Question about Holmes Products Humidifiers
Hm1280 need rubber gasket for cover
I need top cover for my humidifier part number 324866-301 does anyone know where I can find one?
Shop for Humidifiers' top cover on Google
CPAP.com - H4i Heated Humidifier Top Cover Lid and Seal
www.cpap.com/.../resmed-h4i-heated-humidifier-top-cover-seal.html
People Who Bought H4i™ Heated Humidifier Top Cover Lid and Seal Also Bought. ... This is the plastic cover used with the Resmed Humidiare H4i Heated Humidifier. ... People Who Viewed H4i™ Heated Humidifier Top Cover Lid and Seal Also Viewed.
HumidAire 3i Heated Humidifier Top Cover Lid and Seal
www.cpap.com/.../H3i-Heated-Humidifier-Top-Cover-and-Seal.html
This is the plastic cover used with the Resmed H3i Heated Humidifier. It also includes the plastic gasket below the tube connector.
Sep 29, 2015 | Humidifiers
Idylis #0484756 unit shuts off tank emply but take is full
Just purchased a Idylis model 0484756 and it has no
operators manuel. Is there one available?
Where?
Thanks
Jan 20, 2014 | Humidifiers
Need new rubber tank gasket for Holmes humidifier Model HM4600
after scouring the INTERNET AND FINDING PLENTY OF SITES THAT WOULD SELL ME THE WHOLE CAP FOR 24.00. I MAD MINE USING SOMETHING FROM ace hardware THAT COST 2.50 Small suction cups with the hook [CDBL-7500S11] PART NUMBER 7500 .CAN BE MODIFIED INTO MAKING YOUR OWN GASKET. IT WORKED FOR ME ..REMOVE HOOK FROM SMALL SUCTION CUP. cut off nib with sharp pair of scissors. THEN DRILL HOLE THROUGH CENTER OF CUP WITH 7/64 DRILL BIT. re insert plunger part of cap through cap with spring and re- attach suction cup instead of gasket. MINE WORKS FINE ON A HOLMES 3700
woodinvirginia
Jan 23, 2011 | Holmes Products HM4600-U 11 Gallon...
Why won't the water stop running?
When my humidifier refuses to turn off, it is always because the plunger in the electronic valve is stuck.
When the rheostat senses low humidity, it sends current to a coil, this creates a magnetic field that pulls a plunger up into a tube away from a rubber gasket (hole in center to match plunger) and water flows thru the hole. When humidity is high, the rheostat stops the current, and a spring/gravity push the plunger back against the gasket.
The plunger or the tube can get deposits, or just rust ever so slightly, and then the plunger gets stuck in the up = on position.
Buy a new solenoid valve $$$, or take your solenoid apart and clean the plunger and the tube with steel wool.
Jan 09, 2010 | Aprilaire 600 Humidifier
Honeywell HWM 450
I found a solution to our problem with the fill cap failing/leaking. It was/is not the cap, it’s the gasket/grommet/o-ring. Remember “THE MAGIC BULLET”, well the gasket, that’s where you tighten the top to the bottom, some are white and some are black, THEY FIT the Honeywell HWM450!!! ------- Problem solved.
SEE EBAY: NEW AUTHENTIC MAGIC BULLET 4 REPLACEMENT GASKETS SEALS
Dec 31, 2009 | Honeywell HWM-450 4 Gallon Humidifier
Humidifier not working
Ensure there is water in the tank.
  • This may be caused by mineral deposits in the water channels. Try the following: Clean the water tank, base and vapor nozzel with a damp cloth to remove any build up in the water channel.
  • When was the last time the cartridge was changed. (If it’s been over 3 months, this could be the reason why the unit is not working properly.)
  • Unscrew the demineralization cartridge and run the unit, if it starts to mist then you need a new cartridge. (insert cartridge link here)
  • The screw cap for the water tank, onto which one first screws in the demineralization cartridge, has a small rubber gasket. make sure that gasket is not too far down against the outer screw cap. If it is the spring loaded button would not work properly to let the water descend into the base tank .
    The solution: push up on that small rubber gasket so that it is as far up and away from the screw cap as it can be without falling off, and voila! you get mist!!
  • If you have changed the filter recently then take out the cartridge and run the unit without the cartridge for about 15 to 20 minutes.
May 18, 2009 | Venta Airwasher VS 207 3.7 Gallon...
I need the rubber o-ring on the water fill cover for my Senbeam humidifier model 696 please help get this part. my phone # 320 269 9368
Please call the Venta Customer service team.
1-888-333-8218
If you have proof of purchase the part ( cap) is covered under warranty. If you do not it will cost $13
Feb 27, 2009 | Sunbeam Ultrasonic 81696 Humidifier
Pollenex HealthAire UltraSonic Humidifier SH50 need new washer
Sure. But if your homemade gasket leaks try a little 100% silicone caulking. It smells bad for an hour or so but it will help. If you use the silicon make sure you allow it to thoroughly dry before you get it wet or it "will" leak.
Good luck
HVAC Teacher
Feb 18, 2009 | Aprilaire 700 Humidifier
Slant fin gf-210 needed part
slant fin sold the humidifier biz to another company.  info at the slant/fin site http://www.slantfin.com/contact.php
Nov 18, 2008 | Slant Fin GF-210W 2 Gallon Humidifier
Humidifiers Logo
44 people viewed this question
Top Holmes Products Humidifiers Experts
cwradio73
ray gallant
Ben Eng
Level 1 Expert
Are you a Holmes Products Humidifier Expert? Answer questions, earn points and help others
