Question about Dyna-Glo (PPH16-LP) Utility Heater
Workhorse karoene heater starts and runs and heats then quits
2 Suggested Answers
SOURCE: E 1 error on Dyna-Glo Workhorse Kerosene Turbo Heater
Take the top off of the heater and and clean the nozzel orifice, while you have it apart wipe off the photo cell and clean and regap spark plug. The nozzel unscews and you can clean it with a bread tie.
After this clean or change the fuel filter in the tank, and finally check the pump pressure and make sure it is inline with the owner manual. This is assuming that it is firing to begin with
Posted on Feb 09, 2009
Black and decker space heater has run for hours, quit and won't start
When laid down it has an emergency switch to prevent fires,check that this switch is reset in the correct position.
Jan 09, 2018 | Heating & Cooling
Kia 2700 workhorse engine not running evenly at high revs or uphill travel
Fuel starvation. replace fuel filter first and at that time check fuel pump pressure. While under the hood clean injectors
Jun 18, 2014 | 2007 Kia K2700 Workhorse
Fuel shut off switch
Replace the thermostat.
Jan 23, 2014 | Dyna-Glo Heating & Cooling
I own an older Jandy Lite 2. The pilot light is on. After the heater runs for a while it gwets very hot and then turns off making it impossible to re-start. Electician restarted by replacing wire that...
over temp situation causing high limits to open. inspect venting, heat exchanger. ensure proper gas/air mixture, proper ventilation and combustion air supply
Aug 19, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
I have a 60,000 btu Reedy Heater runs 5-10 min then shuts off restarts black puff of smoke bad plug ??
Check the fuel filter on the units as well as the inlet and outlet filters on the back of the motor.
Watch the nose cone and see if the end starts to loose the glowing orange color before it quits.
If the unit slowly looses the color then you have a fuel problem but if the unit just quits at full heat then you could have a electrical problem.
Typically the spark plugs on these heaters don't go bad.
Oct 13, 2010 | Reddy Heating & Cooling
Unit runs for one and a half hours then shuts down
Oct 07, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Ford courier 1.8 diesel van, blower works, but no heat comes into the van when heater turned on
ford courier workhorse ,great van ---right when engine is hot feel the hoses that run into the heater ,also it could be the heater core was leaking and someone has joined the hoses together .if the hoses are connected and they are hot then ,try removing them and then flushing the heater with a hose pipe
Nov 29, 2009 | 2000 Ford Escort
Dyna-Glo (PPH16-LP) Utility Heater Logo
16 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
fordexpert
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
