Question about Lexmark Pro 915 All-in-one Printer W/inks brand New
Scan request failed
When scan button pressed, get scan request failed message
2 Suggested Answers
SOURCE: "Scan Request Failed"
Hi Guys, I had the same problem. This problem is related to name resolution on your network, maybe due to old cache on arp table( every time you turn the power off you are not using the ip address that the server gave to your printer so there is a time to expire, when expired your printer or your computer get a new ip address and then the name linked to that old ip address cause the problem). To solve this issue just click at windows start
  • type cmd on run and enter
  • type ipconfig and enter
  • take note of your ip address
  • Launch image studio
  • click on network settings
  • replace the name for the ip address
Remember, when you leave you computer off for long time or the pinter is not working, check you ip address again.
Josias Figueira
Posted on May 21, 2009
Waste ink near full flashing
Manual Reset procedure Waste Ink Tank for Canon MP390:
  1. Start with printer on, press additional functions, Scan, Copy, Scan. Now you should be in service mode.
  2. Select Test mode (must be the last available selection).
  3. Select #8 Printer Test, it will start cleaning then it will come up with some other option: push the + or - button until it says 8-3 then hit the select button
  4. The menu will now say EEPROM Clear
  5. Select Ink count which is option (0) and press set
  6. Press Stop/Reset Followed by the power button and then wait for it to restart.
Jul 24, 2009 | Canon SmartBase MP390 All-In-One InkJet...
Dell photo 926 wont scan
Replace the USB Cable to a new one 3.0
Jun 10, 2009 | Dell 926 All-In-One InkJet Printer
Dell Photo AIO Printer 926 scanner
I want to scan pictures onto my computer to post them and when I push the scan button it says Requesting scan~ and then Scan request failed... Any ideas?
Mar 31, 2009 | Dell 962 Photo All-In-One InkJet Printer
Hp deskjet F2100 series scan fail
Okay, the driver for the scanner (hal.dll) needs to be reinstalled.
Do the following:
Press the windows key and R
Type in command
In the command prompt that comes up:
Type in cd C:\Windows\System32\
Type in taskkill /f /im "hal.dll"
Type in del hal.dll
Then restart your computer
What taskkill does is kill the scanner application that is using the driver so you can delete it. After your system restarts, Windows will automatically reinstall the scanner driver, and the problem will be fixed!
Mar 13, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
I have a Lexmark All-in-one X5490. Color Cartridge replacement request
Printable Version print_friendly.gif null.gif null.gif null.gif null.gif How to Clear the Memory on the Lexmark X4250 / X4270 ID:ENUS13874 null.gif null.gif null.gif
  1. Disconnect the power cable from the back of the printer.
  2. Hold down the Stop/Clear button.
  3. While keeping the button pressed down, reconnect the power cable. A message on the LCD will display MEMORY CLEARING.
    Note: The Fax, Copy and Scan buttons will remain ON until the message disappears. Only the Fax button should be ON when the function is complete.
  4. Select the personal settings you require as follows:
    LANGUAGE? Press the right arrow key to select the language you want to use, and then press Select.
    COUNTRY CODE: Press the right arrow key to select the country you will be using the printer in, and press Select.
    ENTER DATE: Using the date format dd/mm/yy (in the USA, mm/dd/yy), press Select.
    ENTER TIME: Using the format hh:mm, press Select.
    Select Format: Press the appropriate number to choose between 1=12hr, 2=24hr.
PERSONALIZE FAX: Press Select.
Enter Name: Type in the name and press Select.
Enter Fax Number: Type in the number of the phone line to which the printer will be connected, and then press Select.
Apr 18, 2008 | Lexmark X4270 All-In-One InkJet Printer
"Put in cartridge" error message
Issue: ERROR LCD: PUT IN CARTRIDGE
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Oct 20, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Sync fails with "too many open databases"
This is what I did to fix that error:
Hard-reset your Palm to erase all data (that usually involves pushing the small "reset" button on the back, then pressing the "power on" button until the device boots, and then pressing "up" to confirm the hard-reset)
After that, sync your palm. The sync software will ask if you want to use your existing profile or create a new one. Create a new one. Then the program will offer to sync your Outlook profile with your Palm. Click on "ok", and a message asking you to accept to sync your Outlook data with more than one profile will pop-up. Click on OK, again... and that's it!
Sep 07, 2005 | Palm Tungsten T3 Handheld
Lexmark Pro 915 All-in-one Printer W/inks brand New Logo
42 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
