Question about Fuji FinePix AX650 16MP, 5X Optical Zoom Digital Camera
Fujifilm AX650 autofocus won't work
Everything works on this camera except the autofocus. When I press the button down, sometimes it says IAF. It doesn't matter if I zoom in or out; it won't focus. It worked fine several days ago. I changed the batteries too.
  • 188 Answers
SOURCE: No picture taken when shutter release is pressed
if you see no reation of the pressing of the button i.e. no focusing, no error message nothing , then most probably a simplest problem , the shutter release button may not be working for few reasons : 1) defective switch. 2) defective flex cable. 3) camera exposed to some physical jerk or dropping resulting into disalingment between inner switch and the shutter release button.
Posted on Jul 09, 2006
  • 75 Answers
SOURCE: Camera switches off when I press the shoot button
Are you using NiMH rechargable batteries? Digital caemras are real battery eaters and Nickel Metal Hydride batteries are the only ones that can stand up to the drain. Buy ones with the highest power rating yu can get. If this doesn't help, then the power board has started to fail and needs replacing.
Posted on Apr 04, 2007
wooker626
  • 3 Answers
SOURCE: Menu button and Zoom buttons not working
Yes im having the same problem ,however i open/disassembled my camera and my results was a broken ribbon connector from the Rear Button Board to the Main circuit board.....
The only problem is i can not find any parts list information or where i can get this part....
can any one help me with this??
FUJIFILM F460 Camera
REAR BUTTON CIRCUIT BOARD
Rear Button Assembly
Thanks
Wooker
NOKTURNAL CAR CLUB
BALDWIN PARK, CALIFORNIA
Posted on Dec 22, 2007
zohail
  • 1223 Answers
SOURCE: My FINEPIX s1000fd fujifilm camera
pls update firmware issue will be resolved most likely and pls rate me fixya for help
http://www.fujifilm.com/products/digital/download/s1000fd/fupd.html
Posted on Apr 13, 2009
SOURCE: Fujifilm FinePix S1000FD shutter button won't focus
There is an option in the menu to put camera on continuous auto focus. You must have the camera on manual setting to have this option available, but once selected, it should stay on in auto setting. It will wear the battery faster, but it should solve the issue you are having. Hope this helps!!!
Posted on Aug 16, 2009
Testimonial: "Luckily the camera was still in warranty and I sent it off to Fuji to get it repaired. It came back and they had replaced the shutter button. Thanks!"
Can I do factory reset and how do I do it many thanks
If it has some kind of video output to TV, then maybe it works and you can choose the reset from menus.
Mar 12, 2015 | Fujifilm FinePix AX650 16MP Digital Camera...
I bought FUJI FINEPIX AX650 6 months ago.Now After taking pics when i press play button to view , it shows READ ERROR.another problem after taking a snap, the LCD display shows blank (color black) for few...
when having a problem with your digital camera. switch it of, remove the battery and charge the battery. When you replace the battery, the error should be gone. If not, you should contact the service centre closest to you.
Jan 22, 2014 | Fuji FinePix AX650 16MP, 5X Optical Zoom...
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
Camera won't turn on when shutter is pulled down
Does the camera turn on when you press the power button ?
Jan 16, 2013 | FUJIFILM FinePix Z300 Digital Camera
How can i get photos from my Internal memory to my S.D. card? can't see an option on the menu and can't view photos from the internal memory whilst there's the memory card in it.
Put the card in the camera. Press the Playback button (right-pointing triangle). Yes, you won't see any pictures from the internal memory with the card in. Press MENU/OK to bring up the playback menu. Use cursor-up/down to highlight "Copy" and press cursor-right. Press cursor-up/down to select "INTERNAL MEMORY TO CARD" and press cursor-right. Select the desired option and press MENU/OK.
Full details are in the "Copy" subsection of "The Playback Menu" section of the manual (page 70 in my copy). If you need a manual, you can download one at
http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/a/finepix_av100_manual_01.pdf
Sep 13, 2011 | FUJIFILM FinePix AV100 Digital Camera
Autofocus
reset the camera thru the menus... if it still does not work then repair
Aug 22, 2008 | Olympus FE-230 Digital Camera
Nikon d40 autofocus
Look on the left side of the lens. Make sure the button is on A for auto focus and not M for manual. OR not stuck in the middle. Hopefully that will solve the problem.
Jul 11, 2008 | Nikon D40x Digital Camera
The focus on the NIKON COOLPIX P80
some cameras have a choice in menu as to monitor or continous autofocus-monitor or continous means camera always seeks a focus which hurts bat life but makes focus quicker-single means camera won't focus untill button pressed halfway-make sure you are not in macro mode-flower icon on screen-this will screw up focus except for close up work-good luck-check menu settings for your type of focus
May 12, 2008 | Cameras
Fuji FinePix AX650 16MP, 5X Optical Zoom Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
