Question about Kenmore 24032\24036 Top Load Washer
How do you test the pressure switch on a kenmore 11028002011 washer
Starts spin cycle makes a click and immediately stops
catriver
  • 878 Answers
SOURCE: Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Posted on Apr 27, 2007
SolutionGuy
  • 331 Answers
SOURCE: Kenmore wont agitate or spin
Mindurrs, your motor coupling has gone to the great beyond. Time for mourning has passed and now it must be replaced. The job takes about an hour and parts run about $10.00, ready? First, go to your local appliance parts retailer and purchase a coupling, part #285753. You'll need this for repairs. UNPLUG THE WASHER!!! Standing in front of the washer, you'll see two screws on either side of the control panel... remove these then flip the control panel over. Now, toward the right side, you'll see a wire harness that plugs into the top of the top panel, disconnect this. Now, on either side of the top panel, you'll see two brass colored clips. Take a screwdriver and poke it into the hole, use it as a pry bar. Pry the handle of the screwdriver toward the wall behind the washer, the clip will pop out. Now tilt the entire cabinet of the washer toward you to about a 45 degree angle then lift it out of there and set it aside out of the way for now. OK, now we're into the guts of the washer... Look below and in the center, you'll see the drain pump (it has 2 big hoses attached). Behind that, you'll see the motor... that's what you'll be taking off. On the right side of the motor, you'll see the electrical connections. Remove the long white one from the motor. (CAUTION!!! THIS NEXT STEP MUST BE DONE, OTHERWISE PERSONAL INJURY MAY RESULT!!!) You'll see a black round thing mounted to the motor on the right hand side, this is the capacitor. It has 2 red wires on it. (It's basically a 120 volt battery that is just waiting for you to touch it so it can shock you, badly) THIS MUST BE DISCHARGED (voltage drained off) BEFORE CONTINUING. Remove the 2 wires using insulated needle nose pliers. Now, discharge the cap by touching both terminals of the cap at the same time with your needle nose pliers. This will discharge the capacitor so it's safe to handle. Now, above and below the motor, you'll see 2 clips mounted on it, remove the screws that keep these clips in place then (with a flat head screwdriver) pry the clips off the motor. The motor and pump will drop out of there. Rotate the whole thing off to the left (with the hoses still attached to the pump). Now you can see the broken coupling (compare the old one and the new one). Pry the old pieces off the motor shaft and the transmission shaft and throw 'em away. Install the new coupling (notice the semi-triangular shape of the inside of the plastic coupling? I use my screwdriver handle... poke the handle into the coupling, place the coupling squarely on the shaft, then tap [don't BANG] it home with a hammer) and rebuild in the reverse order of dis-assembly! Sounds complicated, but it's not. I've done a thousand of these and it took me longer to type this than it would have for me to do it for you! And, for what it's worth, you have a good washer there. It's actually made by Whirlpool, and well worth the repair.
Posted on Sep 16, 2007
Master_Tech
  • 770 Answers
SOURCE: won't spin
check your lid switch ...on the lid you see a little plunger this should go into a slot areound the rim of the washer and close a switch. you can try a small screwdriver to press it in while in the spin cycle..see if it works then if not the sw will have to be replaced as this needs to be closed (lid) before the unit will pump out and spin
Posted on Feb 23, 2008
SOURCE: Kenmore 70 series Washer will not go to spin cycle
i had the same problem and agree that the lid switch is probably shot. Try putting some type of weight on the lid right over the switch when it gets to a spin cycle. If the machine starts spinning, that's the problem.
Posted on Dec 16, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
I have a Kenmore 11028002011, It goes through the cycles and drains but does not do a final spin to get the clothes all the way drained, there is no standing water left. When I select drain/spin it works...
No spin, or lite spin try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Or try the hand test:
If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test. WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a bloody death. Proceed at your own risk! Have a nice day.
- put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand
- turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin
- if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand
- if it takes very little force to stop the tub from spinning, the clutch needs to be replaced.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand.
Your next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,basket driveor the tub drive block
If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer.
Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washerhttp://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiN
Mar 16, 2015 | Kenmore Washing Machines
Kenmore stylemaster 902202 will not spin, agitate or drain tub spins freely
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. Or
http://www.youtube.com/watch?v=TB_W6sPdzkM
Pl click if helped
Apr 07, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore model 23832100 washer will not spin in rinse cycle kenmore model 23832100 washer fills, agitates, and drains, but will not spin. Makes noise after draining. BUT if I manually turn off the machine...
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Mar 30, 2013 | Washing Machines
Kenmore Washer 70 series Model #110.22722100 won't spin
Click if helped.
Feb 25, 2013 | Washing Machines
Kenmore washer front load 417 wont spin
Click if helped
Feb 18, 2013 | Kenmore 24032\24036 Top Load Washer
No spin cycle
This is usually caused by the pressure switch. Here is a link with the other possible problems. To check the pressure switch follow the link to the video. http://appliancehelponline.com/topwashernospin.html
Jul 16, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer 48102 starts filling then stops
the pressure switch should be tested for failure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore Washing Machines
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
Check the lid switch. That is a VERY common problem on these models.
Dec 13, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
18 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
