What is an ND26 packet jams on a Xerox Phaser 7760?
  • 18 Answers
SOURCE: Xerox phaser 7760 streaking
to fined out what the problem could be you need to open a word doc and sent a blank page to the printer. from this it will show where the problem is in the printer
if u still get streaking it couls be a faulty toner and it may not be the cyan toner either. i would give the fuser unit in the printer a check. if there marks on tthis unit i can cause this problem as well
Posted on Nov 23, 2007
pdouglasss
  • 125 Answers
SOURCE: 004-354 cyan atc sensor failure
Hi mgordonO:
The problem is with the toner cartridge or the developer. One or both may be empty.
Posted on Apr 08, 2009
  • 2072 Answers
SOURCE: Xerox Phaser 7760 Prints White Lines Diagonally Across Page
That is normally caused by a bad developer housing.
Posted on Jul 16, 2009
SOURCE: i have blocked the fuser uit
All you have to do is open the fuser unit on the end (2 Screws) and you will find a fuse which has 3 strips (in a plastic casing with wires attached). You must the solder the strips so that they are joined, and that should reset the fuser.
Posted on Jan 13, 2010
  • 57 Answers
SOURCE: Xerox Phaser 7760. Set document to print as double
There are a few solutions to this problem.
1. The 7760 does not duplex from the MPT 2. The 7760 will not duplex certain paper types eg. envelope, transparency, labels, thick card stock,special. If your paper type is set to any of these it will default to simplex printing. 3. Conflicts in driver settings will cause the printer to default to simplex printing. 4. From the machine settings, duplex can be enabled or disabled. (Though driver settings should override this).
Hope this helps.
Posted on Jan 19, 2011
Fault 004-350
Here is a link for the Phaser 7760 service manual:
Xerox Phaser 7760 Service Manual
004-350 Marking Device Fail (Controller Video)
Mar 23, 2014 | Xerox Phaser 7760 Laser Printer
Tip
XEROX PHASER 7750 7760 FAN ERROR.
Hey guys this is a Xerox Phaser 7750 and 7760 fan error video tutorial.
In this video you will learn how to fix the error code 48 on the Xerox phaser 7750.
Also you will learn how to fix the error codes 010-391,010-392,010-398 that are related to the Xerox Phaser 7760.
This video shows how to remove covers.
All the wires that you need to disconnect from the machine to fix these errors.
There is also another video part two that shows you how to reinstall everything back
in it’s place. Step by step tutorial hope you enjoy.
http://www.youtube.com/watch?v=yMud-Md2xpc
on Dec 30, 2009 | Office Equipment & Supplies
Xerox phaser 7760 saying "black ATC sensor failure - code 009-380", i changed developer and xerox phaser 7760 saying "black ATC sensor failure - code 009-380", i changed developer and xerox phaser 776
When you have a sensor failure, you need to replace the black ATC sensor and recalibrate it. Another reason for sensor failure is you are not getting toner moved down to mix with the developer...the toner tube/auger spring could be clogged up or not functioning.
Also if you changed the developer housing when you changed the developer, you need to change the value to the new sensor # that comes with the housing.
Feb 16, 2014 | Xerox Phaser 7760DN Laser Printer
Xerox 7760 paper jam
at which position it will jam it matters tell in detail or send a sanp of it
Apr 10, 2013 | Xerox Phaser 7760/YDX Laser Printer
Xerox phaser 7760 saying "non-phaser imaging unit"
There is a snippet on the Xerox website to solve imaging unit recognition problems, link below. http://www.support.xerox.com/support/phaser-7760/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB Usually this problem only occurs if the NVRAM has been reset or the engine board has been replaced without backing up the NVRAM. You can download the snippet to your printer through Centreware or by downloading the 'File Downloader' utility from the same page above.
Hope this helps.
Jan 09, 2011 | Xerox Phaser 7760DN Laser Printer
Xerox phaser shows error code 007-274. -john
what model phaser there are so many and not all codes are alike yours might indicate a tray 2 power on jam
Dec 22, 2009 | Xerox Phaser 7760/YDX Laser Printer
Xerox phaser 7760dx
This could possible be the magenta drum cartridge. also try cleaning the ROS assembly window below the drum cartridge.
Jun 10, 2009 | Xerox Phaser 7760/YDX Laser Printer
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
