Question about Sony Muteki RDH-GTK1i Mini Hi-Fi System - 220 W RMS - iPod Supported - 30 Channels - FM, AM - 2 Speakers - WMA, MP3, CD-DA - USB - Remote Control
Ipod dock Not working
Polaroid clock dock
Take a mignifing glass and look for banted pins on the dock...
Nov 28, 2013 | Apple iPod Audio Players & Recorders
Tip
How To Connect Your iPhone, iPad, or iPod To The TV
The following devices have support for TV out:
  • iPhone
  • iPad
  • iPod touch
  • iPod nano (3rd generation and later)
  • iPod classic, iPod (5th generation), and iPod photo
Note: Other iPod models may support viewing of photos or slideshows on the iPod display but do not support TV out.
The following docks support TV out when used with an iPod model or iPhone that supports TV out:
  • Apple Universal Dock (requires either the Apple Composite AV Cable or the Apple Component AV Cable-will not work with the iPod AV Cable). Search the store for part number MB125G.
  • iPod Universal Dock or iPod with color display dock (iPod photo dock)
Important: The iPhone dock does not support TV out.
iPod models that support TV out can support viewing on a television in several ways. Use the tables below to see which cables and docks can be used with each iPod model. Check the documentation that came with the cable or iPod for information on how to connect and enable TV out.
Note: If you choose to use a third-party cable, make sure it has the "Works with iPhone" or "Made for iPod" label. Learn more about iPod and iPhone accessories.
All you need to get TV out is a compatible iPhone, iPad, or iPod and the correct cable. If your device works with the component and composite cables, then the choice depends on the TV(s) you will be connecting to.
  • Apple Composite AV Cable (part number MB129LL) will connect any iPhone, iPad, or iPod to your TV using RCA Cables.
  • Apple Component AV Cable (part number MB128LL) will connect any iPhone, iPad, or iPod (except iPod with color display (iPod photo), and iPod (5th generation)) to your TV using Component Cables.
A dock can be a welcome addition if you're going to keep your cables connected to the TV. The Apple Universal Dock includes an Apple Remote so you can pause and adjust the volume from a distance. The docks and cables are sold separately.
on Feb 21, 2011 | Apple iPhone Smartphone
My new Panasonic SC-HC57 is showing a 'checking connection' message when I put in my ipod Classic into the dock. I've upgraded my ipod to the newest software through iTunes, but still no
Not all ipod classic work with your SC-HC57 you need an older Panasonic SC-HC30 to work with that ipod :( or an iphone or ipod touch to work with your SC-HC57
Dec 26, 2012 | Panasonic SCHC57 SC-HC57 SC HC57 Compact...
Does this work with the ipod touch 4th gen
Here are it's features
Product Features
  • Portable speaker/display system designed for all "dockable" iPods**
  • Crystal-clear, 7-inch widescreen LCD display with 480 x 234 resolution
  • Pair of aluminum cone neodymium drivers and Class D digital amp
  • Built-in iPod docking station; 3.5 mm auxiliary input for other devices
  • Measures 8.7 x 1.7 x 6.5 inches (W x H x D); 1-year warranty
Notice
Notice it say ALL iPods, as long as its not the 5th gen ipod with the new dock connector it should work fine.
Oct 14, 2012 | Sonic Impact 5090 Video-55 LCD Video and...
I purchased a Denon I Dock ASD-11R and a Denon Receiver AVR 2311CI. The iDock says it is compatible with the Gen IV ITouch. The dock is compaible with a gen III ITouch - worked fine. I plugged in a Gen...
I too purchased the DenonASD11R Ipod dock to connect to my Denon AVR2311 Receiver, and I too experienced the same problem. I think it might be software compatiabilty issues between Ipod Gen 4, the Dock and Receiver. Some other Denon Ipod Docks are not compatiable with Ipod Touch 4. I returned my Dock and received full refund, and will be waiting for Denon to bring out another Ipod Dock which will work with Ipod Gen 4
Dec 31, 2010 | Denon iDock Docking Station for Apple...
With my ipod dockes I am getting a distorted sound
Did you get this solved??
I am having the exact same issue!
Oct 21, 2009 | Bose SoundDock® (Black) Docking Station...
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
Oct 03, 2009 | Bose SoundDock® (Black) Docking Station...
Remote wont work with the ipod
Make sure the ipod dock connector is clear of any debris both the on the dock and on the ipod. Use a can of air to clean these and try reconnecting it.
Try updating your software on your ipod. Plug it into itunes and update.
http://repair-scratched-ipods.blogspot.com
www.huskyipodrepair.com
Jul 26, 2009 | Dual Electronics ihome iH9BR iH9 Alarm...
Bose sound dock - no sound comes through it but my ipod works with the ear plugs so it's not my ipod
I had this problem for the pat two days. Believe it or not I took my Ipod touch of the dock. Shut the power off to the Ipod to reset it. Also the power to the docking station. turned everything back on. Put the Ipod back into the docking station and heard the beep.. and hit play and it was working again. Not sure but shutting Ipod off does act like a reset.
Jul 19, 2009 | Bose SoundDock digital music system...
Teac sr-l200i, the ipod dock just started malfunctioning in the last hour. When I dock the ipod there is barely any sound. This is the case for all my ipods on this unit. The ipods are working on all my...
I had the same problem but with a different TEAC docking product.
My TEAC would not recognize my ipod therefore I was unable to control my ipod via the docking station remote control.
Plug your ipod into the docking station and power down (reboot) your ipod. Once the ipod powers down (in the dock) restart the ipod (yes, while in the dock).
Mar 09, 2009 | Teac SR-L200i-W Docking Station for Apple...
Sony Muteki RDH-GTK1i Mini Hi-Fi System - 220 W RMS - iPod Supported - 30 Channels - FM, AM - 2 Speakers - WMA, MP3, CD-DA - USB - Remote Control Logo
Top Sony Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Sony Furniture Expert? Answer questions, earn points and help others
