy-3-0.jpg
Nov 28, 2013 | Shopnbc Zeki 7" Multi-TouchTablet
Tablet freezes on boot up at android screen
Do a factory reset. Turn the tablet off. Wait 10 seconds or so. Hold down volume down button while pressing the on button. Keep holding down both buttons until you see an android icon. It may be laying on its back with a red exclamation mark over it, like I saw. Once you see the icon, let go of the buttons and press the "back" or return button. This should bring up a list of options. You can scoll through the list by using the up or down volume buttons. I picked the option to delete all user data, which basically will set the tablet back to factory settings, like when you first got the tablet. Once that is complete, reboot the tablet.
Mar 24, 2013 | Iview 760TPC Android Tablet, ARM Cortex-A8...
Tablets & eReaders Logo
420 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
