Question about KitchenAid Washing Machines
Kitchen aid KAWS750JQ3 won't rinse - KitchenAid Washing Machines
aborcass
  • 2651 Answers
SOURCE: Kitchen Aid KUDI230BAL0 - no fill on rinse
i would check for apossible drain issue, perhaps siphoning water out after 2nd fill. make sure you have prper high loop insatlled in drain hose, could also be a bad water fill valve, solenoid overheating and not opening properly after 3 fills
Posted on Feb 22, 2008
reg501
  • 413 Answers
SOURCE: Rinse arms not spinning
Could be a a couple different issues.. Not filling with enough water or food chopper brokeen or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
Posted on Jun 10, 2008
SOURCE: Kitchen Aid Dishwasher--model #KUDS01DJ
On mine the "normal" light was the one that was flashing; after a cycling of the breaker switch in the electrical main panel and closing the washer door, it went to a 2 minute rinse before shutdown.
Posted on Jun 22, 2008
FixinFax
  • 3085 Answers
SOURCE: what does add rinse aid and where do you put it
You don't need rinse aids anymore. It rots the wiring...use FINISH tablets, the rinse aid is built into the tablet.
Posted on Jun 28, 2009
  • 149 Answers
SOURCE: Kitchen Aid Washer (3 years old) does OK
timer bad/ easy fix
Posted on Jan 19, 2010
Won t release rinse aid
The answer may depend on getting more specific information, such as model number and model name. On some of these machines you have to select Rinse Aid on the panel and others you don't. If you have one with the electronic panel it would display a symbol that looks something like a snowflake if Rinse Aid is turned on. Your operation manual should be helpful in determining if you have it set correctly. If it is set and still not operational, there may be a physical malfunction with the dispensing cap. Here is a link to find a manual in case you don't have it anymore. Good luck.
http://www.lg.com/us/support/software-manuals
Aug 31, 2013 | LG Cell Phones
My lxi-h won't draw rinse aid through the pump
You need to replace the squeeze tube on the rinse aid pump
May 23, 2013 | Hobart Undercounter/Lxi Warewasher 24"W x...
My kitchen aid washer stoped at my rinse cycle and ligth keeps flashing
The keypad interface on your dishwasher is faulty, It may be as simple as a broken solder joint, they recommend replacing the unit but it's worth trying to solder the connections to save some money and the worst case is that it won't fix it.
Mar 12, 2012 | KitchenAid Dishwashers
Kitchen aid gas range igniters won't stop
Jammed and broken ignight switch or the spark generator transformer has a short circuit
Jul 13, 2011 | KitchenAid KGSK901SSS Gas Range
My Dishwasher leaves a white film on dishes.
check inlet water quality. If more calcium deposits in the water this could happen. Try using water water softeners.
If provision for dish washer salt check and add salt. ( not kitchen salt )
Finally check whether rinse aid compartment is filled with the liquid. If you are tablet, extra rinse aid not needed. Try all the above.
Aug 17, 2010 | Whirlpool Dishwashers
Kitchen Aid Model # KUDP01ILWH2 Dishwasher dishes
Hi.
Using too much rinse aid will not work. Stick to user manual factory prescriptions. If you use correct amount of rinse aid, and the right product for your dishwasher, that is not the cause of the stains.
Ensure that you are using the right detergent along with rinse aid. Check specifications on manual.
Ensure that the drain well is clean.
Ensure that spray arms have enough pressure, check water level and impeller pump.
If you still get stains on dishes, and you are sure that they had been caused by limescale, that means that the water in your house is too hard. This will also damage your appliances in the long term, causing faults due to accumulation of limescale and rust.
The best thing to do is installing a water filtration system on the appliance inlet.Call your local appliance shop or technician to discuss about the problem and purchase a filtration system for your appliance.
Apr 08, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
Greetings from Downunder, i have a HDWSE12 dishwasher Rinse aid light flashes all the time and it won t go. I put dish liquid in rinse aid container - still flashes. Don't normally have to use rinse...
the rinse aid compartment has to be one of the biggest things in your unit. it helps with drying process or you will have wet dishes, helps with spots, and also with the cleaning process, this is what you can do . add jet dry or rinse aid not soap .fill compartment then close door ,then raise and lower door 3times then open the compartment door and add more repeat this process until you cant add anymore. this will pull all of the air out of the dispenser and allow you to fully fill compartment . the light should go off .
Mar 04, 2010 | Dishwashers
What does add rinse aid and where do you put it kitchen aid dishwasher
Jun 27, 2009 | Dishwashers
Feb 21, 2008 | Dishwashers
Washing Machines Logo
14 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
