Question about WorldBooksOnline.info Retail Supplies
Leica gps viva - WorldBooksOnline.info Retail Supplies
Where can I download or update the firmware for Leica CR344
Not 100 percent on a unit that old. All recent Leica equipment can only be upgraded at an authorized factory service center. That service center has to have a "dongle bit" plugged in to their computer that gives them access to software needed to update firmware.
Sep 05, 2013 | Leica Cr344 Gps Controller
Leica GPS 300 system will not recognize SRAM Card
leica 300 system takes the following pcmcia cards
PCMCIA Cards.
Optional 1MB internal memory.
Type I SRAM cards: 512KB, 2MB. 4MB.
Type II FLASH cards: 20 MB
Types I-III:
Type I: 16 bit Formfactor thickness 3.3 mm.
Type II: 16 bit or 32 bit. Formfactor thickness 5.0 mm.
The original standard was defined for both 5 volt and 3.3 volt cards, with 3.3 V cards having a key on the side to prevent
them from being inserted fully into a 5 V-only slot.
Mar 18, 2013 | Leica GPS
Request unlock HTC viva touch
Hi, To which network has your HTC TOUCH VIVA has been locked to? You can unlock your HTC TOUCH VIVA safer and easier using unlock code. You can get the unlock code for a HTC TOUCH VIVA from www.onlinegsmunlock.com/htc-touch-viva/rs7wp9/ at affordable cost.
UNLOCKING STEPS FOR HTC TOUCH VIVA
1. Switch ON your HTC Touch Viva with a Not ACCEPTED SIM Card.
2. If your HTC Touch Viva asks for a PIN code, then enter your SIM card PIN and press OK.
3. HTC Touch Viva will ask to enter an "unlock code".
4. Enter Unlock Code we send to you.
5. Your HTC Touch Viva is now unlocked.
Oct 06, 2012 | Cell Phones
I have a Leica Digilux, but could not fine it anywhere on tghe dealer spots. I need a memory card for it and its difficult to get locally. The size is larger than the regular cameras.
Amazon could be a help:
http://www.amazon.com/MEMORY-Leica-DIGILUX-Digital-Camera/dp/B000Y06WXA
It may depend on what your exact camera model is. You have only stated Leica Digilux.
There is the Leica Digilux 1, Leica Digilux 2, Leica Digilux 3, Leica Digilux 4, and the Leica Digilux 5. Most seem to take the SD HC (the SD card may work as well) card:
http://www.google.com/search?q=Leica+Digilux+memory+card&hl=en&prmd=ivns&source=univ&tbm=shop&tbo=u&sa=X&ei=FjQaTtGBMoKusAKnxLzCBw&ved=0CDsQrQQ
If your camera is a Leica Digilux 1, then the cards it can take are: Secure Digital Card and Multi Media Card
http://en.wikipedia.org/wiki/Leica_Digilux_1
If you have an earlier camera, then it could take some other kind such as the Compact Flash Card, although I did not find such a note anywhere.
Jul 10, 2011 | Leica Cameras
Leica rtk cr344 controller code error 1165
problems on the motherboard of the collector, sorry
Dec 07, 2010 | Leica GPS
How to use External Gps?
Most external bluetooth GPS units uses serial ports to communicate to the GPS software. You don't need to bother with the External GPS thingy in the setting page. If u really ask, u need to pair using BT to the GPS unit. Under bluetooth setting, u can create and outgoing port as well. On your GPS software, point it to look at that port number.
Feb 12, 2010 | HTC Touch Viva Cell Phone
Can't find instruction manual
Hello
At the link beow you will be able to download the manual for the requested manual.
http://www.retrevo.com/support/Leica-D-Lux-3-Digital-Cameras-manual/id/522dj983/t/2/
Kind regards
Andrea
Jan 24, 2010 | Leica D-lux 3 Digital Camera
I want to use GPS for HTC touch VIVA
hi
sorry to point out but Viva is a non GPS phone and it does not have anything inside even to use a software to get it activated
cheers
pls rate if this was any help
Jul 12, 2009 | HTC Touch Viva Cell Phone
Alternative to Leica Laser Locator
Leica locator with DGPS capabilities? Leica still manufactor advanced military systems under the Swiss brand name of Vectronix which is part of the Leica group. Are you after a laser locator or a rangefinder such as the discontinued 7x42 Geovid. The Geovid is still available but no longer has the electronic compass. The original never did connect to a DGPS PC only the Leica Vectronix Vector could. None of these models will locate a laser only use a laser to calculate distance. Current Geovids range to 1200 meters and the Vectronix 21 will range to 12 Kilometers. Unless you are a certified government customer the Vectronix 21 you will not be able to purchase. Newcon have models that allegedy exceed 2000 meters that are made in Russia and depending on the model can be had for a few thousand dollars. The Leica Geovid 8, 10 or 15 power can be had for around 2.5 thousand to 3 thousand dollars and is an excellent robust unit. It will not connect to a PC for GPS sync though.
Mar 12, 2009 | Leica Laser Locator Binocular
Retail Supplies Logo
77 people viewed this question
Top WorldBooksOnline.info Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a WorldBooksOnline.info Retail Supply Expert? Answer questions, earn points and help others
