Question about Rheem Water Heaters
Rheem Power vent 2 water heater has green blinking light, what does that mean?
Led indication light is blinking, what does that mean?
SOURCE: Rheem water heater with powerglow ignition wont re-light
I have fixed mine. The problem part is the Ignition Control module. It is made by Robert Shaw part # SP10758. I paid $93 plus shipping.
Works great now. A repairman wanted to sell me a gas valve for $488.
Watch out for these people.....
Posted on Jan 10, 2009
odiebugs
  • 949 Answers
SOURCE: No hot water from tankless water heater. Bliniking Readout
http://www.rheemtankless.com/content/tankless/rheem/help.shtml
This is there website.Above.
Use the live chat to ask them, the code you listed does not seem to correspond to there code list, the only code that does is code 76,
which is a problem with the remote control not talking to the unit.
So your best bet is to tell them the error.
Posted on Apr 07, 2009
gary1121
  • 332 Answers
SOURCE: PVS50 rheem power vent water heater do not reignite/restart/kick
I actually just installed one of these the other day, I found that the ignitor wires were straped to the gas inlet and they were shorting out,, I wraped them with electric tape and the unit came on and stayed as for the thermostat make sure your flue is clear of all obstuctions even outside, make sure on the vent on the top back of the unit is clean and no lint or dust has built up on it, you can take a small soft brush and just sweep it across it
Posted on Jun 21, 2009
  • 48 Answers
SOURCE: Loud blower on my new Rheem Power Vent 2 water heater
find out if it does the same noise with the venting disconnected
Posted on Jan 16, 2010
  • 13 Answers
SOURCE: rheem model 41vrp40n power vent water heater won't
"Pres sw open" means there is insufficient air flow. either the vent if blocked, or the blower turns too slow/ or died.
Posted on Feb 12, 2010
Protech 62-24084-02 troubleshooting
62-24084-02 LED CODES
POWER LED - GREEN
ON - Normal
OFF - No power to board
OK LED - GREEN
One Blink - One hour retry delay
Two Blinks - Pressure switch failure (remains open)
Three Blinks - Limit switch fault
Four Blinks - Pressure switch failure (remains closed)
Five Blinks - Twinning fault
FLAME LED - YELLOW
ON - Good flame
Rapid Blink - Flame present with gas valve de-energizing
Slow Blink - Marginal flame
Jan 01, 2014 | Protech Rheem/62-24084-82-1PK - Integrated...
Rheem model 41vrp40n flashes twice and stops working
Error code means that you have electronic gas control valve.
Copy following link to identify gas control valve, read error code meanings for each, and download service manual relevant to each gas control, but not specifically Rheem since rheem does not post service manuals.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
The fact that water heater restarts, means that water heater is getting gas, getting sufficient air for combustion, thermister is ok, gas pressure is good, etc.
The fact that you unplug and replug water heater and it works, shows that you have power vent model.
Since water heater worked correctly before, 2 flashes with Rheem power vent model could mean that pressure switch has failed.
Jul 29, 2012 | Water Heaters
I have a Rheem rtg 74dvp but its not heating and the display show me 1 76 and 2 76, and come all the time to 76 F and another times its blinking the temperature, but not heat
Error code 76 is communication problem between remote control and tankless unit.
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
Multiple error codes could indicate that main PC board is bad.
Before calling service technician, open following link for troubleshooting resources including link to Rheem chat, manuals, error codes, etc.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Jul 15, 2011 | Rheem Tankless Water Heater RTG-74DVP...
RHEEM 50 GALLON WATER HEATER,4 BLINKS THEN 2 BLINKS ,ECO FAILURE,UNPLUGGED HEATER STARTS UP AGAIN THEN FAILURE OCCURS AGAIN.
That is a power vent failure code.
Rheem is aware of this problem and are changing systems as we speak. Call your Rheem dealer and demand the updated system.
Feb 07, 2011 | Water RHEEM 40 Gallon FVR PROP PWR Heater...
Rheem Power Vent 2 water heater is flashing 4 times and there is no hot water. Model # 41VRP50NT What can I do to fix this? Do I need to call a plumber?
The flashing light is a trouble sequence light. Find your manual to see what 4 flashes means. It's usually attached to the side of the water heater tank. Try a quick fix by unplugging the power vent and see what happens.
May 15, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem power vent 2 water heater keeps shutting off
you need to replace the upper thermostat, it has the overtemp switch made to it. Also make sure that the thermostat is pushed up tight to the tank with no space or object between them.
Mar 12, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
1 unit intermittently shuts off and other won't ignite
if you have the exhaust run together it will not light up,, they have to be seperate,, the computer board sences the unburnt gasses and will not allow it to start,,
Jun 24, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Jun 17, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water Heaters Logo
15 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
