Question about Dyna-Glo (PPH16-LP) Utility Heater
Workhorse space heater kfa120wh-03 when starting heater starts and runs for a little bit and stops firing
2 Suggested Answers
SOURCE: E 1 error on Dyna-Glo Workhorse Kerosene Turbo Heater
Take the top off of the heater and and clean the nozzel orifice, while you have it apart wipe off the photo cell and clean and regap spark plug. The nozzel unscews and you can clean it with a bread tie.
After this clean or change the fuel filter in the tank, and finally check the pump pressure and make sure it is inline with the owner manual. This is assuming that it is firing to begin with
Posted on Feb 09, 2009
Kia Workhorse does not start
Possible flat battery.
check the voltage of battery
and tap the starter motor. if it fires up then the starter motor is
not working properly
let me know how you get on
Aug 09, 2016 | 2007 Kia K2700 Workhorse
Bad misfire
run the fault codes as misfire can be from injectors , low fuel pressure and ignition problems
all temp gauges will show a rise on stopping an engine as there is still residual heat in the block and heads with no water circulation and cooling
the fire from the exhaust indicates an exhaust valve is not closing properly so a compression test would be in order to check for valve problems or hydraulic follower problems
Aug 05, 2015 | Cars & Trucks
How do i bypass the themstat on a workhorse heater
As you should know thermostat is for safety and it is not good idea to by pass it ,not recommended
Feb 04, 2015 | All-Pro Kerosene Garage Shop Heaters - All...
My 40-FAC heater will not ignite and run. The igniter has been replaced. What should I check next?
These models require electrical power to run the blower fan.
When you connect the electrical cord, the fan should turn on, then you should be able to start / ignite the propane. if the fan does not turn on when you connect the power cord, you will not be able to ignite the propane.
Dec 09, 2014 | All-Pro Propane Garage Shop Heaters - All...
I have a 1998 chevy blazer with a v 6 it will not start and I'm not getting any fire I change the plugs the distributor cap the Roeder and plug wires I am still not getting any fire what could it be I...
Recheck the engine trouble codes (reset any in history), then try to start it again. Check any new trouble codes - probably an ignition module or ECM problem.
Mar 30, 2017 | 1998 Chevrolet Blazer
MTD 208 cc what should the CD/flywheel gap be set at?
The ignition to flywheel gap is not hyper critical. A .024 will not stop the engine from running. Evidence is - you are getting a spark. You could lower it to .015 and maybe get a better spark.
Are you getting gas ?
Remove the air cleaner and spray a quick shot of starting fluid into the carb.
If it runs for even a little bit, your spark is not your problem.
I'm betting it will run.
If it runs for a bit, clean your carb.
Sep 19, 2017 | Garden
Heater unit will not ignite, will note fire up
Check your furnace by the electrical panel, there should be a blinking error light. Sometimes there is a legend to how many blinking lights means what. I had an issue with mine, read the code and it turns out it was hitting the high heat limit. Turns out my blower motor wasn't turning on. Replaced it with a spare and it was fixed. Find out what type of furnace, and google the name, model, and the words, 3 blinking lights. Does your furnace turn on at all? Does it start to go through the cycle then stop? This is the proper cycle of a furnace and what should happen.
Inducer motor kicks on, it runs for a little bit, about 3-5 seconds, then you should see a bright yellow glow, this is the igniter, shortly after, you should hear a click and the gas should start to flow, almost immediately it turns to a blue flame. Then your igniter should turn off and the blower motor start up.
Mar 02, 2011 | Goodman GMS90703BXA Heater
Space runs 15 seconds then stop
check in front of the flame there should be a flame proving rod which may be dirty, use steel wool to clean it so it can sense the flame, could also be a "fire eye" like a light sensor for a outdoor night light, clean the lense
Aug 01, 2009 | All-Pro Forced Air Kerosene Space Heater...
2003 merc. mountaineer with v-8, has a miss, service eng. light o
Check to see if your overflow tube againt the fire wall on passenger side is not leaking onto cylinder 4. Pull spark plug boot and make sure it is dry. When the heater core starts going bad it will leak out over flow right there
Jan 15, 2009 | 2003 Mercury Mountaineer
Dyna-Glo (PPH16-LP) Utility Heater Logo
21 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
drifterray
Level 1 Expert
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
