Question about Texas Instruments TI-84 Plus Calculator
8.3521e^-4 make it a fraction
Can you help me on this question?
This answer is correct. 4/12 divided by 2/2= 1/3
The reciprocal of 2/2 is 2/2
Then you multiply straight across and reduce to get 1/3
Mar 01, 2015 | Miscellaneous
How can 36/63 be reduced
It is simple. 36=4x9 and 63=7x9. The number 9 is a common factor in both numbers. You can simplify the fraction by dividing both the numerator and the denominator by 9.
36/63=(4x9)/(7x9). You can rewrite the fraction as (4/7)*(9/9)=4/7 because 9/9=1.
The reduced fraction equivalent to 36/63 is 4/7. Since 7 and 4 have no common divisor you cannot reduce the fraction further.
Jan 05, 2012 | Office Equipment & Supplies
How do i make 31 1/4% as a fraction
First of all, know the following basic rule about fractions and whole numbers:
4 / 4 = 1
Therefore:
( 31 X 4 ) / 4 = 31
Therefore:
124 / 4 = 34
So:
34 and 1/4 = (124 / 4) + (1 / 4) = 125 / 4
Therefore 31 and 1/4 can also be expressed as the following FRACTION: 125 / 4.
If you are trying to convert that to a DECIMAL value instead, then 31 and 1/4 % = 31.25 %
Good luck, I hope that helps.
Joe.
Oct 24, 2011 | Texas Instruments TI-30XA Calculator
How to fraction. where is the fraction key
This calculator is incapable of displaying simplified fractions (i.e. 1 ½), you will have to use the decimal value or contain your complex fraction in parenthesis. (i.e. (5/2).)
Mar 01, 2011 | Texas Instruments BA-II Plus Calculator
How to convert fractions into equivalent fractions
find the least common denominator between the original fraction into the new fraction.
example, 1/2 to 2/4 to 4/8 to 8/16.
May 19, 2010 | Cycling
How do you square a fraction with a negative number like (3/4)^-2
Place both the base and the exponent in parentheses
(3/4)^(-2) then press enter. Your answer will be in decimal form at first 1.777...
Press MATH
Select the 1: Fraction option and it will convert your decimal value to the fraction answer of 16/9.
Negative exponents flip the fraction. For instance, (3/4)^(-1) = 4/3. So for (3/4)^(-2) you could just square the numerator and denominator separately to get 9/16, and then flip the fraction to account for the negative. That will give you 16/9.
Jul 24, 2009 | Texas Instruments TI-83 Plus Calculator
Fraction button directions
Yeah, there isn't a fraction button on an 84. You have to enter it manually as 4/9 or if simplifying a decimal, use the Ans>Frac under the MATH menu
Aug 26, 2008 | Texas Instruments TI-84 Plus Calculator
Fractional powers
use the "carrot" button, ^. Type in 4^.5 and you get 2. If you are going to use fractions, use the division bar and parenthesis and not the fraction key. Example 4^(1/2) = 2
Apr 27, 2008 | Casio FX-300MS Calculator
Texas Instruments TI-84 Plus Calculator Logo
18 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
