Question about NetGear Computers & Internet
Authentication required for netgear router ..... Help!?!?!
Authentication required is what it says when I go to router login. I put n my use rid and password and it's not the right one apparently! So,what do I do to get logged inauthentication
Benimur
  • 6966 Answers
SOURCE: Router login
If your Comtrend CT-5621 came with the package from your ISP then it is possible that the username and password has been changed by your provider and you would have to get in touch with them.
In some instances the username is "root" and the password is "root".
Some known passwords from ISPs are:
Canadian Broadband/Aliant - RM60008
NetComm - NetC0mmV3oo
Some ISPs disabled/blocked the web based configuration interface and the initial way to communicate with it is a telnet session to the router.
Would you know if your default IP address of 10.0.0.1?
Good luck and kind regards.
Posted on Oct 21, 2007
  • 52 Answers
SOURCE: Router Password
try admin and admin again for password. If that is not it try leaving the password box blank. Good luck Are you sure you did not change the password when you set it up the first time. If you did you have no other option than reset.
Posted on Jan 30, 2008
2Gigs
  • 141 Answers
SOURCE: Password Problems
Maybe you are getting LIMITED OR NO CONNECTIVITY. This happens when the wireless adapter is able to find a network but the pc cannot get an ip address. One of the reason for that is that your wireless network might be secured and you missed to enter the correct network key when you were asked by the computer. The wireless security is set on the wireless router, SO WHEN YOU SET THE PROFILE ON YOUR WIRELESS ADAPTER, YOU SHOULD ALREADY HAVE THE WIRELESS SETTINGS FROM YOUR WIRELESS ROUTER. THEY HAVE TO MATCH FOR YOU TO HAVE A COMPLETE CONNECTION.
Posted on Mar 12, 2008
  • 16 Answers
SOURCE: cant login to router
When in doubt double check your work. You held the reset button down on the back of the router for long enough for the lights to go out then start blinking again? Then you went to 192.168.100.1 in your browser and tried admin for your login name and motorola for your password? If you did all of that and it's still won't accept your login try to power the router off for at least a minute by pulling the power cord and make sure you clear your browser cache before trying to access the default gateway address in your browser again.
Hope that helps!
Jill
Posted on Nov 30, 2008
gomobo75
  • 63 Answers
SOURCE: login to router
Leave the username blank, then enter "admin" as the password. You can also reset the router to factory defaults by pressing the reset button on the back (small hole, use paper clip) and then try again.
Posted on Jun 23, 2009
Crack password online
Restoring a Netgear Router to Factory Default Settings
Symptoms:
Cannot access the NETGEAR router or access point web interface login screen, or
You have forgotten/lost the password to log into the NETGEAR router or access point (NOTE : This refers to the password required to access the devices administrative interface. If you have forgotten the password required to access the wireless network, you should refer to this article instead).
http://kb.netgear.com/app/answers/detail/a_id/9665/~/restoring-a-netgear-router-to-factory-default-settings
Sep 16, 2013 | NetGear Computers & Internet
Netgear G54 Wireless Router says authentication failed
To RESET the Netgear, power up the Netgear then press and hold the RESET button at the back of the router until all the LEDs flash. Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Dec 01, 2012 | NetGear Computers & Internet
I have a problem with my router login.I have tried hard resetting it and using the default password (username: admin , password: password) whenever I try to login it gives me an error: "System...
If the router ssid reads virginmedia.... then you have not reset the router. The default name for a Netgear router is Netgear.
Push the reset button in (on the back of the router) and hold it for at least 15 seconds or until the power light flashes.
Now the username and password and SSID should be reset to the default.
Oct 23, 2011 | NetGear DGN1000 Wireless Router
Hi my netgear keeps on blocking websites and i wish to get rid of it, i got up to the part where i have to type in the routers address, the 192 thing, but it then says authentication required and im not...
Most of the NETGEAR devices, except ReadyNAS products and Fully Managed switches, have the following default
USERNAME : admin
PASSWORD: password
You can also read from netgear site for more info. http://support.netgear.com/app/answers/detail/a_id/9665
I hope this information will be helpful. Thank you for using FixYa!
Please vote if it helped you.
Jun 27, 2011 | NetGear DG834G Router
I have Netgear DG834G v3 working fine on 3 laptops (vista) 2 iPhones ps3 and wii with wep and no issues. I bought a new printer which requires wpa to be used but when I change over nothing will connect....
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default PW = password You can now change the admin password and configure thewireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
May 15, 2011 | NetGear DG834G Router
Cannot set password at IP address provied. says authentication required. Help set up router per directions
Hi!
If you've forgot (or don't know) the password for your router, reset it by pressing the Reset button on its back (next to the antenna) for 20 seconds. Allow it 2 minutes to fully restart itself.
Afterwards, go to 192.168.1.1 and login using:
Username: admin
Password: password
(all lower case letters)
Refer to the User's guide to reconfigure your router; refer to page 6 and on...
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Apr 24, 2011 | NetGear WGR614 Wireless Router
When logging in, it will not accept my passphrase?
If it doesn't accept it then it doesn't match what was setup in the router, login to the router via a browser at 192.168.0.1, using a ethernet connection. Find the Security Settings page and check the spelling for the passphrase entered there, take note of the Network Authentication that is setup also, when accessing the router from a laptop or pc the network authentication and passphrase must match.
Jun 10, 2010 | NetGear WGR614 Wireless Router
I have a Netgear wireless router DG834G and i am trying to connect a wireless Brother printer and it is asking me if it is No Authentication or Encryption, No Authentication with WEP Encryption,...
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router with the Username as admin and password as password (unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the routers' wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Sep 12, 2009 | NetGear DG834G Wireless Router
HOW DO I SECURE MY ROUTER
Login to your routers web access by typing 192.168.0.1 in the browser. After that you will find router settings screen. Click on Security tab and change the settings as per your requirment, Choose wep with 128 bit encryption if possibe. Put a strong password. If possinble swith off SSID broadcast as it avoids un necessary attention to your router by hackers.
Aug 24, 2009 | NetGear WGT624 Wireless Router
Router Password
Jan 29, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
44 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
