SOURCE: Honda 750 stalls if throttle is opened unless choke is on.
Hmm , sounds like a vacuum leak, check all the hoses, and the rubber intake manifolds and clamps
SOURCE: where is the idle screw for cb nighthawk 750
follow your accel cable to the carb. move the throttle till you see where the linkage moves. look around the linkage to see what it hits on at no throttle. that will be your idle screw
SOURCE: idle problem: motor revs up and down at idle
it sounds like your idle control valve needs cleaning or replacing
