Question about Toshiba Computers & Internet
Toshiba c855d will not boot, even from recovery usb
LT will not boot up, get toshiba logo, then enters auto recovery, ulitimately get the unmountable boot
Geekman
  • 32281 Answers
SOURCE: averatec 3280 unmountable boot volume
You can install Windows XP from your CD drive, you may have to change the boot order so you can boot up from the CD first.
Posted on Nov 23, 2008
ohms
  • 1879 Answers
SOURCE: Unmountable boot volume
have to re-install windows
to boot from CD, check your BIOS setting and have the computer to boot from the CD FIRST
Posted on Jan 11, 2009
KeithHL
  • 67 Answers
SOURCE: Unmountable Boot Volume Win XP
This is an issue know by MS. If you can put it in another PC as a secondary drive (or use an "USB encloser" to connect it) perform a checkdsk on the drive (use the properties of the drive/tools tab and select check disk).
Or...
If you have an XP install disc handy please try these steps (borrowed from an MS KB article).
  1. Start your computer by inserting the Windows startup disks orthe Windows installation disk if your computer can start from the CDdrive.
  2. When the Welcome to Setup screen appears, press R to select the repair option.
  3. Ifyou have a dual-boot or multiple-boot computer, select the Windowsinstallation that you want to access from the Recovery Console.
  4. Type the administrator password when you are prompted to do this.
    Note If no administrator password exists, press ENTER.
  5. At the command prompt, on the drive where Windows is installed, type chkdsk /r, and then press ENTER.
  6. At the command prompt, type exit, and then press ENTER to restart your computer.
  7. After you repair the volume, check your hardware to isolate the cause of the file system damage.
If this procedure does not work, repeat it, but type fixboot instead of chkdsk /r
If you never got a Windows CD PCs usually have a "rescue partition"type setup with a hard drive utility. That can be used as well. Let meknow if any further assistance is required I'll be happy provide moreinformation...
Posted on Oct 07, 2009
  • 76 Answers
SOURCE: unmountable boot volume
hi,
-this can be a hardware problem or a software problem
-run diagnostics first on the computer
-turn off computer; while the computer is off, press and hold the "Fn" key then press power at the same time to initialize the test
-if you find error message like 0142 - this is a hard drive failure; contact your manufacturer for replacing your hard drive
-if no error is found, it is a corrupted Windows; you need to reinstall Windows, ensure you consult local technician to back-up files before installation.
cheers!
Posted on Oct 08, 2009
  • 21 Answers
SOURCE: Boot loader problem
I think the virus attacks your computer or ther is some thing wrong with your graphics, you can cheak it or look cheapest aion gold and aion cd key
Posted on Dec 16, 2009
My lil girl lost my disk to my Toshiba c855d-s5307 laptop and I'm locked out of computer please tell me how to do a factory reset or help me get in please
THROUGH F12 AT STARTUP
To access the System Restore, Refresh and Reset options using the F12 option at startup, perform the following:
  1. If not already, ensure the computer is completely shut down. How To: Shut Down a Laptop with Windows 8
  2. Now restart the computer by pressing the power button - IMMEDIATELY start tapping the F12 key on the keyboard until the "Boot Menu" screen appears.
  3. Using the arrow keys, select <HDD Recovery> and press "Enter".
  4. On the next screen you are asked to confirm if you want to continue with recovery. Select "Yes".
  5. The computer will bring you to the Advanced startup screen.
  6. Select Troubleshoot. Under Troubleshoot you will see "Refresh" and "Reset".
  7. Select "Advanced options." Located here is "System Restore."
Nov 17, 2015 | Toshiba Computers & Internet
Factory reset toshiba A105-S4384
Put Recovery Disk 1 in the CD/DVD drive, then power off your computer, unplug everything from the unit including the AC, remove the battery, press and hold down the power button for 30 seconds, replace the battery and then AC, power on, at the Toshiba logo screen press 'F2' to enter the BIOS Setup, in setup press 'F9' to load setup defaults, press 'F10' to save and exit, now at the Toshiba logo screen press 'F12' to enter 'Boot Sequence', with the up and down arrow keys to select 'Optical Disk Drive' or 'DVD/CD Drive', you will then see 'Press any key to boot from CD/DVD drive...' with the dots counting down, press any key before the count down finishes. Assuming you get back to the Toshiba Recovery Utility menu, select the 'factory default' choice, and return your unit to its out-of-the-box state.
Jul 01, 2014 | Toshiba Satellite L655D-S5093 Laptop
How to factory reset my Toshiba Satellite A105-S4384
Jul 01, 2014 | Toshiba Satellite A105-S4384 Notebook
MY TOSHIBA SATELITTE C850D IS NOT BOOTING
Have you tried a System Restore/recovery? Will it boot to Safe Mode? If you remove ALL media DVD,CD,USB, unplug, remove battery, plug in, reboot, any change? Remove the HDD, test.
Mar 11, 2013 | Computers & Internet
Toshiba Qosimo stopped on startup logo, unresponsive to commands
I used this same response in a previous solution....It mostly looks like your installation of Windows has been corrupted....some system files may have been affected. See if you can find the recovery disk for your machine. One of the things you can try is use the CD as your boot disk (you may need to enter the BIOS or SETUP to change the boot order...there will be a key to hit when you see the Toshiba splash screen when you first boot the machine...it will say press "<some key here>" to enter setup.)
Once you boot from the disk I would try getting to a command prompt and running the following command: chkdsk c: /f /r
This will scan and repair any bad sectors on your hard drive and if they can be repaired it may make your machine bootable again. If they cannot be repaired, it may be that your hard drive is dying. ither way...if you get into the machine (even from the boot disk) if you can see the drive, I'd recommend backing up whatever files you can, because if the drive dies, you will lose your data. You may also use a Linux LIVE CD ... this basically boots a version of linux from a disk rather than your hard drive, it may allow you to test hardware and back up files as necessary before thinking about reinstalling Windows.
Feb 28, 2013 | Toshiba Computers & Internet
My Acer Aspire 5732Z laptop hangs up on the Acer logo starup screen every thing stopped even cant enter the the bios hitting f2 or many other i tried
Remove ALL media, DVD, CD, USB. Unplug, remove battery, plug in, reboot. Try a system restore/recovery. At boot tap ALT+F-10 repeatedly.
Jan 25, 2013 | Acer Aspire Computers & Internet
How do i do a system rebuild on a acer travelmate 2410 series 2413NWMLi , the <alt> <f10> does not bring anything up
If your computer does not have a hidden partition for OS recovery, a recovery CD will be required in order to recover the Operating System using Acer Recovery Media.
Order the Recovery Media from Acer https://secure.tx.acer.com/RCDB/Main.aspx?brand=acer
  1. Restart the computer.
  2. When the Acer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Acer Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
    Note: If there are multiple Recovery CDs, please insert the first of the Recovery CDs.
  8. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Note: if your computer is unable to run the Acer Recovery process, or errors occur during recovery, please contact Acer support.
Aug 17, 2011 | Acer TravelMate 2300 Notebook
How to Burn Recovery DVD image into USB Stick?
first unmount the files and copy them to usb .then change the boot option in cmos settings ,usb drive as primary boot device.
Nov 05, 2008 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
14 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
