Question about Haier Furniture
My haier refrigerator is not cold - Haier Furniture
Haier refrigerator freezer not cold
feel the top of the compressor is it warm or is it clicking noise or is it hot can you tell me that?
Appliance 911 Sea Breeze
Nov 12, 2015 | Haier Refrigerators
My haier refrigerator freezer does not get cold
check the cold control thermostat and the thermistors
Feb 18, 2015 | Haier HT18TS45SB Refrigerator
Refrigerator turns off restart a couple days later haier hnde03
the is an electronic timer for defrost mode on all frost free frig/ freezers it goes bad to find that in your frig call the manufacturer or a good repair man
Aug 24, 2014 | Haier HNDE03VS (32 cu ft) Compact...
I have a haier model # htq18jabww-01 and the freezer seems to b working fine but the fridge does not seem to be cold at all...any soultions??
The "Cold-to-Coldest" adjuster in the freezer steals chilled air from the refrigerator to add more to the freezer. It's a mechanical damper. Set it fully CCW to cold (warmest position). I also put duck tape over half the chilled air outlets in the freezer to increase the chilled air pressure feeding the refrigerator section. Set the thermostat in the refrigerator to 8 or 9 and the freezer works fine and everything in the refrigerator is 38F.
Apr 18, 2012 | Haier HTQ21JABWW Top Freezer Refrigerator
Why my model HTZ21 JICR55 HAIER IS FROZEN AT THE REFRIGERATOR BOTTON/
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 10, 2011 | Haier Refrigerators
Haier refigerator will not get cold
if the motor is runnig it has no gas in the system if motor is not running check the thermostat
May 15, 2009 | Haier HSB03 Compact Refrigerator
Haier model hslorwnawn refrigerator/freezer neither one gets cold or freezes.
Could be a compressor or refrigerant charge problem. Check to see if the compressor is hot. If so is it running. If not and it is hot the compressor is the problem. If the compressor is cold it is in the power supply to the compressor. That would be the thermostat or defrost timer. If the compressor is running and it is not cooling it could be the refrigerant.
May 25, 2008 | Haier Refrigerators
Haier bottom freezer
I have a haier compact refrigerator ESR042PBB.I lost power and when power was restored the refrigerator didnt work.Th einterior light came back on but the refrigerator wont cool. I checked the back and the cooler is hot.I unplugged it and let it stay unplugged over night. The next day I plugged it back in and left it for 24hrs.It still doesnt work.
Nov 07, 2007 | Haier Refrigerators
Furniture Logo
Top Haier Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
jasbo
jasbo
Are you a Haier Furniture Expert? Answer questions, earn points and help others
